View Full Version : Modified JK Tech
- AEV Heat Reduction Hood
- Rugged Ridge Snorkel- Just installed
- Fender Flare Fitting
- Run with no Front?
- JK modified to Tomb Raider style
- Smittybuilt C.R.E.S. Top... Can't get to fit my jku
- Best Tire for NC.. from West to East
- Spare Tire Decision
- Agressive suspension
- Rebel Restraint brake conversion???
- Steering Pop
- Rock Krawler 3.5" max travel vs teraflex 4" with flexarms
- Rock Krawler 2.5" lift install - post mortem
- Yup, another lift thread. Torn between 2 lifts
- Trektop NX help
- Help me choose rims!
- Hyline bumper and tire carrier
- Help please. Axel or wheel bearing?
- Adjustable Front Track Bar
- For those with wheel spacers
- Best skids!
- Jcr dagger rear bumpe on!
- Do have and ORE hand throttle installed on your JK?
- Rock krawler 2.5 inch coil question
- Please help
- Driveline noise goes away in 4wd?
- Rotors
- Jack Stands??
- Shot U-Joint
- bump stops
- Rancho Sport 2" w/ 9000's Worth It?
- Detroit TrueTrac, Any Feedback
- superchips flashpaq
- Viar 2on2, do you have one? Have an opinion? Something better?
- Rugged Ridge 8500lb winch parts
- So what to do with all those extras???
- Recenter steering wheel help, ESP light is on
- question on balancing 35" km2
- Windshield
- rc and 37s
- Does this sound like bumpsteer? could use any advice
- Superchips 3875 Flashpak
- Chromoly Rock Sliders
- Daystar Lower Dash Switch Panel
- Stock Fog Light Install
- Not a wrangler but a jeep need help
- Bestop cable safari top
- Should I get coil wedges for 2.5" lift?
- Mirror ID
- towing
- suggestions on rock sliders
- highway speed driving?
- Ranch 3" Trail Lift
- afe high tuck exhaust
- A little fluid.
- Rubicon Express 2.5 coil lift w/Bilstein 5100's or 3" BDS
- Northridge4x4 Grade 8 Bolt Kit with AEV 2.5 Dualsport?
- Maxxis Owners Tire Pressue and Q's
- Bumper question (winch & airbag related)- which bumpers?
- Available custom hoods?
- Teraflex 4" lift with flexarms
- Quiet aftermarket exhaust options
- Tires for Mixed Off-Road Terrain
- Bumper poll
- RK 2.5 Lift Install In 2 Days
- How to get a spring in place?
- quick disco problem
- teraflex control arm parts
- Quick question
- Pinch seam. How close is to close?
- Regear... noob question, already tried search
- to align or not?? that is the question
- 35's E-rated What PSI are you guys Running
- Stepping up to 35" tires
- Admin help
- Pulled the trigger on gears 5.13s. have some questions
- Is there
- Maxxis Bighorn Weight
- Vibration
- Metal Cloak Game Changer lift
- Mud/trail grappler longevity and road comfort?
- Fixing my broken 4x4 shifter
- Trick to getting track bar reattached?
- waterproofing quadratop summer combo
- Rear Springs Bowed? easy fix for $25
- TF Rear Uppers
- Installing winch tomorrow advice reqest
- Pcv valve removal help!!!
- TeraFlex VS AEV 2.5
- Cai
- 35's so many questions...
- installing pro comp 7076
- Best type of tape to use on soft top?
- Warn Zeon on Poison Spyder Brawler lite?
- What if TPMS doesn't automatically reset?
- About to install EVO Corners
- Front 60s RockJock IIIFS ???
- Black AEV Pintler or XD Addicts...
- How do I remove Valve Stems in preparation for Powder Coating?
- What is a LCG (Low Center Gravity) Lift?
- How tall is your Jeep with all the MOD's you have put on?
- Bestop Supertop NX Photos? Opinions?
- New steering stabilizer with lift?
- New rear bumper help?!?!
- First time towing, help, please.
- 2.5 suspension lift and 1 inch body
- Looking into JKS lift kit.
- Tips and tricks for installing Rock Krawler lift
- 37" nitto mud grapplers
- kit install for front alignment
- Fender Chopping!!!
- Monroe Shocks
- Bikini top 101 ???
- Rubicon Express 2.5 lift, any good?
- death wobble
- U-Pol Raptor Liner durability
- Poison spyder front and rear bumpers
- Detroit Locker/True Trac Review
- replace TF 2.5 coils with RK 3.5?
- 2 door jk
- Rocklights wiring help!!!
- When to use lockers!
- 285s
- 4 broken lug studs on one wheel!!
