View Full Version : Modified JK Tech
- New Member New JK
- Regearing Math - What am I missing?
- Manual to Auto Swap?
- WARN XD9000 , Synthetic Line conversion.
- Jeep Wrangler PCM, ECM, ECU, TCM - Plug and Play - Well Below Dealer Pricing
- Need Help & Opinions - Must Replace Bent Rubicon D44 Front Axle
- Thinking about bedlining the interior. Questions for those who have.
- Possible Wheel Sensor Issue
- Looking for part number to new black rubicon recon grill
- AEV Rear Bumper and Versahitch
- Poly perfomance nitrogen fill kit
- Moab
- bikini top and hardtop question
- TrailDash2 vs TrailCal
- Modified Shock Mount Question
- Sema build!!!! Worst long arm kit!!!!!
- Passenger side bump stop ?
- Educate me on Flex and limit strap selection
- How to Disable Jeep
- Freedom Top Rattle
- Rock Krawler with Fox ATS
- 3.8L Dominion Offroad/JeepSwag Exhaust Users need input
- Opinions wanted: Putco lighted Boss Grille
- JK manual swap.
- MT Baja MTZ tire pressure
- LED Turn signal install. All lights flash
- Redneck Ram - OD dimension needed!!!
- Mopar Big Brake Upgrade on Manual - Booster / Master Cylinder
- First gen gobi stealth rack with quick release
- Steering Stabilizer Rubbing Adapter/Track Bar Bolt Head
- shop recommendations
- Installed 2.5" lift, but rear seems low...see pic
- new with some questions
- Lift Kit advice please!
- Which 37" tyre to pick??
- FlashCal question
- Prorock 44
- Rear Seat Idea ?
- Rocks v. Sand
- Putting on larger Tires, what's your technique?
- Water in the intake; suggestions?
- 50 inch Rigid Radiance lightbar vs Westabo Throwback top
- broke down on way home from off rd
- Unit Bearing Torque?
- Teflon spray useful for anything on our JKs?
- Mishimoto's 2012+ JK Wrangler Baffled Oil Catch Can R&D
- Manifold Question
- I think i may have damaged my Synergy Tie-rod ends?
- Auxiliary fuel tank where muffler resides
- Mishimoto's 2007-2011 JK Wrangler Baffled Oil Catch Can R&D
- Aluminum 1/2 doors
- 295/70/17 regear?
- The Best Permanent Mirror Relocation Kit w/o rendering your passenger mirror useless!
- Rear Sway Bar Links Rubbing Wheels
- About to burn the trek top
- Melted idler pulley and worn tensioner roller
- Arb air comp install question
- Best shocks in the world
- Diagnose front end/steering wheel shake
- Sahara with 10 Aniversary bumper
- AAM 10.5 14 bolt (GM Version) Brakes
- Hemi Hood Heat Reduction Data
- New-ish JK owner....need to get a jack
- G2 Core44 axle housing install
- Tired of the fake beadlock look... but not wanting real ones..
- New Lift
- Help identifying what's going on here
- Control Arm Length Math Question
- LT tires vs P tires
- Never Owned Beadlocks Questions ? ?
- Front Dana 44 removal
- 3" Lift + Tire Size
- Hard Rock Bumper Install
- 7/8" Drilled knuckles, What are Tie Rod options?
- Hood mounted light bar beam
- Towing Question
- What does this heat shield protect? Am I missing a bolt?
- Lift question??
- Rocker panel thickness for EVO skin install
- Adam's Front Driveshaft Users, what caster are you running?
- New Gears and Warning Lights?
- Well, the 2012 is a total... need some advice on my next steps
- Noise from rear axle
- 3rd brake light relocation opptions
- Alignment issue after accident, looking for suspension guru's help.
- New Battery Questio
- Superchips Flashcal F5 ignition software issue
- gear change question 3:21 to 4:10
- RE 3.5" Sport Lift / Alignment Advice
- What to Know Before Installing Long Arms
- Cargo nets with rear-seat removed
- New Pricing for 3.6 Stage 2 Turbo System!
- tires
- How long will OME shocks last?
- 35x12.50R17 > Do I need a lift?
- D30 Ticking Time bomb or no?
- Front 10a bumper with receiver hitch
- 2016 with lift and tires, brakes are $hit...
- Access to engine bay from passwnger side
- Flashpaq for manual???
- Modified enhanced rock rails
- Bartact seat covers accessories/gear
- Putting stock tires back on for road trip?
- Heavy Jeeps
- Rocker panel repair
- Spring Suggestions
- Softening the stock suspension?
- GenRight Off Road Lock & Load Tub Rail Tie Down System - Install write-up and review
- If you are looking for 35s or 37s....here is what I found.
- Jkur Hard Rock, 37" tires and keep full bumper and fenders?
- Axle sleeved and C-gussets done....
- Built Engine, MORE BOOST!
- No Power to Pass
- Driveshaft clarifications
- Determining Existing Lift Size
- 32" tires?
- Maaco to paint new hood?
- Genright bumper & Zeon winch
- Help with getting a true level lift
- Transmission locks out?
- Tera 44 fluid capacity
- Broken sway bar link, possibly more? Thanks for any advice you have for the fix!
