View Full Version : Modified JK Tech
- Broke Sector Shaft looking to Upgrade
- Need a trustworthy shop for Regearin NC
- Suspension differences JK, JKU, JKUR, with measurements pending
- Power steering pump upgrade
- Bushwacker Flat Flares
- Jk front Dana 44 gear contact pattern
- Lift help
- Slider or Step
- Looking for tire suggestions on my 2017 JKU Sport S
- Jeep JK Floating at speeds
- Spartan lockers and esp..
- Steering on a 2016 JK
- Which lsd and why?
- Cavfab Tie rods
- D60 overkill for 2 door?
- Drag and Track link alignment
- Jump Seat for 2017 JK Rubicon
- Third Brake Light Help
- Help with lift height please
- Jeep Swaying
- Presidents day sale
- Brake Problems
- Spare Tire Bracket
- My Jeeping begins
- Best Spark Plugs To Replace Oem Ones
- Looking for a lift
- Metal Cloak suspension
- Differential Fluid
- Yukon Grizzly Lockers
- 35s or 33S
- Possible problems with 3.5 in lift 2 door jk
- Hydro assist
- Rancho RS62103 Geometry Correction Control Arm Brackets
- Track bar is shot
- Exhaust question for Noob
- Is hells revenge possible with 3 inch lift and 35s?
- New supercharger option
- Diff breather tube keeps getting plugged
- Jeep is very rough on road
- headers and y-pipe question
- What color for my accessories, burgandy jku
- Best side steps on JK to match Poison Spyder Bruizer bumpers?
- JKS Flex link vs antirock front sway bar.
- Brand new supercharger from RIPP sounds really bad please give advice
- King Coilovers on Jk
- M19 blown fuse #5 cylinder buring cool pack
- Opinion on selling my '08 JKU Rubicon
- Vibration 4 inch lift installed
- Axle swap help please!!
- Mounting things onto Smittybilt XRC Exoskeleton
- Freedom top inside Allen head bolt purpose
- Teraflex hub conversion on Fusion 4x4 Hybrid
- 4WD shop near Titusville, Florida
- Best brake upgrade
- Arb RD157 locker Front Axle
- Doug DeMuro on a six-wheeled Wrangler...
- Thoughts on Rancho RS9000XL Shocks?
- Death Wobble!!!
- Interior lights staying on
- 2013 JKU lifted, what mods for better on-road performance
- Raptor Series RBM13JPN Bumper HELP
- Jasper Reman 3.8 Oil Change?
- Best fitting and reliable cab cover
- Uh,,, $35k for a 2017 JKU Rubi Recon, $33k new JL
- Posion Spyder Diff Covers / Need Help?
- JK Rear End Clunking Post Control Arm Upgrade
- 2014 fog light driving me crazy!
- Morryde hinge tailgate
- Gobi Stealth JKU owners Question.
- Jk Pinion Preload Torque
- 2016 JKU Rubicon with sloppy steering, what should I look for?
- Better brakes
- Check Engine Light
- What else do I need for aev 2.5 lift
- Rear Back up Camera failure
- Ordering new axle....some help
- Torq lock/ Aussie lock
- Reverse sound
- Sub problem
- Towing
- New Jeep build - anything else I might need ?
- DV8 Fender delete
- Installing Pedal Commander
- Winch would you choose?
- 285/75/17 with 3.21?
- Looking for opinions on this setup
- Suggestions for a street/trail build, and what breaks first?
- 2" Lift for 2016 JKU
- Options for upgrading JKU Sahara to 4.10
- Lack of power 3rd/4th gear
- Cav Fab?
- Big Rotor Kit Help
- A good wind deflector for driving with the hard top off?
- Death Wobble Question
- Sway bar trouble
- Strange feeling in my front end. Help!
- Stock tie rod end “Seized” ????
- Currie front track bar flex
- What gears for Rubicon and 35s?
- Best starting alignment numbers?
- JW Speaker Headlights or?????
- esp intermittent issues
- Big Clunk
- Car kills and stays unable to start then comes back to life 30 minutes later no codes
- Jeepswag.com reviews
- Bumpers, Stubby Bumpers, Winch Bumpers, Ugh!
- 6.4l engine swap
- Unknown lift?!
- 392 HEMI Overheating questions.
- Lockers / gearing question
- Building a Recovery Kit
- Repair/Replace power cables/control port on winch
- JK 3.8/3.6 Engine Coolant
- Tera44 with factory Rubicon locker wiring
- Pinion slop after re-gearing
- Anyone Running Spyntec Hubs??