- Off-road evolution rock sliders
- MBRP light bar mounting ???
- RK Track Bar question?
- Tire carrier question
- Snorkel with 50 inch light bar
- Teraflex spare extender with 35's
- Cost to line x/rhino entire Jeep?
- Check engine light, possibly from k&n?
- 1000 nicks in windshield
- Anyone Running an 09 Unlimited JK on 35" Tires with a 2.5" Teraflex Coil Lift?
- shock dust covers (bilstein 5100)
- does this make sense, any interest
- Running air for MTRs
- Bumper Alternative
- Almost done. Need some muffler help.
- AEV 4 door 3.5" dualsport SC
- Bestop Rocker
- Noise is Right Front when Turning??
- A/T Tires
- Looking at a jk build
- Painting coil springs.
- JK Automatic Transmission Problems?
- New Tires!! Can't Decide!!
- AEV Pro cal and TPMS issues
- Thoughts? Opinions?
- I need advice from my buddies.
- newly installed adjustable front and rear track bars... now what???!
- steering stablizer question
- 3" Lift with 35's
- New tire has slash in it what do i do?
- Dynomax evolution competition review. (2011)
- Help with iphone app
- Balancing wheels
- PSC Brawler Lite
- ATX Slab rock rings HELP!
- Need more droop out of RK 3.5 lift
- Airing Down Tires
- TF Rear Trac Bar relocation bracket - frame side
- Lost Besttop 1/2 door keys
- Snorkel, Finally
- Lifting will i have driveshaft issues ?
- Alloy USA
- Dana 30 inner axle seals.
- yes another MPG thread
- Lift kit?????
- Shocks! Shocks! Shocks!
- What was done to this Jeep??
- pic requests jk 4dr springs on 2dr
- Solid Lift Kit for Mainly Road Driving
- Stock 07 JKX $1000 to spend...?
- What would I gain from installing wheel spacers?
- Dynomax Ultra Flo
- 2013 JKU Performance
- Suspension help
- 2010 rubicon build
- XRC Rear Swing out tire Carrier
- Quadratec and Northridge4x4
- Time and Tools?
- Which size JKS Quicker Discos?
- Spare wheel and tire inside??
- Help
- Is anybody using a chip to modify your power and fuel economy
- Whats wrong with my jeep!!!!
- rough country series 2 lift review
- Difference between 40" tires and a 37's on a JK full of people and camping gear?
- rear TF swaybar link?? Help please!
- Best, non-flipped drag link
- Rock and roll
- What Next?
- Labor quote
- Evo
- 2013 Rubicon wheels help
- Rock Krawler RRD 2.0 Shocks vs FOX 2.0
- Metalcloak Thread
- Custom JK Grab Bar for RAM Ball Mounts
- Looking to buy new rims! Need Advice!!!!!!!!!
- Will it suffer
- Jeep pulls to side after lift???
- Need a little help with tranny
- Question for guys running Adams driveshafts.
- Driving without front driveshaft
- Cages
- Difference between SRC & XRC Smittybuilt
- How much actual lift
- Broken 42RLE input shaft1
- Banks automind programmer
- Poison spyder vs. Metal Cloak fenders
- Is this possible?
- New Magnaflow on 2011 JK
- ECTED or ELocker
- suspention help
- What o-ring? Please help me?
- Front & Rear driveshafts
- Economic Tire Carrier for 33" XD to solve rattle?
- Has anyone added dual washer nozzles to older JK (AEV Heat Reduction Hood).
- Level 8 zx mag
- something to match carpeting
- Weather strip
- Aries tubular fenders
- New arb lockers same rubicon locker switch
- 18/59 vs 19/60
- TPMS question.
- Snorkel
- ** Quick Superchips Flashpaq question**
- Magnuson 3.8 supercharger
- Nitto terra grappler weight specs
- lift size
- AEV rear bumper question
- Rubicon Express 3.5 Superflex with AEV Pintler Wheels Rubbing?
- Teraflex Hinged Tire Carrier Problem
- Rubicon Express 3.5" Standard
- Spline Count Dana 44 Rear and 30 Front?
- Shoud out to SmashBoogey 4x4
- Major Screwup
- Going crazy deciding on which lift!
- One more tire question
- Opinions on this set up
- Just ordered a ZEON winch, what bumpers WON'T work?
- Running 35's with the 3.6L and 3.21
- Dick cepek mud country
- Prorock 60 width and parts compatibility
- RCV's slacking customer service
- Goodyear MTR 38s
- Anyone on the jersey shore know of a dealership that wont flag u?
- Cooper Discoverer STT opinions needed
- Adjust shift points without regearing?
