View Full Version : Modified JK Tech
- Question about dealerships and Superchips
- Mounting LT285/75/R16 Goodyear Wrangler Duratracs on stock 2dr JK wheels?
- Terraflex please advise
- Detroit tru trac question
- Got $1400 to spend
- 2-dr. Roof rack--Low profile, no-drill options
- Question regarding tires....
- RIPP Guys what do you have planned for the 2012?
- What to get?
- Tire and lift question
- Changing Gears
- ARB compressor problem
- Smittybilt XRC Armor 09 JK Unlimited "WARNING"
- MB 72 wheel
- Tips? Bushwacker Flats Install
- Wild Boar Fastback Hard Tops
- 35s, removable fenders, properly backspaced wheels, no lift...
- Fab four front stubby with grill guard
- Best easy up/down softtop for JK
- Which shocks for TF 1.5" leveling kit....?
- Anyone running the AEV 2.0" BB kit?
- pr44 vs built d44
- 15x10 ALLOYS. DOES ANYONE HAVE THEM ???
- Jeep height vs. mods
- Superchips help
- Pic request: bedlined grill with unpainted alumium grille mesh
- AEV tire carrier with aftermarket bumper
- Tuff Country 2" lift Opinions
- Looking for input on what to put in my rear pumpkin
- Detroit TruTrac up front
- Leveling Kit & Wheel Spacers
- do they make a 37 mtr in 15 rim
- Which lift?
- Skidplates?
- relation between tire width and axle stress.
- possible?
- Rock Crawler tie-rod
- What to do with rear? It sits low
- nitto terra grapplers or trail grapplers??
- tire prices?!
- Disabling ESC For Modified Vehicles
- Does having a winch on ur front bumper effect ur mpg?
- how much sag are you Rubi owners getting with winch and bumper?
- Please help lift question!! To many different answers!
- Repairs/upgrades after an accident.
- 2011 and Rugged Ridge XHD Front Bumper
- Extended Brake lines question?
- Wet Okole Seat Covers
- When buying new wheels and tires do you purchase a 5th?
- Powertank Packages
- Pro comp m/t
- aftermarket clutch what to get where to buy
- Steering wheel issue
- Lower control arms?
- Gas Mileage Questions or concerns
- Extended Breather Questions
- Spare Tire Mount Mod
- Help with gas tank skid plate
- Help... Wiring up the hella 500 black magic
- Relocation bracket for spare? Yes or No
- Warranty
- Olmpic bumper ?
- 35s: How many miles before something breaks?
- Fog light issue with LoD bumper
- Upgrade Time: Input Needed
- 37's on a D30? Mythbusters wanna know...
- Is this a Camber issue? LCA's on order
- Teraflex rear upper control arms...can I?
- Best 35" tire that will take studs?
- 35's worth the trouble?
- Will I have rubbing issues with 37-13.50-17?
- Question about Dynomax Rockcrawler exhaust...
- Goodyear Duratrac vs. General Grabber AT2
- 35x12.50R17.... so, what wheel width do I need?
- clunking normal when suspensions flexing?
- lange quick mirror, not really holding up in the door hinges?
- 33x12.50's on stock 18's?
- What rims to consiter!?
- Who is the manufacturer?
- should I tack weld those bolts?
- Jester wheels discontinued???
- Need opinions on the Teraflex Leveling Kit and...
- 37s tires any thoughts
- 08 Sahara 4 door 33's no lift setup
- 285 rubbing?
- Teraflex 6 inch short arm lift
- ReGear - is there anything wrong with this picture?
- Ripped of steering stabilizer
- Ratios @ 100 MPH
- Mickey Thompsons on stock 2011 Sahara
- 37" MTR's with Kevlar
- Anyone using Dynabeads for tire balancing?
- Knock under the drivers side
- new headers
- Dana 30 front axle value
- Toyo mts on a d30
- Off camber concerns
- How similar is the stance between the OME kit and the Teraflex or RK 2.5" Lifts?
- ORI Struts-Who has them?????
- Best bang for my buck (rear bumper with tire carrier)
- Trail Grapplers vs. Mud Grapplers
- 33" stock height. rubbing on swaybar links when disconnected
- Just HOPING someone has done this...
- Black Rock Rims - what size do I need?
- Best Way To Black Out Lights
- Budget boost
- 2012 Wrangler thoughts and mods?
- Terraflex performance leveling kit
- wheel shaking
- Wheel spacer problems
- mods in steps!
- Front bumper - stubby vs full length
- Steel wheels or aluminum?
- Rugged Ridge air filter
- EVO MFG 4" DoubleD JK Bolt On Long Arm Kit
- Toyo 37's or KM2 38's?
- Front ELocker use
- Rear Bumpers without Tire Carrier
- smittybilt src rocker "protectors"
- Question about OME nitrocharger sport shocks
- Bent Tie Rod
- Need Help choosing correct Air lift 1000 Bags for my jk after installing 2 inch kit
- Rear bumper help.
