View Full Version : Modified JK Tech
- 265/75/16 on stock steelies now or save up for 285s with aftermarket wheels?
- TJ Seat in a JK???
- Question about superchips flashpaq.
- Tinted soft top windows
- Help with Lift Kit - Parts List
- SuperChips - DRL Fog Lights like ProCal
- 35's??
- Quick dumb question
- Stock Suspension
- 33"s or 34"
- procal question
- Any way to use 16.5 tires
- Just Clarifying
- Tire size and selection
- 31x10.50R15LT ?
- Rear swaybar disconnects needed?
- RR XHD tire carrier pin
- What is involved when installing a LSD?
- Those of You Runnin 1.25" Spacers
- Custom Roof Rack
- Can i fit 35's without spacers, which ones, regear????
- Rpm stumble motor cold
- Aftermarket gears VS Factory warranty
- which 33's??? or 35's
- Painting Polished Aluminum Wheels
- TF 2.5 inch lift vs. TF 3 inch coil lift
- anyone got these disco?
- SRC bumper upgrade to tire carrier?
- Headlight covers
- Need more POWER
- What springs provide smother ON ROAD drive Teraflex or Full traction??.
- afe performance package
- Rugged Ridge Seat Vests
- hmmmm plastic vs metal
- Whats needed for 2.5 Lift
- 2011 Rubicon is on its way!
- Questions About My Going to 35's Strategy
- Stock Wheel as a Spare???
- 3.8l cam
- Bushing issues w/rubicon express 4.5''
- Rock Krawler Pro 2.5 kit
- will this rub?
- Creaking from Passenger Side
- Adj. Control Arm. How much thread should be threaded?
- Diablo sport tuner
- Flat fender flares vs. Pocket fender flares
- Procal problem
- OME 2"/ TeraFlex 3"/or BDS 3"
- 1st set of replacement tires
- do i need a track bar??
- Which octane tune do you run?
- Wheel offset impact bumpsteer with 35" tires
- Wheel Size
- Getting my first mods done on Sunday
- Stock tirecarrier with 33's w/ poll
- Chrome Pro Comp wheels, can they last thru a Michigan winter?
- Rocker Guards without Steps?
- JKS Front Trackbar bracket Brace and Woods relocation bracket
- Rubbing?
- Questions on aluminum gauges and cutting
- Need a little help w/ rear control arms
- Rock Rails
- Did / do you use the stock tire carrier for your 35" spare?
- Problem with TeraFlex Rear Axle Track Bar Bracket
- What would you guys get for 400$?
- not sitting level ????
- Spare Tire Mount
- Dayton M/T's (anybody have experience with these)
- Rotors what's the difference??
- Stock drive shaft caused trans leak
- Quetion on lift......
- Tires rubbing on upper front spring bucket
- Firestone Destination MT
- For those thinking about using brake line brackets or extended braided lines.
- Tuner Chips??
- help with 2' lift
- 2008 Rubicon Wheels
- Teraflex LCA's broken zerks
- Tires
- Auto tranny pan
- off set tires
- Yes, another steering question
- Rugged Ridge tailgate jack mount?
- Aftermarket Cold Air Intake
- Reset AEV procal to new jeep
- SC, avoiding the pinging before install
- any tips or tricks to center frnt axle
- Question about pieced together 4-5" lift
- NEED HELP Choosing exhaust thinking about Flowmaster Super 44 Extreme off road
- Why choose a leveling kit vs. lift?
- How tall is your 4 drs JK with TERAFLEX 3” KIT and 35’s.
- steering question??
- superchip?
- 33's problems?
- Question - Shocks
- Almost ripped off my rear brake line.
- Yes, it's another lift question
- 35's, stock rims w/ wheel spacers, 2.5" RC lift, Teraflex quick discos.......
- Is it true...
- Advice needed regearing jk without overhauling kit.
- ESP/BAS/ABS Lights On and Off Randomly
- Benchmark Rear Winch Bumper?
- Flat Fenders: Wide or Narrow?
- Best 2" Lift for manual transmission
- Anyone running 2.5" Pro Comp on 15" wheels?
- Tire
- Help Please.
- Help with DIY gear swap. 3.21 to 4.88
- JK 2010 need only 8 body lift spacers !?
- warn winch problem question
- Bad Wheel Bearings?
- Tire Pressure Indicator acting up?
- Poison Syder Evap Skid
- Which winch to buy
- Am I crazy?
- teraflex leveling kit, still have rake
- looking for input on tires.
- Specific Lift Question--(I know a million threads but here we go)
- do bad ball joints make any noise?
- Running fast in the desert
- Pinch Welds?
- Getting new wheels
- NP242 in a JKU?
- XRC smitty built front bumper or Body Armor for Silver Sahara unlimited.
- Extra coverage flat flares
- Wheels: MB72 versus Pro Comp 7069... Fight!
- What is the best way to get rid of front rake?
- money and the decision.
- Rotation of Nitto Trail Grapplers- Learned my lesson the hard way!
