View Full Version : Modified JK Tech
- 34's with 3.5" RK lift to much?
- Exhaust spacer question
- Derale cooler install... Where to tap?
- Engine bay - bling & cosmetic improvements
- AEV Corner Guards and Bushwacker Flat combo
- Toe-in question with hydro assist
- Building a ultra reliable JK on 37's
- Trying to identify this wheel
- RpmExtreme Official GEN4 LS Swap Thread 2007-2011 JK
- Overheating
- TPMS For New Tires, help
- 2015 rubicon axles, gear swap 3.73 to 5.38 help!
- Expedition One basic DX front winch bumper.
- Which Bilstein 5100s for a 3 inch lift
- Synergy springs sagging!! Please help
- sway bar links: better too long or too short?
- 33x10.50r15 good or bad idea
- What do I need to purchase for 3.5" lift kit for JKU?
- Quadratec lift kit advice
- draining anti freeze question
- Front axel/locker?!?
- Jeep Reboot---or Do-over so to speak
- Want 35s But Don't Have A Lift Kit? No Problem!
- misting system
- Review - Superchips F5 Flashpaq 3874
- Those with superduty axles, how did you program you gear ratio
- 295/70/17 or 305/65/17
- rugger ridge exo top - just cant get it adjusted right - can anyone help?
- Towing
- Help identifying a military antenna
- 35 Inch Tire Question
- AEV Bumper with MetalCloak flat fenders
- TIPM issue
- new trac bar needed
- Power steering pump mod - now pretty loud
- Anyone seen these window seals/trim for the hardtop???
- cylinder 1 misfire code HELP
- are superchips worth the money?
- Smittybuilt Flux?
- Looking for options
- Snorkel Pre-Cleaners
- Teraflex HD Hinge not flush?
- J.W. SpeakerŪ Model 8700 Evolution J Series LED Headlights Too Bright?
- AEV 3.5 lift
- Which aftermarket companies support vets?
- Alignment
- Wobble diagnostics
- Who's running quick disconnects on Rubicon?
- 33s which gear ratio would you go with?
- 2.5 vs. 3 inch lift
- Fox canister shock install
- Questions..
- Teraflex Epic Front Bumper Offset Winch Options?
- Seat Cover Install
- E-Autogrilles Sliders
- question about maximus 3 carrier
- Broken Sector Shaft
- Coating bare metal Poison Spyder equipment
- Axle leaking
- Shock Relocation Brackets - top or bottom?
- 2014 JKUR Lift Help
- Legato Exhaust and a Volant dry filter Cold Air Kit
- 35" Toyo Open country AT II AEV 2" BB
- Camshaft CEl causing jeep to go into limp mode
- Heat Reduction Hood Options
- 2.5 Inch TF Coil, Stock Rubi MTs and Flat Flares look funny?
- Gecko green spray paint!
- 37s and no lift.
- Jk running hot
- specific Rim and Tire question
- Rear Bumper with Tire Carrier?
- Has anyone had a bad experience with no named wheel spacers first hand?
- Tie Rod End Help
- No Door Mirrors - Looking for Recommendations
- Mopar 4" Lift Inputs
- Oil pressure gauge questions
- Help me ID this infernal engine wracket!! (vid inside)
- Tie Rod/ Drag Link Removal
- Rhino Rack or Teraflex Nebo
- OEM Wheels with 35's?
- Help with shaking
- Back spacing needed for 37's on the JK
- what options for a wide fender flare ( factory style ) I can paint to match my JK ?
- Problem mounting Or-Fab tire carrier with hi lift
- New Mopar 2" lift installed
- Trigger Pulled - JSS Hemi Swap
- Ace Bumper install???
- Relax in Style with the Jammock
- JK REBIRTH!! (new frame)
- Bolt Hood Lock Keyed to Ignition thoughts and installation advice
- Should my coolant look like this?
- ABS, Traction Control, Brake Warning Light, and Limp Mode
- Going to 37s and looking for input
- Hot Oil Warning...
- Winch Choice
- summer top vs frameless soft top
- Looking for aftermarket exhaust
- AEV Fuel Caddy Alternative
- traction control light and break light on
- Jk vs tj ball joints
- Is their any hope for my 3.8? Need more POWER
- ATX SLAB Beadlock install questions
- LoD Rear Linked Bumper
- Gears? Transfercase? What is it?
- My DIY Jerry can holder
- Rotor Question
- Why we get a bad reputation
- 2012 JK Clutch Options?
- Mammoth 8 wheels question
- New gear install. Please help.
- Enclosed Cargo Area DIY
- KING SHOCKS JK Prototype Steering Stabilizer
- Bestop giving me a hard time trying to warranty my Trektop NX
- Gears whinin during decel after new rear-diff?
- Weeping axle seal- advice
- Barricade Roof Rack - Bumper Options
- Drag Link Rattle
- Where do I buy valve covers from??
- Shaking Problem
- 35's no lift, flat fenders.
- Regearing Help
- Do I Dare?