- No headlights
- Speed sensor? Abs light and traction control light came on
- A Look at CAD4X's Electric Jeep Wranglers for Earth Day
- Rear Sway Bar Link Rubbing
- JCR SLIDERS bare naked metal 4 door crusaders.
- NSG370 Rattle Sound at higher rpm solved, but what is this part?
- Rear Teraflex Coil Spacers
- New axles and transfer case. Not sure what to look for. Any advice?
- Replacing Accent Bolts on Method Rims
- Cruising at 80mph with 3.8 with tires sized at 33.5 mounted 3300 Rpm
- PSC Hydro Assist Mounted to Pitman arm
- 315/70r17 on stock rims with 3.73 gears
- Trektop NX header gap question
- Best lift for mall crawling - ready go!
- Front gear pattern and 500mile fluid condition .. Couple questions
- Offset- positive or negatve?
- 2011 jku surges and shakes in reverse??
- Toyo Open Country MT 37 Load Range D in the Rocks
- jk 4 door Weight
- Bushwacker Flat Fenders vs Rugged Ridge Hurricane Fenders
- EVO Plush ride coils!!! I dont know about plush!!!!
- jk pulling hard
- Securing sway Bar when disconnecting PICS....
- Hydro Assist and DW ?
- Rotopax and PS Rock Brawler II w/ Tire Carrier
- New to Jeepin, looking for a little more ground clearance!!
- Do you still use a shade?
- 305/70r17 no lift with little to no fenders
- Help me decide - Rubicon Rock Sider or SRC Step Slider
- King Coilovers....
- Jasper Engines - 2011 JKU
- Armored Up D30 or upgrade to D44?
- O/D off equivalent to Re-gear
- Which Bumpstops?
- 2012 JKU front bumper dilemma / musings
- LNG Conversion
- Validate my my lift plans...
- Gutter Racks = scary
- Lift choice
- 37x12.5r17 bfg krawlers
- Educate me on towing/recovery
- 2013 JKR brakes locking up when turning left or right no codes
- Upper half window tinting
- Trouble deciding on a lift kit
- Is there a good value direct drop-in upgrade radiator for our JKs?
- Superchip Trail Dash 2 Electric fan settings
- OBD2 App for Iphone / Transmission temp
- choosing diff covers for jku sport
- Quiet my Muffler
- Why you don't buy cheap ebay parts
- Budget improvements
- Adams Driveshafts with lift Angles Front Suspension, Front Pinion Angles and Castor
- Is optima battery worth all the hype and money? Your thoughts?
- Bushwacker Pocket flare questions
- Regear and axle advice
- Post-lift ESC issue, J6 fuse questions...
- Cost to Regear? Are local shops ripping me off?
- Cooper discoverer mtp ?
- Lifted Jeep and ESC/Traction control light always on, help
- TPMS Light on in the EVIC - All sensors showing correct pressure
- Thoughts on Power Steps
- 15x7 with zero offset?
- Overland setup
- 3.8 L 6 Speed JKs with 37's
- Questions for Rough Country 3.5" Series II owners
- Hood vent fan addition?
- How-To Spotlight: JK Shock Absorbers
- Help changing boot on drag link
- Short arm or Long arm
- DuraTrac's and Load Range? Should I Consider Another Tire?
- Heat shielding for floor
- Gear Chart Question Use Actual Mounted Tire Size or Theoretical?
- steering wheel esp problem
- Bed liner removal?
- Winch Sag, Upgrade Coils or Add Front Spacer?
- HELP! Magnet fell off passenger seat!?
- Esp kicking in after drag link flip
- 4.10 - 4.56 - 4.88 Which way for 35's?
- No Spare Cargo Rack
- 2013 JK Replacement Brake Pads
- Light bar
- Flashpaq F5 vs Trail Dash 2
- 2017 New Headlights
- Frame Chop Bumper Strength?
- Dreaded Death Wobble
- G2 Gear Swap / 3.73 to 4.88
- Going Rate for a Front Rubicon D44?
- Wheel upgrade thoughts
- 3.8L Aftermarket Camshaft
- Rear storage
- Trying to locate 2 13.50x39-17 Goodrich Krawlers
- Spare tire location thoughts
- Anyone know...
- 2.5" vs 3.5" lift - similar or different considerations?
- Ring/pinion help
- Hitch Drop Question on a Lifted Jeep
- Leveling Kit and 35s
- Noob pinion angle question with pic
- Help pull to the left after alignment and rotation
- The beast has awakened...
- 37" tires possible with add on coils
- Half of a Body lift???
- 3.8L 6-Speed "High Speed JKs" with 35's 75-80 Mph
- Cold Air Intakes - Junk or Good
- Vacuum Pump Relocation
- Question Tires And Lift
- Ripp 3.8 Specific Thread???
- 2.5" Lift or 1.5" Lift w/ Flat Fenders
- HELP! Rotopax rear side window setup
- preferred welding method for long arm kit
- HELP - JKU Overheating and Transmission Hunting
- Rancho 9000XL Install Question
- Im an idiot!!! Bumpstop help!!!
- 20x10 or 20x12 with 35/12.50?
- Wheel spacers
- Dana 30 axle shaft compatibility
- Advice on installing Synergy rear trackbar ?
- Pinion Angle with Adams 1310 Driveshafts
- M.O.R.E engine skid clearance issues
- Tire Pressure Problem
- Rattling noise?
- Jeep jk cad file
