View Full Version : Modified JK Tech
- Windjammer
- Toyo Open Country M/T 37x14.50x15 question.....
- Shocks for Everyday Road Travel
- Is my caster low evough to need adjustable LCa's
- 35/12.5-17 or 315 /70 -17's on Stock Rubicon Wheels?
- Dont fear the Gear!!!!
- Advice, advice, and more advice, ANY is welcome!
- Setting Caster Angle on 3-Link
- Tire size question???
- fan upgrade
- Used dana44, regearing and tires?
- Rear Sway Bar - Rough Country lift - What to replace it with?
- Cant make up my mind of differential fluids! Help!
- Any issues running 40's?
- does tire height or weight have more impact on mpg's?
- Aftermarket Front Winch Bumper with front hitch
- Height of AEV snorkel
- Install time for Rugged Ridge bumper
- 5.13 or 5.38 (High Altitude)
- Teraflex 2.5 issue?
- lift on backorder. Will 34's fit with spacers?
- MT Classic II vs. AEV Argent Pintler 17" wheel
- Tailgate damage
- 1.5" Coil Spring Lift for 2dr???
- 2" Spacer Lift + PSC Crusher Flares = 35" tires?
- Why has my Procal stopped working?
- Head lights
- Toyo MT 35s: what PSI for the road?
- Skiier dude needs help
- 18'' wheels (discontinued) with matching 17'' spare (available)? Feedback please.
- Terraflex Budget boost
- Another tire/wheel thread. help JK
- Whats your take on WARN 12,000 lbs PowerPlant Dual Force HD?
- Cragar Wheels
- Will they Rub? Will they stick out?
- AmRac Crawl wheels
- Need assistance with u-joint install!
- Will control arms fix flighty steering?
- Fuel Consumption
- MBRP XP series "off road" cat back
- 2dr, 3.21 gears, 2.5 BB Lift, Stock 17" wheels and 33's
- Is it easy to remove the AEV snorkel?
- 3rd brake light
- Who makes this rack?
- random question .....
- Hmmm .... bent C or bad ball joint ???
- 6" lift kit
- Choosing a body lift
- Sway bar quick disconnect
- Synthetic winch lines in Winter???
- question about power steering reservoir from PSC
- First Death Wobble Experience
- Auto, 35s, 513s and NOW the Superchip
- 4 door rubicon springs
- Lift/Tires/Gear Advice?
- Electric windows, cetral lock and remote start
- What to do for 33's
- Looking for 15x10 wheels with 3.25 bs
- Can u sleeve a slightly bent axle housing?
- AEV Snorkel through car wash?
- New 08 JK 4" Lift help...please
- Manual Shifter knob
- Tell me what you think...
- Capped Rear Frame Rails
- Wanna see my shaft??
- WHY doesnt someone make B Pilar armor, or "C pilar" add on bars)??
- trans pan
- Upgrading Wheels
- Price on bushwacker flat fenders
- Are 315 70 17 duratracks noticably smaller than most 35 1250 17 tires?
- ORE sliders VS. Waranty?
- Rancho Lift Warning AND also Death Wobble prevention
- Mopar Windshield Light Mounting Brackets On RHD CRD?
- Winch issue
- is this a good idea
- 6 inch long arm pro comp
- Roll cage tire carrier
- Aev 4.5" premium or rc 6" x-series, which do i need??????
- 315 70 17 on 7.5" wide moab
- aev front control arm drop brackets
- Anyone know of a reputable soft top liner vendor???
- Snorkel with Benchmark Dual Battery Setup
- Alignment needed or not...???
- Backspacing question
- Aussie Lockers in the front, what in the back?
- Towing a 2009 JK
- MTR's
- Battery Upgrade
- Off Road Heroes Soft Top Liner
- 315/70/R17 Duratracs - what are you running for pressure
- Steering Stabilizer upgrade
- tire question. ive searched with no luck.
- Ring & pinion installation manual
- Finally made up my mind on a lift
- Wondering if this setup will work...
- what should be my first mods?
- Psi question
- Front and rear bumpers, what has to do to the jk to hold all the extra weight
- MBRP roof rack Clearance?
- Rattling Tailgate
- Looking for 3" coils
- I got $500.00 bucks for spending my stock JK, now what?
- which tires???
- bumper relocation brackets
- What does it take to put a TJ front bumper on a JK?
- Where to get exhaust installed?
- Winch is installed however ....
- 37" on a sahara unlimited auto
- Magnetic angle finder sway bar links!
- Chrome wheels winter salt comming soon to michigan
- 35" tires again (DuraTrac, Wrangler MT/R, Cooper STT, Nitto, KM2...)
- Lift and ESP
- Short Arms v. Long Arms on Unlimiteds
- Anyone used Lizard Skin for sound deadining???
- Rancho 4" Long Arm ??
- Mtr kevlars?...
- Welding in Muffler? or Better Idea?
- Rugged ridge wheels
- Will I need spacers for 305/70R17 stock rims?
- I need help please, stuck on an install
- dog barrier
- Heights from Lifts
- RCV axle shafts
- Ottawa Ontario
- Front brake install--help
- Pro Comp wheels
- another one
- adjustable control arms
- Bushwacker flats install time
- procomp mud terrains 35 1250 17 any good? blem sale $875 set shipped
- Bushwacker Pocket flare
- Steering clunk noise, I think... Someone describe it please...
