View Full Version : Modified JK Tech
- help for those making decisions
- Steering Stabilizer And Wide Tires
- MPG Question
- Who makes this bumper?
- an Idea... how possiable is this?
- Tire height
- Tuffy JK Unlimited Security Deck Question
- 5:13 or 4:88 gears 4 Door Jeep JK
- Question about suspension lift....
- lifetime powertrain waranty
- For you Vets, better choice shocks for lifted jeeps?
- mopar 4lo kit for np241
- How much rear bumper sag?
- Just installed TF leveling kit on unlimited...now what?
- 2.5" Lift coil/shock help!
- another question on gearing.. please help
- A little question about tire offset
- Muffler Q..Magnaflow
- Another Bumper Question
- Finishline west rear carrier
- Newbie needs advice from vets on winch/bumper purchase!
- Can I use air springs as an adjustable lift?
- Caster with 4" lift and 31" tires
- Lift problem
- more rearend problems, this time bearings
- Track Bar Brace
- No lift help!
- Hey Rancho
- No Lift 35"
- 3" TF coil lift vs. "2.5 coil lift w/ 1" BL
- 37's without re-gearing
- track bar mount re-enforcement
- Help me pick a rear bumper
- Bumper Recommendations?
- daystar 1.75 level kit.
- Radiator fan problem
- Mesh Bikini TOP???? Bestop or Rampage?
- remove wheel spacers, now DW
- Rubicon Express Drag Link
- Advice on more lift and clearance
- Did I just FUBAR my tranny??? HELP!!!
- Baja style build.
- Rubicon switches for sway bar, lockers, esp, and hazards
- Need help with Coils for JK.
- what mpg for lift and tires?
- Rusty lift parts
- Front Axle fluid capacity with Riddler cover
- Plastic Push-On Retainers for Plastic Trim
- Diff Bolt missing?
- Best Frame & Body Mounted Sliders with ORE EVO Armor + Flares
- 35x12.50 on stock Rubi wheels w/o spacers?
- 35's on 3.21 gears?
- PureJeep Rear Tire Carrier High-Lift and Shovel Mount
- front receiver on a bumper possibilties
- Which is better: hub centric or lug centric wheels?
- Bushwacker Painted Fender Flares
- I'm So Over These Flares.....
- Rock Hard 4x4 Full Width Bumper?
- How far to 35s on 4.5" backspacing stick out?
- A quick way to improve premature ESP eja......
- How Long Should It Take???
- Trouble Adding Fuel after Evap Can Relocation
- Herculiner questions...
- new rear driveshaft necessary?
- Mile Marker SI12000 Electric Winch
- What to do ??
- Spare tire carrier question
- Which 3" lift kit?!?!
- EVO rock Slider question
- Added tranny cooler - Where do I put the oil?
- Door Jerry Can Mount
- Double the rear cargo on a 4-door JK using modified Bestop cargo basket + brackets.
- Am I correct on my gear ratio?
- 35's
- Evo Rock Star Skids
- how good is this lift /
- Too Hot on Inside -no carpet
- Tailpipe Routing Suggestions - Relocated Muffler
- Windshield lights and mirror relocation?
- Who here has damaged their stock muffler?
- Clicking noise coming from front of jeep
- Dana 44
- Appropriate way to put JK on stands
- Control arms
- Expedition One Front Bumper?
- HD tie rod and steering question..
- JK Netting question...
- Winch: Smitty XRC-8 or XRC-10?
- 4 inch suspension or 3inch with spacer
- Teraflex 2.5 Alignment question
- New Guy
- Floor Jack
- too soon to change diff fluid?
- No drill frame without rack?
- Going Right down the road
- Rubi locker and air locker
- 24' rims on lifted jk?
- help with steering stabilizer crushing shock
- 180 degree thermostat
- 4" Rough Country Suspension
- Knocked the steering out?
- procomp 7005
- superchips flashpaq worth the extra $$$
- Finally Lifted my jeep!! need help!!
- Need LIFT or SPACERS? i need help
- Speedo correction options
- Ideal Tire Pressure for Freeway
- Rubi E-Locker DIED
- Need spacer?
- Non aggressive Larger tire?
- Got a problem with my lug nuts
- Hypertech Max Energy
- Help!!
- New tires for road trip... or wait?
- Fox racing stabilizer
- Installing new lift
- Teraflex upper CA right and left?
- Another TF3" question
- JK Rubi with 16'' rims?
- Vent in tailgate?
- LoD Rear Bumper Bolt Size
- 34s with 3/4" lift?
- Hitch/wiring install
- Does your kit sit like this????
- Fathers Day present
- Vibration in tranny tunnel on bumps?
- Lets talk arms..
