View Full Version : Modified JK Tech
- Method Beadlocks? What beadlocks are you running?
- Getting 33" tires and want to disable my tpms light
- General Grabber Red Letter
- 4 Arm vs 8 Arm Lift Kits
- LoD Bumpers
- Anyone running a 3" lift on a 2dr?
- Power Soft Top!
- EVO NoLimits Manual Rubicon Swaybar Disconnect
- abs issues after wheeling
- 2012 Full Traction question
- Spacers vs. New coils
- Fabtec 3" Lift with 35"
- 2012 Unlimited - may need to run 37's with 3.73 gears for awhile - Input please
- Stock sway bar e-disco vs. after market sway bar disco questions
- 2.5" TF lift w/ spacers???
- Snow season is upon us, how are you hauling skis and snowboard?
- Soft top disconnects-any DIY?
- What size lift to get?
- Coming up on 60,000 miles. Any tips for maintenance?
- 90lbs of tire/wheel on factory spare location
- Opinions or suggestions on rear shocks
- Where are you guy getting the best deals on your winch's
- Who here runs dedicated winter tires with their 4" or bigger lift?
- 33" spare stock set up.
- TPMS Service Kit
- Shock install
- Re-gear pricing
- Cig lighter plug doesnt work
- What has already been done?
- Clicking sound when turning...advice?
- Rock Sliders that is mounted to the body?
- TF 2.5 lift question
- Overland AND over Rocks
- Jeep Emblem
- River Raider Short Snorkel -- Check it out! What do you think?
- Is anyone running the new XRC M.O.D. bumper.
- RR 4-5" ORV lift W/o shocks- Any thoughts on better schocks than what RR provides?
- Rough Country 3.5" lift
- Suspension question on Teraflex lift
- Terraflex performance leveling kit?
- N-Fab step bars
- Gears and programmer?
- tires for a 2012 rubi with 3.5 rock crawler la
- Body Armor roof rack
- Gear breaking period towing
- How to mount jack on hood?
- Serious Flaw in Rugged Ridge locking gas cap cover, Gas fire explosion predicted
- Fox Shock Feedback
- High lift jack moumted on vehicle
- Installing a Ripp Gen1 Supercharger kit
- What are all my options?
- Mopar rock rails?
- Help with tires
- 35'S No lift?
- Tearing Drive shaft boot!
- ORE Coil system, why lift?
- Black AEV Pintlers?
- What gears?
- Have questions regarding a build, need help!!!
- Breaking Tough Tire Beads - BeadBuster
- Best Fastback Softop?
- Balll Joint Installation -- Axle Shaft Question and Other Concerns....
- Best Soft Top
- Seat covers and dogs?
- Learning parts and what mods i have
- Anyone Running RIPP Log Tube Headers with a Long Arm Lift?
- How can we protect the windshield? (I have an idea)
- XRC Winch installed, What is common path for Cables???
- Front bumper design
- Am i being short sighted
- Need Help - Wrangler Unlimited - Dual Exhaust
- Bent Axle Housing? Advice Please - Alignment Pic Included
- Looking for 3.5" to 4" of lift for ground clearance.
- confused !! help me decide what to go for please !
- Beadlocks on Daily driver?
- Installed MV50 issues
- help choosing what direction would be the best way to start
- front bumper / airbags
- gear/tire size and lift
- Grinding noises
- rust problems
- what rims are these
- Larger Tires or Stronger Sidewall? -------- (DW Related)
- 315/75 R16 on stock steel wheels
- First post - mag light holder
- Driveshaft which one ????
- Rear tube bumper pics
- lastest mods done
- What wheels are these....
- Longest time running a 35 on the stock carrier...
- 4.88 gears or 5.13 gears?
- How do i found out gear ratio on pinion and ring
- Let's say I wanted more flex (droop)
- Teraflex 2.5 budget boost questions
- Coil lift + leveling kit???
- MBRP Exhaust JK 2011
- Exhaust mod gone bad.
- Brake pads
- Teraflex 3" vs Full Traction 3"
- Aussie Locker in Dana 30
- Which suspension setup
- Good bumper an winch combo?
- lift s
- Manual hemi
- 2012 ProCal and TPMS
- Anyone running the Rampage Marathon Bumper Smooth Black???
- Steerring Sensitive after OME Lift
- Sahara side steps versus rock sliders
- Rocker armor question
- how to mount beadlocks? and what psi
- JK rear coil issues
- What wheels are these?
- is it possible to do this setup !? tell me what do you think !!
- wheel help!
- torque question
- Jeepers Block
- Biggest Tires for 2012 2.73 DD?
- Anyone running the RK BFH rear bumper with an OR-Fab tire carrier?
- Quick question before trigger pull on TF 2.5" Lift
- Disable TPMS & Flash for hardtop installation (defrost, wiper)
- slight whistling upon deacceleration after regear?
- Wheel size and backspacing question - 35" tires
- painting steering components?
- 33" Replacement for my Grabber AT 2's
- Bedlining exterior parts question
- Rake correction after bumper add and lift?
