View Full Version : Modified JK Tech
- Painting Steel
- 3.0" Full Traction Economy Plus Lift - Feedback Requested
- Gas overflows
- 35" Tire Concerns
- Hawse Fairlead mounted on XHD RR Bumper
- To all that have install there Driveshafts!
- Anyone running a fabtech lift
- converting to beadlock wheels
- 3.21s, 35s, manual offroad - Will Superchips help?
- Front locker... Or New Axel...?
- Teraflex coilspring lift missing parts
- Roof Rack and Snorkels - do they play well together?
- Bedlined Interior Doors and tailgate?
- 3M Dyna-Pro bedliner/rocker panel guard
- 4.5" aev premium lift
- Bushwacker flats
- Bedlined fender flares?
- Best compromise for daily driver with moderate off-road?
- best 3-5" lift out there?
- Sector shaft brace kit
- 35" Toyos on a Dana 30
- Rough Country Winches
- RIPP supercharger questions
- ddm hid lights!!
- I NEED a softer ride...
- Need Opinion a lift kit.....
- Need help!!! Bearings and axle shaft
- Rusts Exhaust
- Best 37" tire for DD?
- locking gas cap
- LOD rock sliders work WITH stock rubicon rails?
- 2102 exhaust
- used gears??
- Another lift topic - EVO vs. Teraflex. Which to go with.
- 5x127 to 5x150 adapter
- 4" springs on 3" lift???
- Locker Question
- Ok, confused about 2012 gears
- LoD Gen 3 Rear Bumper Lights
- Mini death wobble!?! Please help.
- Rear wheel speed sensors hitting tone ring
- 35x12.50 Toyo MT's On 17x8 Cragar Soft 8's? Will They Fit?
- Wind?
- Hi-Lift mount alternatives for mounting in the cabin
- creaking trackbar
- another typical lift fitment question
- AEV Snorkel. What else to waterproof?
- Hemi Supercharger
- "Recommended" rim size vs. MY rim size..
- 305/70/r17 terragrapplers
- Highway shocks????
- Balance Bags for 37" tires ?
- New 5.38 break in and wheeling
- Mopar off road front bumper fitment on a 2012 JK?!
- help with 285 65 18 plz
- Soft Top Minor Repair / Mod Help Needed..................
- what products do u use
- Best budget mods?
- Ripp supercharger with AEV snorkel
- Wheel Vs "Rim"
- Advice for a newbie
- Pic Request: Black AEV heat reduction hood with black vents on a black jk
- rusty's 3.25 on 2 door
- Superchips Info needed
- 33" ....wich gears??
- Lift Suggestions For a 2 Door
- Teraflex lvl kit+shock questions
- Painted hardtop?
- whats the difference between a 2dr coil lift and 4dr coil lift?
- What did you pay for labor on gear install?
- pls help! have I bent my housing?
- Calling ALL!!! for a syle of rims
- 35" tires with 3.73 gears
- RIPP Long ARM Suspension Header kit
- Rear traction control wire loom when installing a 35 spline ARB locker.
- Upgrading gears
- PROR skid plates??
- Help with buying first jeep
- Teraflex Leveling Kit - The GOOD the BAD the UGLY
- Lift Help: For 35's & 20's [No Flames Please]
- Heated seats with Iggee seat covers?
- Upgrading fog lights
- ProCal TPMS?
- Quick disconnect making noises
- 6 speed 4.1 with 35s?
- Duratrac 315's. Axtual height?
- Installing new driveshafts
- jeep submarine help
- Need new gears! Which brand?
- Regear.
- any programmers at all for 2011?
- Teraflex performance leveling kit plus puck leveling kit, whats need?
- Towing camper trailer
- Will 16x8's fit on a 2012??
- 4.5" RE extreme duty
- Wheel spacer question.
- 37" KM2s and 2DR
- If I go Teraflex 2.5 inch 4 dr lift with 37s will i have to regear
- Warrior LED Taillights?
- Suspension help?
- Everything I need for a rubicon capable jk
- Steering stabilizer?
- When do you need rotors? (running bigger tires)
- Will this shock work?
- Bestop Trektop
- Help/opinions with rims?
- sway bar disconnect on 08 rubi
- 37s: too much on a 2-dr?
- Bedlined Cowl Vent
- Replacing tires for daily driver
- Gobi Stealth Rack Help
- Superchips helped me love the one I'm with
- Winch Install Question
- Goodyear Duratra vs Nitto Trail Grapplers vs B.F.G Km2 muds.....35"
- Ideas?? Abs/esc/etc lights all on after locker/gears/gussets install
- Any reason steering would feel tighter...
- 2010 Front RUBICON replacement Axle Seals UPGRADES Available?
