View Full Version : Modified JK Tech
- 2011 tuner.
- Esp
- Gear oil?
- What Coilover Spring Rate do I need?
- 3-4 inch lift kit help?
- Quick and easy rubi rail question
- 2012 Rubicon Exhaust
- Sway bar hitting break line help....
- Rear Track Bar Bracket and Teraflex Write Up
- Does anyone use a Skid Row Top Prop?
- control arm length for 3.25" lift?
- Warn M8000-s winch
- Bare steel options
- Lift/tire height question
- Clear Coating Bed Liner
- 2012 Sahara JKU, bent rear axles
- nitro axle sleeves again
- Gobi rack, arb awning , Need solution ! Plz
- Exact hight of my lift.
- What did you pay for 37's?
- Installed Yakima Rack Base
- HORN INSTALL HELP!!!!!!!! SOSrelaxing
- Evo Rear Corner Install
- Bedline bellow doors? Pics
- Want lift, Which One?
- RK rear trackbar relocation bracket rubbing
- looking for a new rear bumper, need advice
- VDP end caps with recessed winch & grill guard hoop?
- wheels and tires for jeep ?
- Tie Rod
- Winter Wheel Change?
- ebs traction control
- How much did It cost you to re gear?
- Softtop problem
- rubicon axel lockers
- Looking for 2012 trans cooler line protection
- Rear tire carrier
- Yakima roof rack for hard top....Thoughts?
- Welding
- Bolt on pinch seam covers
- Hi Lift jack Mount on Garvin Wilderness rack
- Re-gearing for tires
- Soft Locker advice
- Snorkle
- Were dose this go
- Need some wheel help please
- Mpg and high rev
- Roll cage options?!
- Fender marker lights???
- Need Help!! 3" lift after install issues. Need advice
- Working on getting a BA Jeep built
- What Size Shocks???
- Line-X my exterior
- King Steering Stabilizer
- Teraflex sway bar disconnects
- Teraflex 2.5" BB or rough country 2.5" BB
- 2012 lift question
- Swaybar ?
- F9 vs pro rock
- Just a relevant question about to vendors, no room for discussion?
- Question on Clayton 3.5" lift
- Do i regear or not!?
- LOD bumper question
- Rock krawler 2.5 bump stop problem
- Remote Reservoir Shocks
- Or fab tire carrier
- Steering wheel dance
- Shrockworks sliders
- Now i'm under my jeep
- Tpms life
- Toe In Question?
- Tire question
- 2013 Driveshaft or Exhaust Spacers?
- Hi, New to Forum! Lifting Jeep
- Regearing with stock tires
- Lifting my 2012 another 3/4" HELP
- Rk 2.5" max travel w/LOD full width rear bumper w/tire carrier ..3/4" spacer question
- Which is taller, TF 2.5 or RK 2.5?
- Exhaust Spacer??
- What's the biggest size tire that will fit the stock 16" rims?
- '13 Sport S + Rubicon Springs?
- does anyone have issue cuz heavy mod?
- Can someone check something on their flashpaq?
- rock krawler 2.5 max question
- Need help with a Lift question, what should i go with?
- Who has the best pricing on some 35" KM2s?
- Little rust?
- Brake.pad question
- death wobble
- Teraflex control arm modifications
- Snorkel and windshield lights
- Fenders and Bumpers
- Synthetic oil
- Superchips Tow tune: Best fuel to use?
- Self Tapping Screws vs Pop Rivets
- Help with wheel size
- Axle Sleeve Dimensions?
- Amt forged aluminum
- Rock krawler x factor mid arm vs. evo enforcer
- Mopar Front Off-Road Bumper with Rigid Dually D2's
- 2012 3.5" Lift 2 Door - Squealing sound when accelerating - Driveshaft?
- Suggestions on build
- Lift issues towing and dash lights?
- Anyone know what kmc wheels are these?
- Shocks for a 1.5 lift
- Procal problems
- Recommendations for tires?
- TPMS question.
- Modified 2dr Rear Stretch
- Locker Opinion
- Thoughts on my build plan
- P0430 and P0420 Code
- Teraflex- thank you
- Installed a Smittybilt GEAR console
- Rock Krawler lift
- Fenders cut.... need trim help
- Gear break in procedures
- 3rd and 4th gears has a reaction delay. anyone know why
- what do you guys think? Tire question..
- Tube Fenders
- Best Undercarriage Armor
- Thoughts on XRC8 Winch?
- Trektop NX in sunrider position
- Bumper + Lift= better MPG's
- Who here bought 33's then wished for 35's?
- Tuners
- AEV suspension problem?