- stock 4.10 gears
- parking break beat because of tires
- Newbie with a million questions... and I've searched
- Best top safari, windjammer, and deck cover questions
- FlowMaster 44 (or 40) versus 50
- Rugged Ridge HXD/Superwinch EPI 9.0 Don't seem to like each other.
- big tires on stock rims?
- RIPP Supercharger Install
- Destination A/T on Stock rims
- Fastest and easiest Soft Top
- Home Made Extended Sway Bar Links
- Nitto Grapplers A/T vs. BFG M/T
- New Tires and wheels
- JKS adjustable coil over spacers
- Show me winch wiring routing please
- gauges for you jeep...
- 2" Lift
- Remove seats for herc liner really?
- What 15" Beadlocks fit over calipers?
- Leveling question
- My new (used) BFG's
- problem with compass after winch install?
- Lower Control Arms (front)- Clayton vs. JKS
- Solve Rubbing Issues? Lift or Spacers?
- Max Life Kit (pucks) on JK Unlimited
- LoD Rear Bumper and Towing??
- Tire Pressure 325/65/R18.. 35x13.50
- EVO Double Throw Down suspension front and rear
- MORE tube fenders?
- Teraflex Leveiing kit question.
- Torque wrench question
- drive line chatter
- Pics stock 2dr rubicon with 3-4 inch lift
- hey big question guys
- Another Suspension Question
- Need help with tires!!!!!!!!!!!!
- Wheel and Tire Deal Yea or Nay?
- Removing spare issues....
- Help asap!!!
- 33's on Stock 16" Aluminum Wheels
- swapping driveshafts, 2dr
- rescue green painted lod front bumper??
- Please Help with backspacing?
- More Trektop header WOEs
- BDS 3 inch Kit adding on
- Spidertrax VS Teraflex - wheel spacer's
- Help with Muffler... Throaty Sound
- LINEX cargo area only?
- Wheel and Tire Help
- AEV fron bumper install time?
- Tie Rod ends?
- Big Difference between RC 2.5 coil and budget?
- AEV Build
- What wheel is this?
- MT/R balancing problems?
- 20's on 2 dr
- Thinking of making an internal snorkel. Anyone done this?
- R.R. Rear Bumper
- What to spend this cash on?
- Carpet mod? Pull matting?
- Bent Tie rod again, help
- Flowmaster 80, SI/DO or SI/SO
- 2.5 lift and 35's?
- Dunlop Rover M/T Maxx Traction
- Don't hate me: Stock X with 2.5 AND Rubi Unltd Takeoffs?
- Teraflex Leveling lift
- Daystar Install
- Smittybuilt XRC 8000
- Can anybody ID this pic?
- thoughts on wheel adapters?
- Help me get more lift...coil spacers?
- Paint Job Question
- Rancho Long Arm lift.
- Tires on stock wheels
- Lunchbox locker options
- What size front coil spacers would you recommend?
- Help - looking for 16x8 alum wheels 5" backspacing
- Castor Issues?
- Need a solution for knobs door surround
- My rubi is now on Superchips and loving it!
- Has anyone got rid of the paint and used Durabak? Pictures?
- Need pic of rancho ss
- Tire selection...Need help.
- Brands for 5.38 gears?
- Full Traction 2" econo lift installed
- Linex coming TUESDAY! Prep pics...
- Pro comp wheels
- TJ Coils on a JK?
- Sanding factory fenders ?
- AEV Front bumper grille....paint or not?
- Erg position sensor circuit high (po4o6)
- Mod:Fender chop on a sahara?
- Trying to find a good deal on procomp wheels and mickey thompson tires
- teraflex not level need ideas
- pinion nut problems on rear
- new driveshafts. need adj control arms??
- ACOS installed
- TeraFlex Yokes?
- i know i keep asking...
- Smittybilt extended top
- Tailgate to spare wheel buffers
- Unichip vs Superchips
- lod rear bumper ?/ max tire size
- Replacing rear roll bar cross-member?
- CTM u joint with alloy c.m on a rubi ?
- any experience with this lift?
- Tires tires tires
- TREs for Rock Krawler's new design tie rod?
- Rugged Ridge signal guards
- 3.25" to big for 33's?
- Replaced Driveshafts.... now diff fluid everywhere
- What diameter wheel spacers sould be?
- Is anyone selling "this" winch mount?
- What is this? It came with my winch.
- Need help setting up a tie rod/steering stabilizer combo..
- Need help, bar pin question.
- Are you running 40's on a JK?
- Body Armour rock sliders for 2-door
- Ar Lift Kit
- Newbie questions
- help with Drive shaft!
- Pro Comp 7005 Wheel and OEM TPMS?
