View Full Version : Modified JK Tech
- time to start the build
- PSI 33inch Duratrac's
- Backordered Kevlars?
- Tera BB w/ Rubi Springs and Shocks on an X
- Finally........
- 1 3/4 lift kit
- Anyone using the Rock Krawler wedges and JKS spring reatiner??
- 37's or 40's on a 9k budget?
- Spare tire security
- Bent Tie Rod - Best replacement option?
- Euro diesel, and gearing
- Gibson or Rugged Ridge exhaust
- 11.5" D or 12.5" E Tire for 17x9 Wheel on 2 Door?
- Backspacing on AEV Savegre wheels?
- Tire weight question....
- airaid intake check engine light ?
- 4.88s and 33s on a 6 speed 2dr?
- Locker front or rear?
- ox brand lockers:good or bad
- Here's my goal. How do I get there? ('10 2-door Sport)
- Back Again . . . need suggestions!
- Lift & Tires
- case spreader
- MBRP Windshield light bar-SUPER windy, any solutions?
- What size spacers?
- wheels
- Steering Issue Resolved
- Aussie facts
- Aev snorkel
- Control Arms Upgrades
- Power Steering Binding? Loss of Power during Offroading
- FYI on Superchips and TPMS disable
- CatBack and relocated muffler ?
- Rugged Ridge Huge D Rings
- offset number for the AEV 17x8.5 Pintler Wheel?
- it finally happened--i got broken into..
- Problem about the 37" tire
- Cheap-O seat covers
- Tire Upgrade?
- interior mounted cargo basket
- 4:1 Kit for a JK?
- Shittybilt rocker guards
- how to stop Sway bar from extending over center?
- Cold Air Intake on the Cheap using stock airbox
- 4.10 from a Rubicon in my X
- Shocks with this lift.
- Ripp / Codes Help needed Asap
- MOdifying Smittybilt C•RES to be windproof
- Rugged Ridge Mirror Relocation Bracket Install
- JK Build and now it's time for a Bumper
- Angry eyes?
- Fuel Cap: Drake Billet or Mopar Door
- Level Kit + 4 Tires
- Which bikini top??
- Trany temp gauge
- Aev nth degree or teraflex which is better d/d ?
- Lift BB for 2dr with 33" tires
- Advice
- '08 Rubi BBlift
- undercoating?
- Cooper STT actual diameter
- E - Rated Tires
- Tire choice, advice?
- HELP! Lift installed, FUNNY NOISES!
- bigger tires questions ???
- Rubicon Express 3.5" lift height
- AEV Pro Cal Module Quick Reference Guide---I NEED IT ASAP PLEEEZE!
- Squeaking noise when I turn the steering wheel to the left...
- TF 2.5 lift-no disconnect-driveline problems?
- Newbie-Help
- Xenon Step Down Flares
- Ripps super charger dyno numbers
- superchips & 6 speed
- Note: for lifts on new 2010 JK's
- Is there a good wielder in So Cal?
- Smittybilt SRC rock rail install
- looking for inexpensive black wheels
- Need help determining best wheel backspacing
- Deceased shake...
- oil pressure gauge help
- Picking a front bumper
- Is this for REAL -- How to adjust a Trackbar?
- Advice on the smittybilt xrc rear bumper and tire carrier
- Kaymar Rear Bumper
- How stiff are the MTR Kevlar?
- I'm torn between?
- steering stabilizer
- D60s, 8x6.5s
- help por favor
- 35's on Jk...How much lift?
- 33x10.5x15 BFG AT T/A tires on 15" black MB72 alloy wheels
- How reliable is Line-x
- Accessory mount on left side of Radio?
- What size Trailer Hitch??
- Cragar Soft 8s 15" or 16" - Advice
- can i run this ??
- Superchips?
- can anyone tell me if its supposed to click like this???
- Rough Country 2.2 Shock BROKEN!!
- ESP with new tires.
- Another TeraFlex 2.5" BB W/ Shocks Q.
- Any Trackbars You Like in Particular?
- High Output Alernator
- Welp, it finally happend. busted DS boot. need information please
- need advice - phase I build - 33s, leveling kit
- lookin for pics of 33x13.5 15's
- Is 4.5" bs. -12 offset ok for stock jk
- Auburn Ected Locker, Whos running it?
- Will any D44 30 Spline locker work?
- Gibson's Performance Headers
- Teraflex BB or winch?
- 2.5 BB installed, some question..
- Strange Tire Wear Problem
- gears and intstallation
- 2010 JK: Are 265/75R16 BFG A/T KO okay on stock 16x7 rim?
- What is the difference from suspension
- Buying my first lift kit need help!!!!
- dynatrac ball joints
- "Strange" vibration at speed
- Another Newbie Question
- 4" rough country
- Looking for info on "Monstaliner?"