- 10A Bumpers
- Anyone have pressurized water in bumper?
- How-To Tuesday: Beginner Wrangler JK Mods
- Vendors, Looking for F&R Adams Driveshaft deal to order today.
- maximus-3 - JK FRONT BUMPER BAR/HOOP & LIGHT BRACKETS
- Fox steering stabilizer worth it?
- Need some guidance (death wobble-again)
- Whining noise
- 2DR Drive Shaft on 4 Door
- Anyone have to do a PCM reflash?
- Help IDing Tire Carrier Seen On The Highway In MO this weekend
- Questions about 4 point harness and air bags.
- Patch holes in dashboard
- Tire carrier HD
- 4 DR bikini top on a 2 DR?
- Locker Advice
- Bestop sunrider for hardtop
- Planning for my Mopar 2in Lift install
- Vicowl or Grumper? Any have one?
- Best Spring set up with fox shocks
- abs or somthing else
- Turning a Jeep into a house....
- Black Rhino Madness wheels
- Tire Carrier / PSC or GenRight
- Metalcloak hardline flare pictures
- Removal Help
- Clicking sound
- Evap ripped off on trail, then sucked up water
- Front bumper identification...
- can we talk tuners for a minute?
- AM Tube doors for 2-door JK ***Updated***
- new jeep/ new lift pulls left
- Anybody use this bumper?
- Bilstein 5100's
- Help needed building mall crawler
- Stock bumper shackle mounts
- 37's on a 3.8L JK? what are your thoughts
- Wheels HELP!
- Coast 1310 Squeak
- Install Party anyone?
- New 2016 JK Starwood Build
- WANTED: Reamer for draglink flip in Raleigh, NC
- Pintler tyre sizes no lift
- 33's no lift, articulation pics
- Tire pressure
- Free Ways to Make Your Jeep More Fun
- Sway Bar Problems
- Backspacing again! I know...
- Help With Lift
- Help
- Fuel Pump Won't Stop Priming - Engine Won't Turn Over
- Lift kit
- Going up to 40'
- Dana 30 - Dana 44 front similarities
- ABS scan tool
- CRES2 HD CARGO NET Opinions
- Whining grinding sound when going forward.
- Metalcloak Rocksport Shocks
- Whats the difference between the AEV high steer kit and a drag link flip ?
- Clutch system seperste res. Anyone?
- mopar 2" lift kit
- Unsure what gears i have
- Stock exhaust 180*
- Steering box upgrade
- Tuffy conceal and carry security drawer
- took out my seats and now...airbag light
- AEV Geo brackets vs RC X-Flex adjustable front LCAs
- Trail fixes
- Hood vents
- Amerihood and TOL innovations
- Bestop NX trektop tailgate bar issues
- Anyone running 4" Mopar lift?
- Warn Zeon 10 Bumper compatibility Question
- RIPP Superchargers Memorial Day sale!
- Advice on modifying my current 4" lift to drive and handle better on-road
- Jk sways on highway.
- sqeaking in front end after lift install
- Panoramic rear view mirror or blind spot mirrors on vents?
- Re-Gearing from 4:56 to 4:88
- Rear broken axle! How common?
- Caster correction on 2.5" lift
- 37" Tires and PSI
- Having a few issues with vibration/wondering
- Wheel color with Billet Silver
- Drag link flip kit !
- 1st gen Gobi rack questions, answers, mods
- Beadlocks.
- Can anyone idetify this lift kit?
- Battery Side Terminals
- King coil overs
- Upgraded fuel pump?
- TF 2.5" lift + 35's question
- Bug deflectors - do they work
- Strike Force Zebra Half Doors
- Lights and other Tech messing with the battery?
- A weird Premium Soft Top Question
- 3.8 stroker vs 3.8 replacement engine
- Bump steer? New here and need some help!
- Installing Teraflex pre-runner with long arms this week.
- Wheel Spacer Comparison
- Best 3.5 Lift for under $1000 - kit or piece by piece
- Rear OEM Driveshaft yoke hitting tank skid.
- artec raise trackbar question?
- Need recommendation on treating rust on AEV bumper
- ARB Install
- What's Needed for 37's with Stock Fenders
- warn wiring question
- Are Leveling Kits Unsafe
- ORO Airock Suspension Problems...
- Alignment spec's help after lift
- Hard rock rear bumper bolts?? Help
- 35 vs 37 Nitto Trail Grapplers 2015 JK Sport
- 3.6 with 37s
- Quadratech really messed me over, who is better to order from
- Intake tube manufacturer?
- New BBK pulls left or right when braking
- Lift suggestions
- Ripp cai filter dirty
- E-Autogrilles bumpers installed w/ pics
- 35s
- Aftermarket Exhaust systems
- Rock krawler lift upgrade
- Filling your Tires up with argon gas
- Tire size on stock suspension
- Tpms necessary?
- Lockers
- Manual JKU 2011 grinding noise in neutral?
- Bent axle flange or warped rotor
