PDA
View Full Version : Modified JK Tech
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 [200] 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296
  1. icon vehicle dynamics vs Kings
  2. new bumper
  3. Stock(ish) JK disappoints in sand. What now..?
  4. Need help with new suspension
  5. 6 speed, 3.73 gears w/stock Rubi 32" wheel-tire set-up??? First Post!!!
  6. New Unlimited Questions
  7. Recommendations for a good Mud Terrain Tire that also performs well on ice
  8. Diagnose popping sound? TF 2.5" installed
  9. hood grommets
  10. Gear Swap for the Jk - Ooops!
  11. How do I extend the parking brake lines?
  12. body lift - do i need to re-center streering???
  13. Superchips flashpaq and Factory transponder key
  14. 1 inch coil spacer on 4 inch lift
  15. Chrysler paid me for my auxiliary transmission cooler
  16. Nitto Trail Grappler M/T
  17. ball joints
  18. Offroad Heroes Soft Top Review?
  19. will 15" fit on the new JK
  20. Best Upgrade for Mud
  21. MBRP sound file
  22. Advice on using Nitto Trail Grapplers with my Stock wheels & EVO Enforcer
  23. Sway Bar Link Question
  24. Bestop Soft Top Headliner
  25. Yokohama Geolander M/T
  26. Don't understand wheel width in relation to tire...
  27. Running TF 2.5 Coil with leveling kit as well?
  28. To Switch Or Not?
  29. Wheel Backspacing & Offset Calculators
  30. TF 2.5" Coil/shocks Lift...Still need leveling?
  31. LOD Rear Bumper/Tire Carrier Questions
  32. TF 2.5" coil lift and ESP warning?
  33. 38x14.50?
  34. Dynatrac ball joints
  35. Caster Adjustment Needed On Teraflex 2.5" Coil Lift?
  36. Issues Again Pinpointed the problem though let me know your Thoughts!!!
  37. LOD or rockhard
  38. 35 w/ standard gearing
  39. notching tranny skid, is it self explanatory?
  40. 35s & Toe-In?
  41. Will 35s fit without spacers on stock rims
  42. Which Tubular Doors? Mirror/Rattle/Looks?
  43. Gerry Can mount
  44. upgrading driveshaft question
  45. Engage 4WD while working on Jeep?
  46. Xtra Wide Mud Gapplers???
  47. Superchips tire height
  48. Need anything else?
  49. Shift Light
  50. help decidin which lift.
  51. Conclusion of lift and wheel upgrade
  52. ProComp 7032
  53. Cambolts vs. Adjustable Control Arms
  54. suppercharger
  55. Superchips now available for 2010 JK!
  56. Warranty
  57. Slider Question
  58. Drivetrain question
  59. Sound and suspension
  60. Death Wobble?
  61. 3" Zone Suspension Lift vs. 3.25 Rough Country Lift
  62. LoD D-ring Tabs
  63. Seeking for a "COMPLETE" 2.5-3 inch lift on my JK 4 door
  64. 35s: 35X12.50R17LT VS. LT315/70R17
  65. Superchips flashpaq's for JK 2010 is now available !
  66. need advice..doing minor body work repair
  67. rear bumper
  68. Off Road Evolution & build advice
  69. What to do with JK Rubicon OE Springs and Suspension?
  70. How tough is the Goodyear MT/R with Kevlar?
  71. Rim Question
  72. 35" tires Questions
  73. Lift - OME vs Teraflex
  74. Air Intake/Exhaust Poll
  75. What exhaust?
  76. which body lift
  77. looking for 4" springs only
  78. hub and lug centric wheel spacers
  79. spacer lift, and wheel spacers
  80. Steering "Hitch" after Teraflex 2.5 coil lift
  81. Ripp mods supercharger and superchips programmer?
  82. Aggressive AT's
  83. Stock Stubby Help
  84. Strenght of Stock bumper
  85. '10 Sahara Unlimited First time Off-Roader, how's this for starters?
