View Full Version : Modified JK Tech
- Rock Knob
- PRESS RELEASE: Full-Traction Suspension Radius Arm Rescue & Geometry Correction Kit
- will my stock drive shafts last
- Dynamat Xtreme My Doors
- Chop Fender question...
- need steering stabilizer?
- Tire Question
- 37's on stock rubi axles?
- Anyone have 40" km2's?
- Smokin' hot brake rotor!!
- Mud Grapplers or Terra Grapplers?
- moving rear axle back/regaining wheel base
- Disabling Tire pressure system
- What would you do with $300-400 and a brand new 2011?
- Wheels 17x9 or 16x8
- Transer Case Arm
- Which lift to get??
- Winch mount question
- Mopar off road bumper with winch??
- 1000 Dolla now what?
- front axle breather hose
- 37s vs 38s
- help me decide: lod stinger vs rugged ridge xhd + stinger
- Calling all XHD bumper owners, how are they holding up???
- traction control still going off on turns
- Question about my 4.88 gears...Please Help!
- Anyone have the Dynomax VT muffler on?
- Any difference in rubicon unlimited and sahara unlimited springs
- Hood laches
- Front track bar brace?
- Dash Lights still Coming on after lift install HELP!
- Thoughts on OR-Fab Bumpers.
- rear pionion angle help
- Question.. Instrument Cluster...
- Soft top question....
- c gussets and control arm skids
- Replacing Bumper Myself - Advice 4 the Noob
- Anothet tail gate debate
- Or Fab tire carrier write up: where to find?
- Rear axleshaft removal
- Need help with converting tire size to "metric"
- How much lift with stock driveshafts
- Detroit trutracs
- Suspension/Tire Size Question
- Teraflex Jeep question about backspacing
- Check valves on breathers
- Transfer case bracket
- What should I do??????
- XHD bumper broken right out of the box? Are these foglight pins bad?
- Will 35's and 5.38's pose any issues?
- Question regarding new lift and tires
- I have the superchips ping!
- Can't make up my mind on a bumper
- Rough country bb/1.5'' spidertrax wheel spacers
- Rugged ridge light bar and winch mount
- Super Swamper IROK radials
- Teraflex Shocks
- Suspension Question?
- Castle nuts bettet than nylock nuts?
- Clutch Install
- Evap skid paint?
- Question on steering
- In 2011 what is the final word on the evap canister, move or skid?
- Tire Choice
- Pavement ends bumpers?!
- Front lower control arms after installing lift
- Rubi Crawler question?
- hypertech programer
- Clayton vs. Rock Krawler
- Modding back bumper into stuby is it possible ?
- Anyone have Rampage tail light guards?
- How Bad Will A Ruggid Ridge XHD bumper make me sag?
- Duratrac tires white letter or BSW?
- dual or single steering stabalizer for 35's
- Upgrading the tires with a lift/ ANY HELP?
- Is this wheel too wide for stock tires???
- dana 44 axel sleeve?
- what size leveling kit
- Temporary spare tire spacer
- A little concerned about 5.13 gears with my 37s...
- Has Anyone installed Crown brakelines?
- Front bumper
- drive shaft grease
- Best bang for my buck suspension lift kit!!!! That fits 37s!!!!
- Extender the shifter
- 5.38s or 5.13 for an auto on 37s?
- Finalizing the lift... want opinions
- 33s or 35s on a 2-Door?
- Am i right?... For a newbie
- has anyone used this tuner
- Best after market ball joints Trying to fix the off Camber stockers..
- quick help....
- Pinion Seals
- Relocated evap rattling tub
- TPI in new wheels
- CHange of plans for now. Putting on spacers.
- Alignment results left me with a questionable recommendation.
- Best 37 for an 18" rim
- Need help regarding CAI
- heavy tire on stock tire carrier
- Top off ???
- Black Rock 909 wheels
- 2.5" Lift Help
- Where can I buy RR Wheels and Duratacks as a package?
- What's Next?
- Factory Rake LOOK is back
- Benchmark Oil pan install
- 2" BB questions
- Cam bolt determination
- Tom Woods DS install?
- Just finished 2.5" Lift, steering problems.
- What kind of grease fitting is this?
- Best for stock 2011 2dr Rubi.
- help asap! how do i measure the trackbar!
- Teraflex Performance Leveling Kit
- underbody armor suggestion
- need opions on bumper
- 2.5 lift rims and tires?
- Gears - Reviews, Thoughts and Comments
- Expedition One Basic DX - Foggy Options
- Tire Carrier Latch Help
- Teraflex leveling kit
- Seat covers
- Cam Bolt Kit, Help
- Locker Questions. Please help
- height of Gobi stealth rack?
- Exhaust??
- Anyone here run 35s on 3.73?
