View Full Version : Modified JK Tech
- Freshly Lifted '14 JKU
- Opinions for 35" tire
- Steering Issue- Not safe, need help
- SS Relo bracket for Currie Rock Jock Lift?
- 2012 JK 3rd row
- Jacking from the diffs bad?
- bump stop length
- cant decide on a lift- need help
- Comparing 2010 2011 and 2015
- one ton swap question gm14 bolt
- Ripp superchargering a jk with 75k
- rubicon express lift
- Analyzing options for front axle, gearing and lockers
- Dynomax EVO Comp Exhaust
- 08 Unlimited Front Body Mount Replacements
- Looking for a shop to do my gussets and sleeves
- Sway Bar Nut Size
- Universal shift knob adapter not fitting correctly
- new bestop trektop pro!
- 2011 DOT tires
- Can anyone help me decide which wheel spacers to run on my Jk?
- Rear Quarter Panel Cracking
- while doing gears, need advice on gussets, trussets, and/or sleeves
- TrailDash vs. FlashPaq
- LoD Rear Bumper question
- Rubicon JKU springs for 2dr jk
- Which is REALLY larger? GYWrangler MTR 305/70-17 or Mickey Thompson MTZ 315/70-17
- Axle Seals - Which do you like or does it matter?
- SMS Wiring Harness Install
- Undercoating metal flares question - when painting body match color
- Flashpaq,Flashcal Alternative
- Help me find the right shock tower bushings
- Changing spacers to coils
- Tires for mi jeep
- Need help, heated seat question
- tire options
- Heated seat install question
- Is it cast iron?
- Steel or aluminum poison spyder flares
- What 15in wheels work on JKU?
- Anyone w/ 37s & 4.5BS in LA Willing to Let Me Check Fitment?
- Hood Lock ... Yes? No?
- shops near southwestern pa
- Clockspring help
- Synergy Tie Rod Ends
- New Clutch?
- Which LED Tail Lights?
- Insulation
- Time for an upgrade?
- Truss with 2 1/2" lift
- Wheel question
- 37s vs 38s
- Will it rub?
- 12.5 or 13.5
- Exhaust Loop Delete
- Build vs buy a new jk
- Monstaliner? Anyone use this?
- Any one have info on Orion 300W 50" LED Work Light Bar?
- Does anyone have a 40 in their cab?
- Exhaust loop skid
- Rugged Ridge door hinges - Wasted money???
- Rolling resistance
- Single line breather tube extensions like River Raider, contamination?
- Swaybar Disconnect park bracket issues...
- Replacing stock door hinges on 08 JK Unlimited
- 2015 2dr Rubicon rear drive shaft change?
- Modified Front Bumper. Please help.
- Superchips Flashpaq
- Suggested price of somewhat modded jeep..
- Hard Rock tire carrier options
- Ball Joints
- Popping in frontend?
- Whats yalls reccomended under armor/skids?
- JKU gets teraD60 and bedline YETI
- Bestsuspension upgrade for washboard roads
- Whats the best tool for triming factory flares?
- JKUR10A annoyances: caster, heated seats, ride harshness. need input.
- Rocker knockers frame or body mount?
- Rotten egg smell
- Removing bushings to powder coat suspension parts
- Wheel help
- Help with my weekend project. teraflex 2.5 BB
- Custom Windshield Decal
- Need new driveshafts?
- Flashcal - Taking it into dealer - Code P0730 - Automatic
- Beefing up front axle along with other stuff
- Tyger side step/nerf bars
- smittybilt oversized tire carrier with teraflex hinged carrier
- 14 Billet Silver JKUR Build
- 2Dr Rear Seat Removed... Where to store it?
- Front D44 pinion
- Flashcal 3570 unlocking question
- Mounting Viair Air Tank
- Trouble changing stock bulbs to led's.
- New Gear Ratios
- Bushwacker flares with Rugged Ridge Inner Fender Liners....
- Louder?
- Replacing with Rubicon Shocks
- Gauges
- wheel offset question
- Superchips Vs Procal
- Rock Hard 4x4 3RD Row / Accessory Mount Sport Cage for Jeep Wrangler JK 4DR?
- Rustys 3.25"??
- arb stubby bumper
- Modified w Mag SC any computer fixes
- Doors need adjusting after body lift?
- Doors off-Hardtop on?
- Axle flange bent possibly -- Need advice after crash
- Anyone have these Walker Evans wheels?
- Does Anybody here have a Device to Turn of My ESP? (Los Angeles)
- Sterling 10.5 questions
- Will I need a lift?
- Need small lift advice
- Opinions on rock lights
- Exhaust question
- Whats are they?
- Headlight bucket replaceable?
- Magnuson Supercharger Tech Questions
- How many o2 sensors does the 3.6 have?
- Crashed- steering box info?
- 3.5 inch lift
- ARB rear locker, Rubi fornt locker, Co2 Tank, and spod. I'm lost...