- Heavy Weight JKU
- Axle and gearing recommendations
- Jkru
- 20" wheels with 37" tires on stock jeep jk
- Tips for steering wheel adjustment
- Bilstein 5100 shocks tight fit!
- Bad Trans
- P0016 hell
- Rough country shock replacement- upgrade?
- Dash light dim turn signal...
- Aev correction barket
- What are these? Lights? Sensors?
- TOB, Clutch, or Slave Cylinder
- Trauma Metal Works.... thoughts?
- Mopar lifts
- Only one key fob.........
- M28 NGC Fuse
- Need advice
- Steering wheel shake
- TrailDash 2 help
- Any early BF sales?
- Adjusted RE Track bar now sways..???
- Steering box drill and tap locations
- Time for a v8
- Suspension Idea, Opinions needed
- Aussie rear / front lockers
- Front stretch
- Aev procal aligniament
- Squeaky Spare Tire
- Rubicon express 2.0 shocks with reservoirs
- DIY: Heater Core Flush with Filter Installed
- Synergy Jeep JK Steering Kit
- 2.5" Lift and 35s? JKU
- Shock recommendations for DD
- Black Friday deals?
- Which cage and why?
- Let's Talk Cold Air Intakes 3.6L
- RCV joints/front axles - Long Term Reviews???
- Radio install problem
- 4.56 or 4.88 Gears?
- Swapping from Sport to Rubicon springs/shocks?
- TF front full float kit wheels?
- Need new tire suggestions for comfort
- Electrical issues (ls swap)
- New Springs
- Steering box?
- Which Axle Assembly
- Lifted JK front steering component Geometry
- Currie Rock Jock Anti Rock
- Rk krawler joint
- Springtail m pac
- Inner Fenders
- Electronic Sway Bar Disco Issues
- Mud tire cupping cause death wobble?
- SEMA Jeep showcases new Mopar parts
- School me on Tie Rods
- Control arms not greased. This displeases me.
- Looking to buy some bead locks. A little help please.
- Adjustable front track bar
- Grease?
- Shredded threads
- question about lift
- Brake squeaking when turning while applying brake
- Wrangler goes from salvage to savage
- Identify Rubicon Express JK Coil Springs
- Gonna give it a try
- Control Arm suggestions
- Traction Panel Mounting JK 2Door
- Long arm input!
- Bestop Core Doors
- Leveling Kit 18 JK, Preference?
- Not bad for a rookie
- Jeep jk rubicon lift kit
- Using thin 1/8" wheel spacers
- JK tire carrier
- Few more pics....
- Thieves Steal Custom Jeep Built to Raise Money for Cancer Patients
- Another exhaust question :)
- dumb guy, in search of answers
- Rear Brake Line Replacement
- Rusty Rear :(
- ATF leaking after new engine installed??
- Trailer Connector/ EAG bumper
- Considering a Regear
- Dana 30 Beefing
- Who stepped up from an 07-10 to a 2012+ JK?
- JKU soft top leak at B pillar, both sides
- Snow Tires
- Stay away from it?
- Pop up camper hard top
- Mlc 6
- New Guy....needs help
- Steering geometry issue
- Fox 2.0, Old Man Emu, or Bilstein 5100
- Help on Modifying JKU
- Needing some advice
- Radiator Question
- annoying squeak
- New lift rides harsh / ome vs synergy springs?
- Anyone buy 6 pack shocks in the last year?
- Tire size question
- Do i need wheel spacers
- DV8 Ineer Fender Liners side marker light options.
- What's causing this leak?
- Rear control arm question
- 6WD Wrangler Up For Sale
- Best fitting/looking seat covers for 07-11
- Still can't fix death wobble even after changing all my steering components !!!!?????
- Doesn't Anyone make what I'm looking for?
- Windshield Replacement - Help with decals
- Help me figure out my lift height
- What's the better way to reduce rack noise?
- 07 JK Sahara front end clicking
- Humming/vibration felt at gas pedal when accelerating
- ironcross side arm step bumpers / install
- Rubicon still swirly.
- 1000hp JK at Hoonigan
- Control arms or not?
- Rock slider recommendations
- Rubicon Express oil skid plate and Fumoto Valve
- 10th Anniversary bar vs aev bar?
- Need help identifying ODBII device
- Need help before purchasing lift
- How to full a big pinch seam cut
- Floor heat not working.
- Shocks
- Help with drive shaft selection
- Topsy Products Hinge hoist Brackets Review
- Advice needed with dana30
- Stock Subwoofer replacement
- Alignment help
- Smittybilt SRC Classic vs XRC M.O.D Question
- Shock Recommendation
- Service Shops around Houston