- Traction control on my j.k.
- Nitto mud grappler
- JK 6 speed popping out of gear resolution!
- Smitty Built XRC Rear Bumper- Official Bumper Latch Fix (Drum Roll Please!!!)
- Teraflex 2.5 coils vs the Rock Krawler coils
- drivers seat mod
- Death Wobble
- Anyone runs 35/12.5/15 BFG tires?
- lift recommendations
- Adjustable Lower Control Arms Question
- Help! Tire carrier advice.
- Warrior-Stubby Front Rock Crawler Bumper
- passenger tire toed out?
- Which tune to try next?
- Bestop Instatrunk or .............what???
- Anyone ever install a rear battery?
- Currie HD tie rod??
- Anyone else runing a fumoto oil drain valve?
- UPS is on the way with rock krawler 2.5" Kit... Questions
- disconnects
- leveling kit + bigger tires=Steering issue
- What upgrades should be done first ?
- Transfer case bushing
- muffler relocation question
- Single or dual steering stabilizer ?
- 1" Lift in Front
- 2.5" Teraflex coil lift install problem
- procal and tpms
- Bushwacker Trail Armor
- Question on ProRock 44
- Tire question
- Teraflex 2.5" Coil Lift Questions
- Pics Please Location where you put your compressor for ARB.
- All wheel spacers the same?€
- Turning a RC 3.25 kit into a 4 inch kit by changing spacers?
- Glass pack (cherry bomb) = p.o.s???
- Mud spray on doors
- Shock Extenders
- most reasonable exhaust
- New gas mileage?
- teraflex leveling kit
- Rough Country Tube Bumper Tow Points
- Usable Body Lift
- American Outlaw Buckshot wheels anyone?
- At what point do you need to raise track bar?
- rear upper trailing arm recomendations ?
- 3.5" lift, spacers, 37s, nothing else. Can I drive it 2 street miles to the shop?
- Steering Help Please
- stubby front bumper
- Help/Advice On Rear Dana 44 Differential Fluid Level
- I am sooo strong out about my lift choice!
- Broken Body Bolt! Any Help!?
- Rubicon Locker/ESP Mod
- Spacer lift/ electric sway bar
- Spacer or Spring Leveling Kit
- Ripp Gen2 Supercharger Symptoms, any help?
- Should I upgrade the exhaust ?
- Rugged Ridge Light Bar experiences and uses
- Running 37's on budget
- Hemi Owners
- Noob Question: What is a C-Gusset
- Soft top support brackets
- Ordering New DriveShaft-Do I need to measure?
- Decisons,decisions....
- 3" or 4" lift??
- Black Rhino Wheels Question
- Decisions Decisions....
- trying to mount a high lift jack to after market tire gate
- Flashpaq TPMS disable
- Black steel rims pics please
- Purejeep Rocker guards
- Need help Teraflex 2.5" lift w/ shocks
- Anyone regret 35s?
- db Performance Exhaust
- Opinions on BFG, Goodyear, Mickey Thompson tires.
- My 3" Suspension and 35" tires go on this week. What should I do next?
- Best tire size
- Rear control arms
- Which is lighter?
- help with Duratracks
- 37's on Stock Moab Wheels....Whats needed?
- Driveshaft replacement?
- Want to upgrade a Pro Comp 2.5" coil lift with track bar brackets
- Tire Help
- thinking about what wheels to get.....
- Alignment pro needed
- JK X swap to JKU Rubi shock and coils plus a TF level kit questions....
- Hood Buffeting help
- Pure Jeep rear bumper--tire carrier is seized up
- Front Bumper Mod - Skid Plate Necessary?
- Rear bumper
- Rear bumper
- Lift choice assistance - feedback needed
- Brake light relocation, buying 35's
- olympic boa bumper pics
- C or D rated tires
- Black and Silver 16" Wheels
- Looking to lift 2.5 - 3"s....
- Axle cleaner
- Teraflex Drag Link Flip Kit/frame brace help
- Trail Mods removeable flares
- Situation Duratrac
- Steering Wheel doesn't line up after JKS Track bar add..??
- Trektop Rear Window Help
- Spacers with 37's??
- will they rub?
- LoD Front Bumper?
- Backspacing on wheels? Any help?
- Will the Adjustable MX6 or RS9000XL shock give a softer ride than...
- Rear Driveshaft throwing grease?
- Teraflex Front control arm lenghts??
- Is it ok to remove inner fenders?
- Steering wheel esp dance help
- T.W. D.S. Silicone?
- 2010 Soft Top
- RC Adjustable Control Arms
- A Jeep and A Floor Jack
- Rubicon Take-offs or 285/70/17
- Wheel and tire weight
- GF performance chip GFORCE
- 4" BDS or 3.5" AEV Premium?
