View Full Version : Modified JK Tech
- spray in bedliner, water resistant seating
- Another DW thread???
- Need help on a performance chip!
- Need some advice
- Who has the widest tires mounted to stock Rubicon wheels?
- Superchips 3875 Jeep Wrangler Flashpaq Programmer For Sale PM me
- bedline grill!!
- Tool Box
- Soft Top Mods anyone?
- Viair 2on2 high speed kit
- Drive Shaft/Diff Slack
- Hood louver w/ black grill pic request
- Is my exhaust damaged??
- Jeep need a checkup before lift and tires??
- OME 620 question
- To wait or not to wait
- Hothead Headliners 2012
- Tailgate Bump Stops
- 4.10 vs 4.56 2012 6 speed with 33's until I get 35's
- Well that's not right....Bestop Grill Guard
- New rims
- Passenger Side Leak 2012 JK
- Trektop vs Trektop NX for 4 door
- Retaining Clips on Wheel Bolts?
- Is a steering stabilizer worth it??
- Fox Shocks
- Tires
- Dont know what i should buy
- HELP!! teraflex and KMC fitment question
- ripp or sprintex which has more power
- Rubicon Sway Bar Disconnect Question
- What product did you use to stop soft top leaking
- e-Locker lights not on...HELP
- Best Gearing Combo w/ Ripp Kit for a 6 Speed Daily Driver?
- ACE rails coming and gotta grind body mount washer
- Bilstein Steering Stabilizer question.
- Trektop NX - 2012 unlimited - Bestop warranty experience
- Lift Installed, Alignment?
- Yukon Gear Install Issue - HELP!!
- H.i.d.???
- AEV 2.5" coil lift
- Painted bushwacker flat flares
- Question about dominon offroad catback
- Gloss black vs. Textured black bumper finishes
- Bumpstops and 3/4 in spacer with 2.5in RC coil lift??
- ACE rails and Body Lift?
- Front adjustable lower control arms and Front adjustable track bar.
- Going from stock to 35's in stages? Is it even doable??
- Why the **** is my front end wobbly???
- Installing Rubicon sway bar on a Sahara
- im making modifications to my stock bumper
- Winch Help
- Teraflex spacer kit VS Teraflex 2.5 lift
- 3/4 spacer on top of 2.5" lift
- personal experience
- OR-Fab Tire Carrier
- Banks monster exhaust
- ATX Slabs
- Tuffy Security Deck Enclosure and the Trektop Original
- Removed the "star"
- Question about XD Rockstar Wheel
- Drag Link question
- Evo suspension ?
- Going from BFG KM2 to BFG All-Terrain
- Weight after build up?
- 37s and pinch seam
- Build Thread
- 52K miles from Baja Claws, but now its time to go
- Falken Rocky Mountain ATS Tread split?
- New Teraflex Rear upper Bumpstop question
- Toe/caster adjustment after 35"
- what is the purpose of the Teraflex front sway bar links in...
- Best off road tires
- Ripp Header install question/Skid Plate recommendations???
- OrFab Tire Carrier Rattle
- Help on upgrades.
- Rear sway bar links
- Fender trim help
- Racks for Kayaks
- 3", 4", 6" long arm lifts
- Full overhaul for 5.13's ???????
- Pro Comp M/T VS KM2 VS Dick Cepek FCII
- I am afraid! Rear Bumper JCR
- tire issues
- Does this exist
- Help ordering new front axle please
- Gear swap dana 30 3.21
- question on drive shafts and future suspension setups
- Sway Bar Disconnects, Head light, & Fog Light recommendations
- Thank you Quadratec for doing the right thing
- JCR Dagger mid width and A.C.E rock rails on order
- ace rock rails installed but.....
- Winch on stock bumper
- Just got new Wheels & Tires...Need Help on ProCal
- Broken driver side rear axle Sahara Dana 44 30 spline, which axle upgrade to use?
- Wheels & Tires
- How do I disconnect the wire on the top of a Dana 44 Rubicon axle?
- Line-X vs Onyx Bedliner for Parts
- shift boot seal after a body lift
- Tires/lift installed pics and opinions
- Rim/tire ? HELP
- Atx slab with beadlock vs. normal 17" aluminum rim?
- how to change u joints
- rough country quality sux
- will 33 12.5 fit on stock tire carrier?
- How much back spacing is too little?
- is there a Superwinch rep here?
- 37s any body trimming needed?
- McGard Wheel Lock Key Broke......now what ??
- Aftermarket Wheels and Spacers Question
- Lift rims and tire help
- The Age Old Which lift should i get question?
- TeraFlex JK 2-door 1.5" Performance Leveling Kit
- Quick question
- Riddler D44 diff cover install question
- EVO Draglink Flip
- Need Help With Winch
- Wheel question
- A weird winch question...
- trektop nx
- Long arm kits?
- Clayton 4.5 inch and nitto trail grapplers
- wheel spacers?