- Rugged Ridge Front Skid Plate issue
- LT 295/70r17 or LT 285/75r17 with No Lift or No Spacers
- Which Spacer?
- TereFlex 3" Long Arm Kit & RIPP Mod Long Tube Headers
- 2012 lift ?
- Your experiences with gears and mpg
- 1/2" spacers.
- $.02 needed on bumper color
- Modified Rocker Side Armor OR-Fab or PSC
- 38x13x17 geolandar on stock rims
- Buyer Beware!!! Olympic 4x4 Products Xtreme Double Slider Bars
- Pro Comp back orders
- Quick decision
- AEV Pro Cal, tire size and speedo question
- gas hatch cover?
- Is there any difference between 4Door and 2Door Shocks?
- Snorkel with Cool Intake system or Snorkel only
- Cheapest tire carrier / rear bumper that will support a 37
- Please clear the air on lifts?
- Intergrated tire carriers
- Suspension and lift kits system And Speed
- rear bumper without tire carrier
- Superchip Installed
- Rear Drive Shaft Recommendations
- Anyone Running a BDS Lift?
- Advice requested regarding Wheel/Tire setup
- Gibson exhaust
- 2'' or 2.5'' bb on 33'' tires.....pics please!
- Dodge Ram 1500 diff/tubes/axle swap?
- Proper jack/stands to install a lift
- Centerforce dual friction vs spec stage 2+
- Switching from half doors to full size doors w/ power locks and windows
- dyna beads
- Cracked Header
- Airaid CAI or back to stock?
- Is 2010 ecu plug and play to 2011 JK ?
- Teraflex 2.5 coil lift. Are UCA or LCA needed?
- Bumpstop extensions needed?
- Anyone install a catback or different muffler on their 2012 yet?
- Choosing lift kit! What do i look for
- Hyline skid plate compatible with RR XHD???
- From a BB to Springs
- Can a 33x12.5 r17 tire be ran on a stock jku with wheels that have 4.75 back spacing?
- oe flange driveshafts.....not good enough??
- Some rubbing going on
- Pulled electrical connector on Front Locker - doh!
- 55k Mileage Maintenance Check List
- Poison Spyder Rock Brawler Front Bumper
- i bit of help, been decieved by sales person, just noticed now... after almost 2 year
- Tire weight difference
- Dynomax VT
- Mopar FRONT OFFROAD BUMPER with fog loights
- Issues/opinions about the Mopar 2 inch lift with unlimited X
- Help me choose!!!
- Mopar Off Road Bumper Tire Carrier Owners?
- E-Autogrilles bumpers on e-bay
- 09 Drag Link question
- 4 Dr Steering Box in a 2 Dr?
- Traction control problem?
- Different Rear Tire Carrier
- Wheels for 2012 Sahara
- JE Reel yokes with Coast Rear shaft?
- Front axle
- What is the deal with Duratrac???
- Alternative for aftermarket bumper and a 35" spare tire carrier
- Removing Powder Coat?
- Teraflex 2.5 coil lift/wheel clearance?
- Help !!! AEV Snorkel - AEV Heat Reduction Hood what after market Fenders - Photos ???
- UK front bumper stubby ?
- AEV Snorkel option........opinions please
- Puma 12v 1HP air compressor- anyone have one?
- Gearing question?
- Smitty Stinger
- Full traction 6" long arm system
- ShrockWorks Bumpers
- Anyone use a Proclip mount in their 2011+ interior?
- Any suggestions for a heavy duty steering stabilizer?
- Having probs regearing
- Blizzaks or Wrangler Aauthority for winter?
- Jam nuts?
- Choices...
- Intakes
- Electronic Sway Bar indicator light???
- Rock krawler 2.5 lift
- hieght comaprison: TF 2.5" BB VS TF 2.5" coil lift
- removing rear driveshaft question
- new lift, very squeaky
- How much damage did i do?
- Does anyone here know if the plastic windows off a 2 door 2010 sun rider soft top
- Drag link flip
- Stock JK Re-Gear... anyone done it?
- diff fluid on axle c
- Red Springs PIC
- Newb here need tire advice. Wanting to swap out mudders.
- Will this work on the street?
- Walker Evan Beadlock look-a-like?
- drop pitman arm for 3" lift
- K&N Performance Kit vs. Suerpchips Flashpaq
- Power Steering Failure Right Side Only
- Adjustable track bar...no relocation bracket
- 32 inch tires
- Non-brake related squeak.
- Winch and car wash?
- driving with front driveshaft only/4 hi question
- rockrails with steps for 4door
- tire milage
- Loud Clattering Noise When Under Stress
- Advice needed: Steering wheel shake, but not Death Wobble..???
- Command trac NV241 GII
- help need the link to the cut and fold front stubbie
- what else do i need
- Or-Fab tire carrier
- Rotopax spare tire mount
- Front trackbar needed?
- Transmission temp sensor NEED HELP!
- Double checking!!
- New Bumper By Vendor: Link to thread?
- What kind of hi lift...
- Poison spyder
- Ripp Mods Gen II blower surge
- Can you use superchips AND pro cal at the same time?
- Error Code after Ripp Gen 2 install