- Death wobble help
- RR XHD Bumper and Recon Winch
- Magnaflow exhaust
- ANYBODY with a JK 4dr run Body Armor 1/2 doors in front but keep stock doors in rear?
- Manual trans breather hose
- Rough Country 1.25 body lift question
- move bumper after body lift?
- 1310 Coast DS
- Need some help identifying lift on new Jeep
- Talk me out of this!?
- Did I make things worse???
- Power windows
- help with identifying lift kit
- Anyone Rhinoline their LoD sliders?
- rocker guards
- MBRP Roof Rack "Floor"
- Mustang SVT engine swap
- Superchips issue w/ new dealer PCM flash RRT 10-066
- Silver jeep with chrome rims or alloy?
- Snorkel + light bar
- Instrament check
- Fatigue Cracks in Rugged Ridge Flat Fenders
- A Little Input Needed
- Low profile "stubby" automatic shifter modification?
- Smittybilt Storage Boot
- Installing Rock Krawler 3.5" triple threat longarm kit Monday!
- Stock metal front bumper?
- Shock upgrade
- 2011 manual 3.73 gears vs 2012 same specs.
- d44 upgrades or pr44/pr60
- 2012 Skids
- Rim Question
- Plasti dip please!!!! Quick
- 2012 lifts?
- Duratrack help !!
- Headlight help
- Couple questions regarding shocks
- Black Rock 997 Type 8 confusion
- Looking for recommendation for roof top tent & rack
- teraflex
- New gears!
- hardtop chip
- A Hypothesis on Backspacing (No, This Isn't What You Think)...
- Please help !!! Esp BAS lights on. No reason
- Wanting to build the most competent all around 2012 Wrangler possible
- Woods steering stabilizer relocation bracket
- 4-point harness
- Pics of Diff Size Duratracs on JKU's.
- Teraflex or Evo gussets?
- What pro comp rim is this?
- Canadian Tire Black Rocker Guard?
- 5x5 to 5x5.5 wheel adaptation HELP
- Dropped a chunk of a rivet ...
- Lift Question
- Quick help me settle the age old exhaust debate
- Small lift
- Caution: TF 2.5" Lift, when using 3rd party shocks
- Herculiner, Rhinoliner or ???
- Total height of JKU with 33's and 2.5" lift
- Diesel Swap Qustion
- 35" tire and C' gusset question
- Rusty's cherry bomb exhaust..home garage install?
- Great Lift Information
- Missing horsepower!
- Bushwacker flat fenders wider than stock Rubicon flares?
- Gussets??
- 2012 tpms
- What should i spray my c gussets with?
- Which is more important?
- Best tires for snow + mud
- tall and narrow vs tall and wide
- +18 offset...5.4" backspacing?
- BGF/GY/Toyo, HELP
- axle swap
- Anyone have the retractable rockslider steps by Rampage...?
- Anyone try this roof rack?
- Squealing Grinding and now vibrations 40mph+
- EVO sway bar link length??
- Whats needed to run 37's
- what causes death wobble
- Bumper Search
- Buying JKU Rocker Guards!
- Your axle dream
- Front bumper: Rampage recovery vs RRidge XHD with storage ends
- AEV wheel question
- Death wobble. Broken steering stabilizer. Sigh. Is this common?
- I broke something - part of rear Shock mount
- Went in to get new gears, sleeves and gussets but found out something terrible!
- What gears and did you like your choice
- Ox locker shifters???
- Driveshafts ??????
- Why metal fenders?
- Shock recommendations
- 2010 15" rim question
- Y get a waterproof winch?
- Question about Goodyear MTR 37/12.5/16.5
- Highrock 4x4 rear bumper
- Beefing up everything?
- 20" rims and 35" toyo Open Country M/T Tires
- would it ping?!
- dana 30 upgrade or swap?
- 3/4" spacers, now noise
- Is this odd
- Need some more help
- 17's VS 18 inch rims: pros, cons
- Question for Rancho
- Spidertrax-should i be pi$$ed or not?
- 18" tire upgrade
- RR powered top!
- Gear shop
- OME Part Number For Steering Stabilizer?
- Axle
- Wheels Wobble/Lug Retainer Clips
- Rampage inclinometer question?
- Ladder rack
- Family rejecting my MBRP...ideas?
- 2.5bb, 305/70r17
- Front lower control arms
- Stock Suspension / Bushwacker Flats / 35's???
- Half doors
- Which exhaust system for my 2011 Jeep Wrangler Sport
- Cooper stt question
- How much would it cost to change the exterior color of my Jeep
- Axel Sleeve/ C-gusset necessary?
- superchips or bully dog?
- Roll Bar Covering
- Wheel and Tire Help
- will it work?
- A diff way to relocate rear shocks
- Anyone Installed Daystar 3" Lift Kit in Black with Scorpion Shocks
- Tire size??
- esp bas, abs, traction control light