- Help with Teraflex links
- shock install help
- Superchip tow/91 tune, which ones best
- New AEV 2" puck lift
- Rear bumper with hitch reciever
- Tera Flex BB installed!! Why no front track bar bracket? Is new track bar necessary
- green valve stem caps ???
- Hood Louvers
- lost power steering after body lift?
- Steering wheel question????!!!!
- Raceline Beadlocks
- OME lift question
- 4wheel online?
- Did i get all the parts to fix my DS?
- Welding C Gussetts... am I off my rocker??
- Steering stabilizers
- Tereflex disconnects or JKS quicker disconnects?
- jeep death wobble
- Terra Fkex 1.5 Leveling kit
- Rugged Ridge Cowl Covers?
- What tire size with these wheels? - Help Please!
- What tread depth replace tires-Nitto Mud Grapplers due to lost performance rocks mud
- 1310 vs 1350
- Smittybilt neoprene seat covers question
- Can I take my fuel tank skid plate off, while keeping the car drivable?
- License plate mount on Olympic front bumper?
- Long term Iggee seat cover review anyone??
- Keeper winch?
- superchips fan temp
- Not driving as well with Steelies.
- loud exhaust
- Installing RK 2.5 Max Travel - tips and advice welcome
- Need help driving tomorrow with new gears
- OME or Bilstein shocks with OME 2"
- 4.7 engine swap
- ebs esp lights on and the stering wheels no longer in the middle
- brackets for stubby front
- Which lift for 37s on a 2 door?
- Question about ACE Engineering rock sliders...
- Paint hard top. What to use?
- Balancing 35x12.5x17 tires
- Where to get a hood?
- The Black Ops now has the 2 inch lift is installed
- SRC Bumper
- Nitto mud grappler or wrangler mtr with kevlar????
- Tire question
- Teraflex 2.5 coil lift alignment specs?
- falken a/t tires
- evo coilover suspension front and rear vs. rebel off road coilover front and rear??
- to those who know about winches ????
- 2 door windjammer on a 4 door??????
- Body Lift Help!
- rear trackbar bracket hitting bumpstop
- Cost to powdercoat your wheels?
- Scored a free AEV tire carrier!
- Which tire comes closest the size claims by the manufacturer?
- When do you need brakeline extensions
- Lower control arms JJ joint on both ends better?
- Which 37in tire for mud and clay?
- Difference in height 4 dr sport springs vs 4dr rubi
- Will this fit?
- sanding bedliner?
- So what’s the point of Bikini top?
- vibration/wobble...help needed
- Rear trackbar bracket issue
- warrior outer cowl cover reviews
- Duplicolor bedliner on floor?
- Superchips Flashpac for 2011
- re-balance Front shaft ?
- LoD rear bumper
- Need help with tires
- Backspace question
- Need help with 6inch lift????
- Need help deciding on tires
- Lod or Rock Hard stubby??
- Poison spyder brawler lite with brawler bar-- where's the best price?
- Flowmaster or cobra 75?
- 33x12.5R16 on stock rim
- 35" spare - need a wheel spacer or mount ext or both??
- Quick tire Question
- Widesest 35 on stock Rubi Rims with stock flares and no rubbing
- Programmers question.
- Anybody out there running coil overs on the front only?
- 5.13s and 35s with a 6 speed?
- Mopar "rock crawler" front bumper question
- Winches - how much do you REALLY need?
- after putting a lift in
- Body Armor bumpers - opinions?
- Stock to 37s
- Calling all Rugged Ridge Flat Flares Owners
- Running Toyota (6 lug) alloys on wrangler
- How to "beef up" my drivetrain
- Offset Backspace Conversion
- muffler for jk
- 2.5" Front Spring Install Problem
- Who's running a lift & 35's on an auto 3.73 geared JK?
- newbie shock install
- AEV Ram Air question
- Aftermarket wheel center bore???
- Sway bar HELP!
- Essential armor?
- Tranny Cooler - Dealer Install Questions
- Body Armor Trail Doors on order
- volant snorkel
- Gobi Rack... best price?
- Will the Rear Tow Hook work with the Rugged Ridge Tube Bumpers?
- Will I regret 37s?
- Trektop NX
- Question about powdercoating PS Brawler light front bumper
- tuning with flash paqs?
- OK, What's the deal with driveline vibrations, need super tech!
- Question about tires?
- Drop down Tailgate Conversion
- Help with tire size!
- I'm going with 4.56's...assuming I can find them
- Those with Tuffy Security Deck?
- LOD Gen 3 Rear Tire Carrier - SHORTY LINKED??
- Does anybody have this kit?
- Who makes the best control arms?
- JKU Trektop NX manual is posted
- Can anyone answer a tire question?
- Smittybilt XRC armor with Snorkel?
- Pinch Seem How to?
- Lessons learned while modding (warning---long post)
- Pick everyones brain...
- my 3 link bump stop question?
- Help!!! regarding a 3" Suspension System with Full Flex Arms vs one with out ?!?!?