- Please help!!! 2 dealers, 1 month w/out my Jeep ...still issues.
- Will I have some rubbing (driveshafts)
- So this is new
- Rim width?
- 2008 Soft Top on a 2011???
- Driveline vibrations, transfer case maybe?
- JCR dagger midwidth for 2011 JK unlimited
- Fifth Wheel Predicament
- Anyone using a DashCommand App to monitor engine data?
- Is this the right D ring receiver?
- Show me your tires on stock rims !!
- Choice of Snorkels
- Suspension for fast ride on rough and bumpy road
- Need a little help...Rusty's 3.25" basic install
- Color scheme help!
- aftermarket steering wheel hubs (momo? grant?)
- mbrp exhaust leak
- Stay with 17" or switch to 16"?
- Just got new Teraflex leveling kit! Anything I should know?
- What else will i need to run 37's
- Inside hardtop
- Recommendations for replacement seats?
- D44 Full Float Kits?
- Lower Control Arm install tips...
- Lets see from to modified
- Please critique my lift (or affirm)
- programmer questions
- JCR Vs. RR XHD Front bumpers
- rear coil spring isolator
- bump stops HELP ASAP
- Daystar shocks
- $300 To install Gussets and skids?
- Weight = loss inchs.
- Bent Pitman
- Noise issues with Rigid light bar and Trektop soft top
- Quick teraflex help
- AEV Pro-Cal recalberation tool
- Rough country BB questions
- Question about wheel spacer with RC 3.25 lift
- Rear bumper help!
- stability control disable
- Springs for fast bumpy ride
- Exhaust spacer needed on 3.5 AEV lift??
- This isn't good...
- 1st time mods - MOPAR lift questions
- Axle truss
- Inverted Swaybar
- Clicking in steering wheel
- wheel offset and backspacing?
- 35's with a Stock Rubi Spare?
- Ball Joint Noise when testing them!
- Does the Drake Billet knob fit Automatic on 2012?
- Need help tracking down a wheel?
- Got me a new winch!!!
- Faulken wildpeak tires
- yokohama tires
- Rubicon 2" spacer system...help!!!
- Tinted fronts on softtop?
- Instaliing rough country 2.5 inch lift
- Newb installing aftermarket front bumper.... any advice?
- toyo mt vs duratrack
- Mopar CAI
- Finally got my AEV hood installed
- daystar 3/4 front and rear lift
- Installing my TF leveling kit tonight, any tips?
- coils or spacers?
- Rock Krawler 2.5
- Spare mount / carrier
- Going doorless soon and need a good mirror kit
- squeaking coming from the rear
- AEV Pintlers or Savegre Wheels
- Dana 60
- Will this tire fit on my rig?
- Gussets?!?! Questions for longevity
- Trail rack and jerry can holder
- Pic Request: 315/70r17 Duratracs on Stock Moabs
- Ok, I give up
- New JK owner/ what is this?
- opinions on lifts
- Roof height after lift and tires
- Advice on Lift and Tire Combo
- Resonator removal
- Rock Krawler sway bar links noise
- Traction Control and Check Engine Light
- Planning my phase 2 build... 37s and ProRock 44.
- AFE Y-pipe vibration/rattle, need some help.
- 35's with Auto Tranny - 4.88 gears or 5.13 ??
- Backspacing??
- Will an offset front axle cause vehicle drift?
- Information on Lift & Tire Kit...
- Flexing my "C" joint
- Lift kits & and tires!! Need help
- another question about wheel/tire weight
- Rock jock 60 rear full float?
- What's the purpose of the stinger bumper
- Trail Grappler vs. Duratrac 35's...Weight concerns
- Bent C's vs. not bent C's. Pics?
- What else do I need
- Mtr/k giving problems
- 35s on 3.73 auto?
- Logic behind wheel size, MPG's and need for Wheel Gussets
- SOLID diff covers / Rubicon
- Best battery replacement for 2010 JKU Rubi
- Need advice on 2" lift
- Comparison
- 3 inch bds lift... 35s vs 33s
- Fastback Top VS Factory Box look....
- Modding a 2012
- Trektop NX Rear Window Hitting Rear Head Rests in 2012 2 Door
- Nitto Terra Grappler Tire Pressure
- Drive shaft BOOT
- Rugged Ridge XHD aluminum bumpers
- freakin stone guards
- C Gussets
- 4 Door "Floor Plan"- Anyone have one?
- Tire pressure
- Questions about a 33" tire upgrade on a stock 2-door......Is this a fair price????
- Thinking about lots of Line-X??
- RK 3.5 Max Travel Instructions
- Brakes.... Going to upgrade to a 4 inch lift with 35 or 37 inch tires
- Going with 35's - Heard I need C Gussets??
- Ring and pinion question....
- New to Jeeps and need wheel size help!
- SUMMER TOP IDEAS for a 4 Door
- Toe In Alignment Question
- Recommended Tie Rod replacements?
- Stupid question