  86. Suspension Question
  87. 4.87 Backspacing with 295/75R16 ??
  88. Trak-trak, Brake Lock, ESP and whatever else
  89. Looking for a nice 3-4" lift for a 2 door jk rubicon.....
  90. Whos JK in Baltimore
  91. Help on My gears 5.13 and 37" tires
  92. How tall on 40s-42s?
  93. loss of height with LoD rear bumper and carrier?
  94. LoD Gen2 rear tire carrier issues
  95. need to trim my LoD mid width
  96. Help!! with Rims
  97. Lightest Aftermarket Bumper?
  98. Roof racks. Need opinions.
  99. Yakima Rack on 2 dr Hardtop?
  100. Yet another lift question...
  101. Smittybuilt XRC Front Bumper - What would I do with my fog lights?
  102. rubicon vs. x shocks........more travel, or just more stiff?
  103. Info about Stainless Steel Extended Brake Line
  104. More Guages??!
  105. Tradoffs? Spacers vs springs
  106. skyjacker dual stabilizers question
  107. a pillar-mount grab handle?
  108. Volant CAI and AVE Snorkel
  109. Canoe on a Gobi
  110. miles per tank
  111. Death Wobble - problems seem to be going away
  112. Front End Noise?
  113. That's right, another gear question
  114. Opinions on Old Man Emu lift?
  115. drive shaft length ?
  116. 4.56 gears
  117. Argent Pintlers/Shrockworks Anthracite
  118. Stock Rubicon rims w/ big lift+tires
  119. stock shocks vs. rough countys 2.2 performance shock
  120. What is the best way to go about painting Aluminum Grille Inserts in Brushed Aluminum
  121. popping noise in front end?
  122. River Raiders - Smilin Bob's Breather Extension kit
  123. Smittybilt SRC bumper question
  124. How bad do 35's hurt the power?
  125. Is the harley davidson passenger mirror functional?
  126. Canoe rack for unlimited
  127. bb and coil over??
  128. im at a loss..
  129. pinion seal install
  130. Installed PA 1 inch body lift= body mount torque question
  131. coast drive shaft
  132. am i crazy? 37s on 2.5" TF lift
  133. Tire spacers, Teraflex, rugged ridge or spidertrax?
  134. Air Intake...
  135. Flat fenders vs. stock fenders... how much flex?
  136. OEM tube steps VS RR oval side steps.
  137. Which tires?
  138. I want a Supercharger?
  139. What is the largest tire that will fit with 4dr rubi tow coils on a 2dr X
  140. Evap Cannister Relocation Installed - gas cap light now on
  141. 5.38 Gears with 35's
  142. Re gearing
  143. Installing adj track need help
  144. Lift Question
  145. Rough Country 4 inch x - series lift rear tracbar problems
  146. Will JK Coils/Shocks fit '00 TJ
  147. Recon LED turn signals
  148. Teraflex 2.5 spring lift with coil spacers?
  149. Rear Stock fender chop!!
  150. Yellow jeep, Black hood?
  151. Any unlimiteds using Bestop Header/Windjammer?
  152. Turn off my low tire pressure warning light
  153. Tire Advice/ opinions needed
  154. After market cage?
  155. Performance chips? Do they truly work!?
  156. 2dr + TF2.5" Question about rear upper control arm
  157. hp question?????
  158. Any reason not to get the 12k/lb Warn Powerplant..?
  159. Grab handles?
  160. Clutch
  161. Turned My Rearview Mirror Upside Down! You Must Do This!
  162. Wire or Synthetic winch cable, is it worth the extra money?
  163. 2.5" Teraflex Coil Lift leaning to the passenger side
  164. 3.0L CRD V-6 Engine
  165. 09 JK Didn't pass inspection/Superchip Arghh
  166. Trektop suggestions? Last chance for Bestop.
  167. Rear bumper/tire carriers and Gobi racks
  168. Rear sway links to the front and front to the rear?
  169. BFg a/t's or GY Duratracs ????
  170. Experience with tires through Costco - or anywhere to get KM2's
  171. Help Second Aftermarket exhaust not straight
  172. Best Adjustable Rear Trackbar for OME Lift? (4 door JK)
  173. Mesh Bikini/Island Topper Tops?
  174. Problems with LOD and WARN PowerPlant Dual Force HP 9500LB Winch
  175. Rampage rock sliders?
  176. Air Shocks
  177. Synthetic Rope Fairlead
  178. Quick and Easy Roof Rack for Kayak
  179. 3" lift, Rough Country or Teraflex ?
