View Full Version : Modified JK Tech
- shock direction.
- want to buy this regear package form Northridge, is it a good regear kit?
- G-Force, Flashpaq, or Procal
- Rocker armor
- Rock guard for my radiator
- Flashpaq or Procal
- Duel Exhaust H-pipe search. :/
- factory rim on xrc rear bumper tire carrier
- Diablo tuner
- bolt on flat fender?
- D30 Nitro Sleeves install help
- Building a Lift-EVO Plush Ride 3"
- Cut front bumper
- 2012 jk rubicon unlimited
- I really need regear ...
- 12' soft top on an 08'?
- Sahara Unlimited, AEV 2 inch spacer and Bilstein
- Coil spacers?
- can i hear from owners of pro comp 9000 shocks....
- help : choosing an affordable tire carrier to run 35s
- Another 2.5 lift question sorry
- question for curiosity
- AEV Coil Spacer Question?
- 4" lift
- Best lift kit?
- Warn M800 solenoid mount bolt/nut size?
- How is this for a roof rack!!!!
- Rough Country 2.5 suspension
- Genright
- after marker JK rear bumper
- New '13 rubicon Lift advice needed
- Need advice
- Has anyone made some DIY quick disconnects?
- Help Needed Caster/Adjustable LCA settings
- Suspension: Am i missing anything?
- mounting gas / jerry can
- What Lift Springs?
- Question about offset wheels
- did you install prorock axle yourself?
- New RUBICON!
- 2013 Horrible ride after lift
- Rear tow hitch question:
- wheel and tire shopping location?
- Rear bumper/tire carriers that fit 40's- expedition 1????
- Diablosport Tuner vs regear for 2011 JK?
- Shocked at the difference my lift made!!!
- Guardian Tracker?
- Budget boost no up travel
- studdering in 1st gear???
- Bestop Trektop nx instal help!
- need a gear expert
- lift kit
- Looking for a winch line rock guard
- Just replaced ball joints...... Need some help!!
- Axle Truss or Sleeves?
- Rubicon Express 3.5" Superflex Question
- Suggestions for tires...
- Nj jeepers.
- back in market for 3.5" lift for 4door rubi
- 8 lug front wheel bearings?
- How to properly meeasure tires
- seat covers
- ARB bumper and 37" tires, any rubbing?
- Front end clunk
- Currie steering, Currectlync
- Bumper Painting - unanswered question
- Under $100 Christmas list suggestions
- What do you think ? After alignment.
- Help: Adding axle sleeves
- PSC Brawler Lite vs. EVO 1/4
- Modified JK weight
- Lift questions, anything I may be overlooking?
- TeraFlex Tech: Choosing a lift for your JK.
- Dynomax P/N 39523 (2012)
- BF Goodrich All-Terrain 275/70/18 Tires - 2010 Jeep Wrangler Unlimited Sahara PSI
- Air Locker question
- 18 inch vs 17 inch
- Track Bar, do i need one?
- smittybilt xrc bumper rattle
- Viper Throttle Body....
- Looking for local 4x4 shop
- Why no 4:1 kit for non Rubi t-case???
- Rubi Shock Upgrade
- Wheel spacers
- Homemade tire carrier build
- Rock Hard rear bumper tire carrier install question
- Seat Heater Question
- Artec Axle Armor Truss- Does it help?
- Rubicon E-locker ?
- Fender flares
- Troubleshooting Axle Leak
- Body lift
- Cusom stubby stinger bumper.
- Best all terrian tire for Louisiana
- Dynomax EVO Competition #39516 '07-'11 for 4-Door only...?
- Opinions on Falken Wildpeak A/T
- New Jeep Wheel and Tire Questions
- Bumpers-Or-fab-PSC?
- Duratracs vs Fierce
- 3" AFE High Tuck Exhaust installed...
- Turninh Stock sahara rims to Altitude rims
- Help with tires
- Intake ?
- 2013 - 2007 spring question
- Baja MTZ Tire Pressure
- Bilstein stabilizer pulling to left
- JKU springs on a JK
- Tie bar performance question... Need a little help..
- 33 spare on stock carrier
- New Wheels/tires advice
- does anyone have experience of EVO 999$ gear promotion?
- Noise after teraflex lift
- Testing a locker/axle out of the Jeep
- Drive shaft question
- Need help understanding coil over benefits
- Choosing the right offroad tire.
- caster question
- Teraflex 2.5 coil lift?
- Will a ROCK HARD sport cage from an '08 JK fit into the newer 11-13 JKs?
- measuring tire height for procal
- Rock Krawler 3.5 and Synergy high steer Help!!
- Anyone with a Procal in Raleigh, NC?
- Arb deluxe vs rampage recovery front bumpers...