- MPG with 2.5 lift
- Why wont this work for a 3.6L
- Spyderlock wheels
- New control arms
- Rock jock 60 and rock krawler lift
- ProComp 1069 Aluminum Wheels (Centercap - Polishing ??)
- How do I know what Gearing I have??
- Engine swap
- Tire Weight List?
- Rear Axle Bump Stop
- Welder in Tallahassee FL
- tranny cooler
- wheel spacers safe?
- Steering stabilizer
- Total vehicle height with 2.5 RK and 35" Trail Grapplers...need some help.
- 1/4 pounder front JK bumper by EVO MFG
- Lowest price on Trektop NX
- Removing coolant from radiator
- What did you do with OLD Exhaust?
- 3.8 super charger with snorkel?
- Need help with 3.5" Rubicon Express stdrd lift and pinion angles/contol arm lengths
- Rock Krawler lower rear control arm question for 2.5 X-Factor kits
- Duratrac 325/65R18 vs stock Sahara tire height
- who is running 35's with out a lift?
- answer this please because I am confused
- Will i need to re gear
- Teraflex Hi-lift Jack Replacement Parts
- Fox 2.0 SS went poof
- Blown Head Gasket
- JK tire upgrade
- Sway bar disconnected bent
- Seahawk special edition
- 15" wheel issues on 2015
- Thoughts on the Eibach
- Kargo Master Congo Cage?
- Centerforce flywheel
- 35'' tires I can't chose!!!
- Regearing whoes... :tantrum:
- Fog light pig tail
- Adding Bestop Element Door Enclosures to soft doors
- Questions regarding lift
- Warn m8000 winch plate for poison spyder bfh
- I killed my 2015
- 2015 jku brakes line ? After coil over
- Rancho 9000/Synergy Rear Shock Brackets
- lugging and hesitation issue. AHHH!!!!
- Front housing..
- Do I have a lift?
- Recommended 2.5" lifts?
- new to building and have backspacing question
- blow rear, what to upgrade
- Barricade Roof Rack for a 2015 Jeep Rubicon 4 door
- Pro comp lifts
- OME piece together
- what lockers to run? dana 30 up front and dana 44 in rear.
- Pro Comp MT's
- BFG KO2 How do they perform?
- Light bar hood deflector thing
- Lift recommendation
- Rancho RS9000 Shock Remote Control System Display Bulb ????
- Help ripp supercharger
- Color choice!!!
- Axle Upgrade Questions
- New build - PSC fitment experiences
- Spongy brakes after wheeling this weekend
- Those with D60's
- A shout out to RIPP Superchargers
- Ripp supercharger question
- 3.5" or 3.75" Backspacing - Thoughts
- Questions on labor hours so I don't get ripped off
- Misfire? at idle, but no engine codes
- Hawse Fairlead with Prolink Thimble & Front License Plate
- Tire wear
- recommendation for a back bumper
- Tinting soft top windows?
- Question about front support beam?
- Overlanding with a Rubi, opinions on gusseting?
- Muffler too close too frame?
- best bumper for under 500 bucks
- transfer case front half
- ESP is all out of whack
- Backup camera ?
- 2014 Jeep Wrangler Jk
- joe diesel bumper?
- transmission issue or misfire? no CEL or codes
- Soft Top Replacments
- Best Springs for the road
- Latest minor mod
- Clayton 3.5 coils or Eibach 3.5 coils?
- Radiator for 5.7 hemi
- PS rocker knockers question
- Oil Tank Skid recommendations
- Aftermarket performance
- 37" difference
- DynoMax Rebates ??
- Another Opinion needed thread
- Whirring noise with 5.13 G2 gears installed
- Different ways to calc tire pressure
- anyone use these mirror relocation brackets?
- Brake light on dash?
- NOOB ALERT--- General Lift Questions
- Vibration at 60+
- Toe adjustment
- Is slight "bump steer" normal?
- Warn Winch vs Smittybilt
- FOX ATS Warning!
- Stubby mod to factory bumper
- How high are your fenders?
- Aftermarket Bumper Without Lift?
- gear size vs rpm plotted on graph for 3.8 auto
- Issues with 2" Rancho sport lift with 9000xl shocks
- Can I plasti-dip the part behind the wheel caps?
- 4.56 with 33's for 3.6 Manual
- ProComp Lift Quality
- Poison Spyder Fail
- 2015 freedom wheels question
- Is the superchips flashpaq worth the money?
- Biting the bullet
- Can anyone recommend a shop in SE Michigan for gear swap?
- Rock-Trac NV241 or 4.56??
- Diablo Intune verus Diablo Predator w/ Ripp Long-Tubes
- Steering Help!!!
- Spacer or Suspension Lift?
- Too Old To Modify??
- What brake pads to go with Teraflex Big Rotor Kit ?
- Rear trackbar problem
- Chasing demons
- will this lift work??