  180. Will a 37 13.50 r16 fit on a 16x8 rim
  181. Need Axle advice
  182. 4" lift?
  183. DIE TECH EVAP RELOCATION..... Check engine light ON!!!!!
  184. lockers Front or Rear?
  185. tire compare 35vs37
  186. Most comfortable aftermarket seats
  187. How much pressure for Street 295/70/R17 Nitto Trail Grapplers / XD Addicts 17x9
  188. pics of my jeep. What lift height do you guys think this is?
  189. How do you ever decide on which LIFT to install!!!
  190. Stubby front bumper?
  191. 4.56 vs 4.88 on 2dr 6spd
  192. Driveshafts with more lift
  193. Pro Comp Xtreme Alloy Series 7098 - Flat Black
  194. Springs vs. Spacers
  195. AC compressor ?s
  196. Will my stock wheels and tires fit after my 3" Daystar spacer lift?
  197. extended the 6 speed breather tube
  198. Rock Rails and Side Step Together?
  199. Rubicrawler or Rubi transfer case?
  200. terrible steering
  201. what determines the ride quality? Shock or Coil
  202. Help!!!
  203. Step Sliders
  204. Which way to install new steering stabilizer?
  205. Tires, Gears, want personal instances, not facts on charts please
  206. problem with sway bar 2nd time now this happens
  207. xrc 8 will not free spool
  208. what size lift?
  209. 37x16 tires?
  210. Tailgate Bump Stops
  211. Dynatrac balljoints
  212. Camber Problem
  213. JKS 6150 Jeep JK Front Adjustable Lower Control Arms: Any suggestions?
  214. SOLID diff covers, fluid qty for a D30 ???
  215. quick Disconnects
  216. Extended Rear Brake line brackets
  217. Upgrade feed back
  218. Lower 40 Tailgate Idea???????
  219. Finally made my decision and went to Teraflex monster control arms!
  220. Jerry Can Location
  221. Axles and clutch
  222. KM2 vs MTR
  223. Experiment: 18.4 MPG City, on 35s (what's your best?)
  224. Swaybar touching front coil
  225. 5:13's sound like too much for 33's????????
  226. PRESS RELEASE - Off Road Evolution EVO Enforcer Suspension System Coming Soon
  227. 35's or 37's - Advice?
  228. Teraflex 3" short arm vs Teraflex 3" long arm?
  229. AEV Snorkle Question
  230. Is the front frame crossmember NEEDED?
  231. PSC Hydro assist with the Rock Krawler Tie Rod?
  232. Rough Country 3.25 lift
  233. Smittybilt SRC classic rock rails
  234. how did u cut for your AEV snorkel
  235. What size shock?
  236. rain gutter Problem
  237. Sector Shaft Brace from Off Road Evolution - any experience ... ?
  238. Rear Cage only?
  239. Aftermarket clutch
  240. When are things like Drag link flips and Adjustable rear track bars needed?
  241. 2-doors with Tuffy security deck
  242. What Shock Length?
  243. Lift Kit Help
  244. Best steering improvement is FREE - adjust your caster
  245. VDP Locking Hidden Storage Vault
  246. how to measure lift height
  247. What determines the articulation/travel? Coil, Shock or both?
  248. Spare Tire Eliminator kit?
  249. Wheel rings for Pro Comp rims
  250. Adjustable length for the Full Traction Adjusatble Control Arms?
