View Full Version : Modified JK Tech
- Opinion on SRC side armor
- Just finished installing my new lift and 35" tires/wheels.... DEATH WOBBLE!!!
- Installing driveshaft
- can spend $200 per tire.. but which one?
- BROKE Somethin
- Rear DS replacement JKU...what a PITA
- Front skid plate
- Rear trabar
- Rugged Ridge - Air Box Clamps
- Stinger/Winch question
- are we sure no ds with 2"leveling kit
- 37's and 3.25 Lift Issues
- Need help from tire/wheel guys PLEASE!!!
- Help installing Currie's rear coil spring retainer kit
- SPYDER "XRC Style" Front Bumper
- Working Today-Need Help-Teraflex Quick Disconnects
- Roof rack road noise
- Hex driver to remove hardtop
- tire and wheel question
- I need new bumpstops
- Shrockworks front bumper HELP!!!!!!
- Painting Plastic !?
- HELP.. SHOCKS locally
- jk hd hinged carrier
- adj front lower LCA's, Rock Krawler or Tera Flex?
- Is this installation OK?
- 40 inch tires in stock d44 rubicon axles?
- More flex.
- Lift Kit Question
- Need your opinion
- new jk
- Modifying Rubicon Rear
- Just ordered...
- Tires
- JK adj front LCA's length for 3" lift?
- Steering problems after lift
- I need a new front Bumoer.. Any Ideas or Suggestions?? 12 rubi..
- Assuming....
- Thanks Ripp
- Installed 2" Budget boost and now have check engine light
- BDS 3" Lift w/Fox shocks
- Military trailer hitch question
- magnuson super charger
- adjustable rear trackbar question
- swaybar end links?
- It rained in my jeep. Time to bedline what's the best kind?
- Am i crazy.
- 16" vs 17" wheels?
- Do I need new shocks?
- Finally going for a real lift, but which/how
- Tires
- rock sliders
- Who's brake line extensions are there at 4:41 of the video?
- AEV Procal - Gear Ratio
- RE 7123 3-1/2" super flex kit
- How to spend money?
- Spider Gears are shot!!
- PS Brawler Lite- winch plate/engo
- EVO vs Teraflex??
- Shock install
- Tire Selection with AEV Pintlers and 2.5 inch AEV Lift
- 1310 driveshafts
- aev procal?
- Aev snorkel
- optimal gearing with motor replacement
- Cabin Winch controls ??
- Proper location of Stabilizer tie rod clamp.
- Gear/tire size opinions
- NOOB: control arms
- 285/70R17 on Stock Tires - No Rub???
- Death Wobble and bushings ..HELP!!!
- what type of jerry can??
- Gut the interior?
- Tailgate doesnt lock with fob after Teraflex HD hinged carrier install
- Which Gear Choose for 4.88
- Locked rear diff on daily driver?
- Stock isolators
- Need Help on Tires and Rims for Stock 2dr Wrangler
- Getting rid of the frot rake
- Spidertrax wheel spacer question
- Falken Mud Terrain updates?
- Regearing for 35s
- sup rack????
- Full Traction lifts products etc ANY GOOD
- Snorkel with CAI???
- Looking for a bumper......any suggestion?
- Starting with Tires...but how big
- Which gear?!?
- Moto Metal 961 w/-24mm offset
- Longer screws for windshield?
- side rail rust question
- Swapping front bb to springs!
- Jack Question - What do I need?
- 2013 JKU Rubicon .......Comment On My Build!!!!
- Welding to the frame, anything i need to know
- teraflex Level 285/65/18
- Drop in air filter
- Smittybilt Tire Carrier
- Drop Pitman Arm Taboo
- Flexing! question!
- Will you run 38.5 tires?
- get excited....another wheel/tire question
- Thule gutter rack height
- Side airbags
- Problems staying ON the highway
- Xenon fog light bulbs
- Riddler diff covers
- New front DS needed?
- Silver JKUs with Savegres
- Bedliner Prep Question
- Offset qusetion
- beadlocks?
- Rear bumper and tire carrier recomendations
- Front shock removal
- Door check???
- JKS Almost touching Coils
- (rear control arm kits upper and lower) alighnment on a zone 4" suspension lift
- Cold air intake
- 35x12.5x17 Dunlop Fierce Attitude vs. Mickey Thompson Baja MTZ which to pick??
- Coil Spring flex?
- bedliner to avoid
- First Mod--New Tires...but which ones?
- Engo winch with and AEV bumper
- How big of a tire can i fit on this?
- Replacing Jack...
- Extra Fire Power kit for the 3.8L
- Front castor?