- Installed Hypertech Max Energy 2010 JK Review
- Death wobble
- Who has a 2 door Ruby with...
- GOOD 35s FOR ON AND OFF ROAD??
- Some lift questions, appreciate the help
- 18" Stock Wheel Question
- BPE's in OME shocks!!
- Rubicon express bb rough ride
- sway bar disconnects
- anyone removed silver bumper trim on Sahara?
- Wheel & Tire Help...
- New Clunk Sound at low speed/turn
- I Need Help With Wheels
- Body Armor Extreme Rock Rails
- Mud flaps for off-road bumper
- axle U-joints and ball joints shot
- 4dr Rubi>2dr X
- 2DR Rubi Axles into Unlimited X?
- Lift Kit and stock rims?
- Tire change from Mud to Highway
- adding BB to lift kit
- pitbull maddogs
- Wheel Spacer = Evil ?
- Evap replace cost
- Hella Twin Supertone Mod
- Rubicon 3.5" standard or what lift around 1,000.00
- enigine code PO13a o2 sensor / with ripp supercharger?
- Smittybilt XRC Armor Corner Guards JK
- whats everyone favorite steel corner guards?
- Procomp Series 51 R15 ANYONE???
- M.O.R.E. Rear Bumper/Carrier?
- EVO Gusset Install Question
- Driveshaft's ????
- Bestop - Extendatrunk for the 4 door unlimited!!!
- Airaid Intake
- Tire PSI?
- Clearing 37's
- Rampage Rear Sport Rack questions
- all the different 3" TF lifts make my head hurt
- tera flex lifts
- Bodylift with Smitty Rock Rails
- Looking for a good rock Rail...
- Mopar Tire Carrier
- 4dr Rubi Build questions? going to 37's
- newb question? Teraflex or BB?
- should I regear??
- Quik Release for Kargo Master Kongo Cage?
- Nitto ballance issue
- Help me make a decision
- How will 4.88's effect me?
- Tire suggestions? Help!
- Anybody got info on the Yukon Zip air lockers?
- pro comp extreme alloys 8069 anyone running them
- 37" tires for street??
- Homemade snorkel
- Control Arm Bushings-DW
- Review on Olympic A/t Rock Rails
- Upgrading Axles for under a grand help?
- Factory rubicon wheels with 35" tires
- Front LCA bracket
- 5.13 gears 6spd 34 inch tires review and information
- IS this the Trak LoK LSD?
- AEV bumper touch up and alternate wrinkle paints...
- Lift decisions for the layman?
- Unlimited Rubi Rail Question....
- Aeroforce & Normal Operating Temps?
- Leaking Rough Country shocks?
- E-locker
- Alignment needed with new trackbars ?
- Lift install first....35's second?
- Which Gears 4.88 or 5.13
- PowerTank vs. Warn PowerPlant
- Thinsulate Top liners
- rugged ridge modular bumper
- 33's
- Mopar relocation brackets vs Rugged Ridge
- I just installed 33's and she wobbles
- [B][U]I just installed 33's and she wobbles[/U][/B]
- protection for my bottom side!
- 1/2 inch spacer transimission skid plate?
- really want to lose my spacers...
- rear pinion seal keeps dying - anyone had similar?
- Need pix of the Bestop instatrunk
- Tail gate cover
- performance chips????????
- fender flare plastic
- Difficulty on installing 2.5 inh teraflex Coil lift with shocks
- Teraflex Leveling vs 2.5 lift
- arb long ranger?
- Magnaflow Exhaust?
- 37in questions??!!!
- 2.5 TF coil lift ... 4.7 backspacing ?
- Looking for HELP!! Please. FRONT END ISSUES.
- Thicker rear sway?
- everytime i go 4wheeling my steering is jacked
- CAI and Snorkel
- Just installed unichip programer
- 2010 Rubicon 4dr with Budget Boost?
- JK X D44 and Rubi 44 Locker
- Adjustable front track bar
- Superlift adjustable track bar - need some help...
- Determining if my lockers are working...
- What is the backspacing
- Dust caps & Coast DS's...
- from 19 to 12 mpg...Is something wrong?
- What lockers are your running?
- What to do next?
- Front lower control arm bracket
- Poison Spyder Body Armor
- TeraFlex HD Track bar
- Factory LSD?
- superchips issue?
- Dumb mistakes made wrenching (eg. changing diff covers)
- Will this work?
- yes another regear question
- 5.13 gears question
- Best riding 3.5in lift for daily driving? Runnin 35's
- LoD front bumper with smaller stinger
- Where to start?
- 4" lift
- Aftermarket Plug wires
- rock hard cage
- Suspension Help
- Toyo Open Country MT vs Goodyear MTR Kevlar
- Wheel spacers & bumpstops
- aev snorkel w windshield lights ,mopar brackets
- Bilstein or RE?
