View Full Version : Modified JK Tech
- Going 3.5" Lift and Drive shafts, pinion Angles, Control Arms....
- set up perfect!!
- Tire sidewall height
- Airaid to OEM airbox idle issue
- Suspension Lift
- Beefing up dana 30
- Can High Grass Cause Pinion Seal Leak
- Rubicon Express Bushings
- Black american flag sticker for cowl?
- Teraflex trac bar
- Overhead lockable storage mounts to soundbar? For a laptop.
- 35's and flat fenders-NO lift can it be done Pics please
- 15x10 on 35's
- Train horn
- how to clean your engine?
- AEV Procal tire height setting
- Out with the old in with the new!
- Cummins 4bt conversions
- steering "pop" on lifted 2012 jk
- Front bumper question?
- Stubby bumper help please!!
- Brand new Bushwacker Flat Flare Marker light not working
- King coilovers vs King 2.5 shocks
- Bead locks
- gorilla ? or mcGard? which one are you prefer?
- DIY JK Exhaust with Dynomax builders parts
- Pattern Check
- Lockers,t-case or control arms
- Nitto Terra 295/75 16 on 2.5in lift photos?
- Control arm suggestions
- 07' JK problem
- Affordable tire carrier search.
- Regular service questuion
- rough country quick disconnects
- 255/80-17 photos please.
- rear shock install, what direction? (fox 2.0)
- Lift and tire help
- Whats normal rpms @70 mph?
- Refresh wet okale seat covers?
- Want to put 15" rims & 35s, does anyone know a brand that will fit over the calipers
- Do i need them? Brake rotor retaining clips
- Vendor experience Question
- Time & Trouble Body Lift?
- Anyone running Banks Exhaust and Banks Air Intake on Pentistar?
- What would you do?
- gears
- Will spring lift plus budget boost spacers work together? OME + RE
- Air pressur
- Coilovers
- Somethin is rattling
- Suggestions for Rock Sliders with Teraflex LCG Elite Lift
- Death Wobble????
- sound clip of rugged ridge exhaust???? anybody?!!
- To be or not to be....
- Nitromare sleeves!
- Replacing my D30
- Dana 30, 35's, and a locker?
- Anyone running Rusty's JK 3.25 advanced lift system?
- Help with mirrors
- What wheel to get: XD addicts or rugged ridge
- Input on lifts ?
- Wired tire question
- Advice needed. 2.5 lift and KEEP factory rake?
- Wow jeep dealer theu don't really know about jeep..
- Twist the 2.5's on 35's
- AEV 2in or Teraflex 2.5in with no shocks.
- Rear factory isolators?
- Talk me out of 4.88s
- Newbie backspacing question
- Help a dumb guy out.....
- 2.5 BB now..2.5 or 3.5 coil lift next??
- Feedback on Quick Disconnects
- need help: possibly a dealer/service is screwing with me on repairs
- mbrp offroad exhaust, aluminized
- EVO long arms
- Rugged Ridge Door Hinges- Anybody Using Them?
- what happened my rear wheel?
- Trail tools list
- Smittybilt xrc10 comp series ir quadratec Q11500 integrated solenoid?
- falken rockey mountain or BFG A/T
- 34'' on stock carrier
- 800 bucks burning a hole in my pocket.
- 3"-4" for 2013 4-door JK
- Anybody Running a rally mirror???
- Coilover Questions..
- stock rear sahara shocks 3" lift and evo rockstars
- Sleeved and gussetted D30 strong enough to rock crawl with 37" tires?
- New Owner 07 Seems to be tilting.
- Rear Coil Spring Arch Fix & Puck Lift?
- TeraFlex LCA
- Fox IFP 2.0 Advertised Shock Length/ Lift Height Confusion
- DIY Grab Handles
- Rear track bar qwestion
- Flashpaq
- What size JKS disconnects? Have 2.5in lift now, but will add bumper/winch
- D44 Rubi axles, how much could i get?
- Amp for Boston Acoustic swap, or just Amp for Sub?
- ATX Wheel Offset
- Duratrac vs. Terra Grappler
- help me pick a rim for gy duratrac 275/70/18
- Airaid intake - 33's
- im clueless on this(rough country) control arm problem??
- 1" body lift on a 2012 stick JK
- 2..5" Kit Installed with 37s and it ripped my fender off!
- Skid plates compatible with Rancho RS720003 exhaust crossover?
- Just bought my nitto trail grappler 35x12.5x17
- Lifted, caster compromising and offset balljoints
- Have you changed your front upper control arms?
- slip in coil spacers
- Rock Krawler rear trackbar bracket rubbing shocks
- TF Hinge and Mount Question
- Exhaust question ???????
- Dumb Newbie Question but need help?
- gearing and axle question
- Suggestions for rear upper control arms.
- Need a good tire!
- Recommendations for exhaust for 2013 6mt JKU
- Rough Country 3.5" with 8 adjustables, disconnects, adj track bar, and 2.0 shocks
- Koenig ironworks winch.
- springs - leveling kit ????