- Buying my new tires and wheels today, question though
- Help with lift
- My 35 inch Toyos are C rated??? What psi should i run?
- '12 JK Vacuum Pump Relocation
- traction control light after flip kit install??
- First $1,500 to spend on 07 Rubi JK, what to do first?
- Anyone else waiting on orders from Quadratec?
- Stop Theif!!! Drop that HiLift Jack!
- Wheel Choices and Backspace options for Cosmos Blue 2012 - Need Opinions
- Can I attach a lap belt to these seat fittings?
- Lossing the front rake on lift after winch/bumber
- somebody give me a exact advice.. about tire size and lift
- Improve AC performance
- Plowing
- dealer installed or self installed?
- 4.5" AEV and DW after a year.
- Led dome light not working
- Lift and tire questions
- Painting d rings
- Looking for a 16x8 wheel with more than 5" of backspacing
- DANA 60's and the ol' 3.8L
- Looking for snorkel thoughts and opinions!
- coil spacer lift question.
- Coax cable help!!!!
- Goodyear Duratrac - Nationwide Backorder
- Need suggestions for a cheap set of mirrors!
- pro comp 8179, what should I pay?
- Front DS / 5" Lift / 6 Speed Manual
- What's the 'best' lift for highway driving on 35s ?
- Trac bar
- Tire pressure
- Cooper Discoverer ST Maxx
- Rear bump stops - Please help
- Design Ideas
- Help needed, gas can holder...
- ok nitto trail grappler!
- 285/70/17 with stock Rubicon setup?
- New modifications for a newbie
- Guys, got my first winch and it doesn't sound right
- Lower Control Arm Bolt Nightmare, Need Advice.
- '12 Rubi...what gears??
- Ring and pinion gearing
- Help:Which chip works best for a 2008 JK
- Grab handles
- TF Performance vs Budget Leveling Kit
- Tire sensors
- about tire weight
- I can't wait next wednesday..
- AEV RS kit versus Rancho Sport
- On board air compressor
- please help with teraflex BB!!!!
- Window handle question
- lift kit
- Drive shaft, exhaust, or both with 3.5" lift kit?
- 255/75/17 what other tires sizes will fit to replace this size.
- Newbie wants a suspension lift
- Need help securing harley mirror
- Which kit, and why?
- Help please
- Rancho Rear Off-Road Bumper with tire carrier??????
- Tire size with 4" lift
- Help! Teraflex Noise
- Tire questionq
- Dongle anyone?
- Sprint booster light flickering
- Ultra Wheels "Crusher"
- Questions on Forced Induction
- Steering Wheel Revolutions....question???
- 2013 power programer
- Bug screen for JK like old TJ CJ screens
- Airaid cold air intake
- Rock Krawler HD Drag Link with 2.5" lift
- Best 34-35" commuting on road tire
- Teraflex Flex Arms worth It????
- Control arm mount....Bent it...
- drive shaft rubs on the oil/trans skid
- 2.5 roughcountry coil lift.
- tire size
- Need Intrl; 4" lift on JKU
- Drive shaft trailer coupler
- Stock exhaust system
- tires
- Help with next mod
- Brake Pedal Vibration
- Need Help WIth Wheel/Tire Package Selection
- evo extreme high clearance long arm kit question
- Snorkel question.
- Thoughts on Skyjacker suspension lifts
- HELP!! Traction Control light flashes!
- Headers?
- Improving towing capabilities.....
- Control arm choices
- Who Carries Toyo Open Country Tires?
- ACE rail installation problem -- help
- Is this death wobble?
- Driveshaft length
- Lift and drive shaft question
- Rotopax Storage Packs
- Install party?
- Squeking noise under front dash
- Hub rings
- 35" tires, 2.5 aev lift, what backspacing i need?
- 2wd to 4wd Conversion ?
- 315/75r16 on 16x8 bs 4 7/8 question...
- Can i get a question answered quick about 2012 exhaust
- Difference between Rancho RS5000 and RS9000XL
- New Coast driveshaft NEW leak too? help!
- How can I make this center cap?
- ordered centerforce clutch kit.. what throwout bearing?
- Air Pressure
- Taking springs out
- Pics requested: expedition one basic dx front bumper
- Cutting stock fender flares
- 5x5 to 5x4.5 adapters
- Paint or Line-X rock rails?
- Warn VR10000 and Rugged Ridge XRC w/Overloop
- 3rd Brake Light Relocation
- Rock krawler bumper cap
- Speedometer and GPS speed
- 4.75 backspacing question
- RC LCA lengths
- Front bumper
- Opinions on a 35" spare on stock mount/tailgate with spacers