- Seeking for deal to get ox locker and regear package
- Regearing?!?!?!?!?
- Brake light is coming on randomly
- Trektop or Sunrider Softtop.....Which is best...
- Will a 2012 rear bumper fit my 2007?
- has anyone installed a VT muffler inline under the drivers seat area?
- 325/60r/20 beside stock JKR deep cherry.
- Can't decide on AEV Wheels
- Trailer hub, Wheel Spacer Question?
- Request: NITTO Trail Grappler K SPEC tires
- superchips flashpaq advanced tuning
- Home made power top hoist
- Opinions on MOPAR lift with Bilsteins??
- New member with a project in mind :D
- AEV snorkel & light bar help
- Many mods advice
- Super Swamper M16's
- Winch IN stock bumper
- Ball Joint Suggestions
- Vent Bellow Kit?
- Which roof rack?
- Where to buy......
- Blown passenger side airbag :-(
- PSC rocker knockers vs EVO sliders
- Tuffy JK Conceal Carry Security Drawer Question
- viair vs mv50? how do youguys think?
- Wanting to switch from 35's to 33's need advice!!
- Question about sleeves and axle shafts in a d30!
- Lift and alignment ?
- Help me pick the right lift for my needs...
- Anyone reset their JK ECU...
- viair 400c or 400p?
- painted sahara wheels
- Tire help!
- Best rear driveshaft for the $$$
- Paramount Restyling Bumpers
- looking to put a tf 2.5" spring lift w shocks on.
- getting a new front end any help?
- steering shimmy
- which is the best lift kit to fit 35"
- What rock rails/steps to go with??
- Replacing driveshaft really necessary
- Exhaust..Dynomax?
- Step bars need help!!!
- Horn Help !!!!!!
- 2.5'' bb lift shocks vs springs?
- Winch Help
- Tpms transfer
- rear bumnper for a body lift?
- Procomp AT xtrem vs DickCepek FCII vs MickeyThompson ATZ
- Anyone running 37s on stock jku
- Wobble at 55 MPH
- Northridge4x4.ca discount code !?!?anyone
- Rear window bar/seal
- double throw down front with bolt on coilovers in the rear????
- Procal question 101
- Got 2k to spend on suspension jeep noob any advice
- Mods
- Lift suggestions?
- Lift heights based on what type of JK!
- Help! What do I do?
- New wheels and tires vs stock rims and tires
- Wheel spacers, terraflex vs rough country
- 2.5 inch lift gave me 4 inches of lift. Should I be concerned?
- 2012 Onboard Air Selection
- Anyone running poison spider diff cover stock trackbar
- Mpg
- What beadlock wheels ??
- Is anyone running this muffler
- Replace or cover up door hinges?
- Rocker panel protection in four season areas?
- BF Goodrich AT or MT
- Has anyone taken on painting the jeep logo and screws on their mopar fuel cap?
- help. bought used tire/wheels. wont fit
- First jeep ever...what to do? What to do?
- DiabloSport
- about death valley off road trail
- Can I run 2.5 inch coils + 1inch spacer up front and 2.5 inch rear spacers?
- Death wobbel 2011 jeep jk please help
- Black Top/Bar wrap material
- 4" DD Lift Recomendations
- Looking for Rubi Rails
- dual SS brackets?
- If you could change one mod you did what would it be?
- Bilstein 24-158428 steering stabilizer ???
- How do youguys adjust tire pressure?
- Which is better : G2 or Superior Axle ? ...
- 2011 Wrangler Diablosport Tune?
- 26psi
- 2.5 tera flex vs 3 inch bds
- Rugged Ridge Throttle Body Spacer HELP!
- Plastic dipping factory rims
- Evo plush ride springs
- lift ?
- lifted
- 4" lift thinking of body lift
- Definitive steel v alloy v weight
- 2.5" RK rear sway bar links
- front bumper pics or ideas/recommendations
- Removing rear drive shaft
- Winch question.
- EVO Holiday Sale ?
- Lift question. Coils or pucks?
- Vacum Pump Relocation Install Question???
- drive shaft bolt torque
- Vent Window Replacement
- thoughts on RE 2.5 lift
- 5.38 Gears with 33's (Auto - Rubi D44's) - Bad Idea?
- Coilover question.
- rims
- Help with gears
- Black Grille
- Is this possible!?!?!?
- Sterring Stabilizer Recomendation
- Smittybilt XRC or ACE rock slider?
- Black friday sale going on now @ ajusa
- Rock Krawler, Pintler, and 285/75/17
- Sway links
- Need some pics
- 37s on a 15 in wheel possible?
- AEV high steer kit help
- Anyone running the RR XHD Bumper on 12 or 13?
- Best place to buy lift
- Vibrations in front end??
- Front bumper
- tire size
- Billstien Shock help please