- Need write up/information on installing rear driveshaft
- 35's on stock 2012 Sahara Unlimited wheels
- 2013 Jeep JKU, Teraflex 2.5 w/ Bilsteins 5100 Driveshaft making contact Help
- YES... another lift tread
- K & N Filter
- Adjustable front trackbar - Teraflex vs Rock Krawler designs
- Wildboar snorkle release?
- What is a "tuner" in terms of Intake/Exhaust
- Need a little help guys
- Bump stops
- Rugged Ridge windshield lightbar and rigid dually leds.
- Axle Sleaves Need Welded?
- Who makes these JK grill inserts?
- procal for 305/70r16
- Are these really needed for 4'' lift?
- Adjustable trackbar. Which one?
- Alignment Probz??
- Poison spyder or ridged gen 2 50" led mount?
- white knuckle
- Pinch seam trim required? AEV lift
- amazon warehouse deals?
- GF Performance Chip
- ACE rock sliders?
- How to fix this????
- Olympic 4x4 supply JK8
- Electronic Stability Issues
- Need help on choosing tires!
- Has anyone had any experience with SPRINT BOOSTER?
- EVO1 Race JK suspension ?
- Advertised lift vs actual lift
- This much rubbing normal?
- Rough Country 3.25 lift kit review
- Adding a front bumper and 1" spacer
- Glass Sider Upper Doors for a 2007 JK?
- Fender clips and rivits
- Driveline vibrations?
- Looking for a Shop to Re-gear in Alvin/South of Houston Area
- Lockers: Air or Electric?
- Teraflex Performance Leveling Kit
- Suggestions on Shocks?
- Leveling Question
- Nitro sleeve installation
- Rubicon Owners: Flashpaq or Traildash?
- 33s vs 35s questions (please help)
- Help with shocks?
- New to the community, Lift advise please.
- Dick Cepek DC one 15'' wheels clearing caliper
- Control Arms Question
- Spring retainers - when to use
- 2012 transmission
- *** 2.5 BB with 305/70/16 s***
- Instaled teraflex 2.5 coil lift today
- Need some help with air bags
- Help with teraflex kit
- Any good sales on posion spyder 50" led mounts?
- Trailer Question about axle/hub
- PSC hose routing question
- New tire smell should be a cologne
- AEV, Teraflex, or Rock Krawler
- Air Intake Time
- Looking for a Shop to Regear in NY/NJ Area
- Wheel question
- Leveling Kit and other goodies
- Do I "need" rear upper control arms for 2.5"
- A mod from the wife!
- AEV Lift Help!!!
- Clicking/knocking im driversides rear
- Installed Christmas gifts this weekend
- Help me pick a tire
- draglink bushings
- procal or flashpaq
- Teraflex 2.5 coil lift kit vs Rock Krawler 2.5 Stock lift kit
- newbie needs help
- Smittybilt SRC front bumper, rear bumper, and rocker package.
- Help front suspension
- Beefy front end?!?
- what is the cheapest way to loft my stock Rubicon
- Anybody have pics of RR XHD stubby and RS-E stubby with bull bar?
- 35s on stock or aftermarket wheels? what should i do
- What do you think about 305/70 tires?
- Inner fender help?!?!
- Steering Radius Issue after Drag Link Flip Installed
- synthetic oil
- Old and cautious!!!
- Rugged Ridge Snorkel...Does it Work?
- Front locker
- Can I put 37s on my jeep?
- Uneven tread wear; HELP!
- Will a spyderlock wheel fit on Or-Fab tire carrier?
- Rock Krawler 5.5 in. TF 6 in. DD ?
- Where will it rub?
- Frame mount rear d ring mounts?
- Your opinion Rancho RS9000XL Series VS. Bilstein 5100 series?
- Oil pan busted
- 17/59 and 18/59
- Wheels Spacers Vs. Soft 8s???
- translucent wheel paint?
- 2 grand for wheels and tires
- Your opinion on Toyo Open Country MT or Nitto Trail Grappler
- trans " hunting" and bad mpg's
- Question about headers
- Poison Spyder Brawler Rockers?
- Coil Difference???
- Traction control questions
- where is the best site for jk parts?
- Skyjacker 2.5-3.5" Sport Lift Kit with Hydro Shocks and 315/70/17 Duratracs
- opinions on bushwacker pocket flares?
- Teraflex shocks, the one weak spot.. replacement suggestions?
- 2007 power steering reservoir cap leaking
- The Best!
- Hood latches give too much on highway
- XD Wheel Offsets and backspacing
- R/C Stearing Assist?
- X-fer case shift knob replace with RR #11422.02 aluminum?
- A lot of people regret 33"s, but anyone regret 34"s? (Tires, ugghhh!)
- Nitro sleeves worth it?
- Rear Track Bar
- Wheel Spacers w/ 35's
- Does any one use AEV bade for stock scissor jack.
- Track Bar Question
- aftermarket steering stabalizer.....just for looks?
- 2.5" lift gains 3.5" is this right?
- Rear Trackbar Relocation Mount vs Spring
- How so small my car jack..
- JCR Bumpers vs. Poison Spyder Bumpers
- ATX Beadlock help
- Beating a dead horse
- Pure jeep stubby non winch bumper
- Pics of 33s w/leveling kit and ARB or AEV bumpers?
- Name its side steps and bumper