- Coild springs
- Step in height
- Teraflex or BDS Bumpstops
- My 35" duratracs may never come in, Backordered with no date
- RK 2.5 max travel vs BDS 3"
- plasti dip tail lights/side markers/blinkers
- Upgrading to 35's
- Best price on Nittos???
- Off Road Limitaions???
- budget VS suspension
- Mickey Thompson & Beadlock Wheels
- Does this look normal?
- Where to get new TPMS
- Dynomax- For Off-Road use only?
- suspension and wheel upgrades on 2012 wrangler unlimited sport s.
- Bushwacker 2 door flat fender flares on a 4 door?
- Installing red insert on dash gauges
- Spring Opinion.
- Need advice on tires
- B&M cooler question
- yet another tire size question
- LOD / Engo combo
- Cheapest way to running 35x12.50's??
- Anyone else have finish issues with smittybilt winches?
- 3.5" RK X factor ?'s
- Kargo Master Roof Rack
- Level ride
- B&M cooler install help
- Bestop bumpers?
- Gears
- Q about Rubi Exp. 3" lift
- 2012 Rear Drive boot torn/AEV Lift question
- 35" BFG M/T or Dunlop Mud Radial… OR 33's Duratracs
- I need help!
- Unlimted shocks on a two door
- How does your Jeep handle after 4" of lift?
- Camping Jeep Style Livin Lite ARB
- Bilstein 5100 corrosion?!?!
- Aftermakret Intake and Throttle Response
- Yakima Combo. Need advice and opinion
- 2013 TPMS Compatability
- drain plugs and spray in liner
- RK 2.5 max travel question
- Need Advice On A Good Lift and Tire Combo
- Replacing Mirror on '12 JKU
- Recommended tire pressure on and off road?
- Hi-Lift Jack Questions
- I Regret the 2.5" Rough Country
- is a K&N air filter worth it?
- front brake question
- Front drive shaft cv boot tron
- Hypertech settings
- Teraflex 6" long arm kits
- Problems/Cons of Running 37s
- Warn VR10000-s Winch
- Can anyone tell me about these parts?
- Best Top Best Price
- Trektop NX HELPPP!!!
- need some help and opinions..
- 2012 Sprint Booster users or Procal trick?
- Wheels and tires without lift
- Welding Strut Hoops - Need info
- how was your gas mileage?
- Canoe tie-down question
- RK 3.5 Max Travel lift install, tips, thoughts and just a couple of gripes
- sway bar link question
- shocks being a limiting drop factor
- Tire station keep recomend 70psi...
- Rock Krawler 5.5 Mid Arm
- All right Teraflex, if you're sooooo smart!?!?
- 2012 unlimited sport 6 speed with 3.21 gears, what size tires are you running?
- drive shaft vibe question
- Shocks for OME Lift
- looking at pro comp 7032's have a question...
- Nitto Terra Grappler or Nitto Trail Grappler?
- Jeep JK replacement soft top question
- Painting Poison Spyder rock knockers
- Air Lockers
- Light Bar and AEV Snorkel
- What first???
- Help, what wheels are these?
- Wheel wobble @50mph on 35s
- Info on a lift kit
- help ! just before to install tire!!!
- Besttop Bikini top looks awful
- RC 3.5" + adj. trackbar question about pitman & brackets?????
- BFG A/T KO on Stock Carrier
- Looking for advice...
- Running with no muffler?
- Tire balancing.
- another lift ?
- Need help with figuring out my suspension
- is the stock tire carrier sufficient?
- Jeep noob in need of tire/wheel suggestions please.
- Air Intake
- Swamp in Jeep
- Rear shock mounting question
- abs, esp, and traction control lights all on?? help
- Lexan hoods for JK
- Trackbar Bracket/Braces
- Fender clips
- Front Trackbar Creaking?
- Superchips? Bully Dog? Other? Which is the best tuner mid?
- Powertrax No-Slip Install
- 14/14 to 16/17 Coil Spring Swap
- Considering the Dynomax Evolution Competition Cat-Back Exhaust -- Evap Issues???
- Smittybuilt flat flares
- Fender flares help!!!!
- question about retorque after instal lift kit
- EVO Draglink Flip Install.
- Wobble.
- Power mirror relocation?
- Power mirror reloctaion
- What are the biggest tires I can put on a 2012 JKUR
- Dana 44 Axle upgrade options
- Recommended lift kits?
- Tires
- How to tell which 15" alloy wheels will fit my '12???
- What "looks" better 17" or 18" black addicts with 35" tires?
- plasti dipping wheels...question
- Is this the right lift for me?
- Went from 37's to Stock wheels and tyres and got Death Wobble.