- Evap relocation
- Full Traction M Force shocks
- Need Some Help
- TPMS - Do I need 4 or 5?
- What r the best All-terrains
- What I plan to get for a lift and tires. What size spacer do I need?
- New Member Sayin Hi And Sharing His Dream
- Anyone running the xrc fenders?
- Running Stock Rims AND Tires on Teraflex lift
- Are the ARB Diff covers worth it?
- HELP Question about ProCal and TPMS
- steering warranty
- 3.21 to 4.88 Difference in off road performance?
- Tire balancing media
- Valve stems
- why are some lifts made 2dr or 4dr some both
- 33" tires on stock sahara rims?
- Body Armor 59 in front triple hoop bumper/ORFAB rear rock slider bumper
- 2011 Superchips - January at best
- Front Drive Shaft Busted?
- Ziptieing T-case lever
- i want to buy bestop soft top, anyone have one? need comment
- can a Superchip tuner shut off TPMS?
- Is anybody running 305/65r17's?
- More Mods ordered / scheduled ... I think that SHOULD do it ....
- What gas cans are you using with your OR-FAB tire/can carrier?
- buy shocks or save for a new lift?
- DW Please help!
- Anyone running the Mopar 4" lift?
- Snorkel?
- would this work?
- what would be safe to do??
- 2.5 Rock Krawler lift, now have a flighty feel when driving.
- need help with extended brake lines...!!!
- Question on Teraflex C Gussets
- BFG AT/KO's
- Changing out front trackbar and lower control arms?
- O.M.E. or Bilsteins?????????
- Vigorous Wobble
- Which coils for increased weight?
- [B]How about Duratrac -vs- Cooper ST(T/C) (your thoughts)[/B]
- TF Level kit & 305's w/ spacers???
- 3"LA vs 3"SA ~ 1st hand experience wanted
- Rustoleum Rubberized Hardtop?
- Lod rear bumper towing
- Track bar brace bracket mount
- Look out DuraTrac's....
- Any aftermarket solution to get rid of this panel?!
- EVO Armor Rock Sliders - Do They function as a Step?
- 38" MT/R's just arrived... Need axle advice.
- question on ARB locker o-rings
- Ways to reduce mud splash under the hood?
- Rubicon Express 3.5in Standard HELP!!!
- Driveshaft / Trackbar / Control Arms Questions
- Tires and gravel roads. Recommendations?
- 4 pin Eaton Elocker for D44?
- Any Issues Mixing BB with Coil Lift?
- Spidertrax / Removel
- Running without inner-fenders?
- tires on stock x
- 33x12.5 on Rubi rim?
- Smittybilt Front Stinger
- How to lift?
- Lift installed with new 35's
- Duratrac vs KM2
- Mopar lift kits?
- Mopar Off Road Front Bumper D-Ring Replacement
- Question for Superwinch LP10000 Owners
- TEraflex 2.5 bb HELP!
- Removing MORE 1" BL
- Can't find...Detroit Trutrac LS for Dana 30
- Tpms
- can i still use my rollor fairlead
- Masterflow 1050 or 10# CO2 Tank?
- Question about stock tires, new rims, and new tires
- Toyo AT or GoodYear DuraTrac?
- New Tires...HELP!!
- POLL: Those with 35's,Bent, not Bent, or don't know if you bent your front axle?
- Complete Lift to run 35s with stock-like on-road ride/feel
- Who has Atomic axles? What do you think and are they worth the coin?
- Any have Rock Krawler Suspension? (vs. Teraflex)?
- Need help after putting on a 8274
- Installed a Yellowtop Battery, worked fine for a day, now jeep wont start
- Educate me on the ome +40 lift...
- Traded in my Cherokee SRT8 for a 2010 Wrangler unlimited
- Gussets and sleeves for 35"s?
- Installing a Steering Dampener/Stabilizer
- bumper and air bags
- How much did your rear end sag after installing a rear bumper?
- steering shaft help
- Ball joints=death wobble?
- Mickey Tompson Wheels
- performance chip
- Front Drive Shaft problem
- Can I put a 9" wide wheel on the stock rubicon tires? Need help quick!
- 15" Pro Comp 1069
- 255/80/17's and Spacers
- Anyone here chipped their 2.8 CRD?
- RC 2.5" Coil LIft or Rustys 2" Basic Lift
- ideas for rear license plate relocation
- What skid plate to protect my electric disco
- Old Man Emu Lift
- Front sway bar connector idea.
- No Lift, 33's? Possible? PLEASE REPLYYYY!
- Needs specification of Old Man Emu Long travel Shock
- Pink Accessories?
- drop pitman
- Why has the aftermarket not come out with a steering box brace yet?
- Which Program would you use with a 6 Speed Manual
- 2 door auto lift ?
- AEM CAI install help: IAT wire tension
- do i need a leveling kit
- is this a good deal?
- Tire pressure sensor
- Bilstein 5100 or Rancho RS9000XL for rear replacements 3.5 lift unlimited
- Rear Bumper????
- Spacers + 4 inch lift?