- n00b backspaceing question
- What gear with 35's auto 4 drs. 5:13 or 4:88?
- PRESS RELEASE: Falken Wild Peak AT - They Get You Going! By Discount Tire
- Axle shaft swap...Help please
- Teraflex 6" lift height
- 35" Tire Carrier
- Help!!! newbie with delimma regarding 4" super lift kit
- Correct caster or perpendicular axle?
- Daystar Comfortride 3" Spacer Lift?????
- mod's
- Procomp trackbar? Alright?
- Best Spacers
- Wheel Spacers Bent Axle
- Rubicon Express front track bar and ARB diff cover?
- 285/75/17 installed: Seems to wander now!
- AEV ProCal / Gear Ratio Changes
- TF leveling kit and 3" spring lift???
- *Electronically Controlled Throttle*
- Noob beginner question on driveshaft and gearing.
- Been searching for Milage on goodyear wrangler Duratrac
- Rugged Ridge flat fender flares
- winch without cutting
- Under seat drawers Tuffy vs Bestop
- Tire and Wheel Shopping - Forum Member Discounts
- Adjustable Control Arm With Stock Rear Driveshaft
- gas tank skid
- Viair Super Duty Installation?
- 35 1250 17 or 18 Mud terrain tires needed, long life and low noise 99% street driven
- Welding washers on axle side track bar bracket hole to fix wallowing/ovaling?
- 345/75R16 KM2 fitment with flats and a bb?
- Brakes with currie D60s
- 37" km2s 6 sp and 5.13s speak up please
- Horns!
- OME LT lift upgread questions and problems
- can i add a winch onto my stockbumber?
- Tire sizes
- Instrument Panel light came on! What does it mean?!?
- Advantages of running 15" wheels (other than cost)?
- Ground Front Brake Calipers
- $150 What would you get
- 35 1250 18 vrs 325 65 18
- Warranty issues
- Tire/rim Size help
- about to install springs--what else am i missing
- Anyone replace thier stock front skid plate??
- Need help with flat flares
- Sahara Rims on Rubicon
- Viair 88p
- kore suspension 3.5'' off-road
- 3" Ultimate vs OME LT
- Are BBs ok?
- Steering wheel
- Brake pad POLL. For 37 inch tires.
- 6-speed mud in clutch fix
- Choosing a 35" (17" wheel) for Southern California
- Best Bikini/Bimini/Brief top???
- Adding spacers to coil lift.
- I knew I would crack
- Trans cooler question
- JKS Trackbar brace
- Rugged Ridge or Rampage soft top boot
- Lift Kit Install Questions.
- Ordering new 37's. Looking for recommendations!!!!
- going 37s whats the best al around tire.
- Line-X Doors?
- Body armor front bumper
- Front Bumper
- U-joints
- Ebay, suspension lifts....
- my steering stabilizer's busted
- Winch mount in stock bumper
- Some upgrade purchases I am considering for my 2008 jk unlimited Sahara need opinions
- Bad control arm bushing cause DW?
- Front Axle Universal Joints
- Gobi roof rack + tretop?
- Gearing for Flat Florida Driving! Need feedback
- Hard top chip? What to use
- Weird Rattle coming from front suspension after wheeling.....?
- Rugged Ridge Cat-Back exhaust
- 6-Spd Shifter bezel
- 4 black unlimited door shells
- Front Driveshaft Upgrade
- MBRP Black
- Why do I feel like I need a larger rear sway bar?
- What you think?
- Chrome or All Black Wheels on my Surf Blue????
- Rugged Ridge Winch
- Do i need flex arms with suspension lift?
- Need opinions on lifts for our jeeps (2 door)
- Temporary Rim for Spare Tire?
- Alignment specs for modified Jeep (if ever in Keene, don't use Cheshire Tire)
- wheels and tires
- OX Locker
- steering geometry
- Coil Spring Off?
- Who's running a Hub Conversion?
- waterproof rear storage with Tuffy lid?
- Too soon to tune?
- Question for Gobi roof rack owners
- Rugged Ridge Bumpers Paint Chipping?
- Evap canister relocation, gascap code
- Installing axle sleeves
- I need a copy of Superchips instructions Please
- Rugged Ridge Xtreme Heavy Duty Tire Carrier Mount
- Body lift Vs. Suspension Lift
- Wheel Fitment -R 20in Rockstar w/Nitto Mud Grapplers 33x12.5x20
- what causes steering wheel to off center?
- if no access to a lift, what can use to support the jeep at frame
- body armor
- help on lift kits
- Rock ring/rim protector for DC-2 wheel
- Is 5/16" close enough when centering the axle?
- Anyone with a 6 spd, 33" tires and 4.88 gears?
- Stock 2010 Sahara 18" Wheels... wanna put 35"'s on and lift
- Duratrac tread life ?
- ION Alloys
- Spring Retainer Clips
- looking to lift my 4dr jk 3''! is BDS a good lift kit? any suggestions?
- teraflex control arms on a 2.5 inch coil lift?
- superchip
- diff oil in engine compartment
