View Full Version : Modified JK Tech
- Fulltraction Premimum kit vs Ultimate kit
- MBRP Exhaust install help: Sliding the muffler over the pipes
- GEAR Alloy?
- Going to run 33's. Need lift suggestions.
- 2011 Sahara Unlimited arrived Friday, body-color top is pretty sweet!
- thinking 35s and im a newb
- Wheel size advice for a newbie
- What tires run true to sizeand which ones dont... get what you paid for!!!!!!!!
- superchip programmer issues
- I want to add some mods and i need help !
- 35's on stock suspension
- Help, Tire advice Needed, sidewall punctures
- Will 35s fix DW?
- Need some wheel help!!
- stock bumper mod for a winch
- Death wobble?!?!
- Tore my drive shaft boot...now what?
- bds 3.5" lift 35's rubbing on pinch seam
- 0.75" Daystar ComfortRide Coil Spacers with 35s...
- HELP PLEASE 4" Teraflex Long arm kit
- Aftermarket Bumper Weights
- Warn tire carrier help please
- DynoMax Dual Exhaust problems?
- finally ordered a lift
- How do you extend the speed controll wires?
- How will this look?
- MBRP Exhaust install help: Removing stock exhaust
- Rubicon Automatic Sway Bar Disconnect
- Snorkles and winter.
- To anybody running Rough Country's 1.5 wheel spacers?
- install new bushings in RE lift
- where can i buy ?
- Front Locker Alternative for Rubicon
- Shcck diference?
- Rear CA Question
- Looking for the BEST Rear Bumper w/ Carrier
- Rock rails & side steps?
- is my odomiter off
- Control Arm Bushings?
- Need a new front bumper
- help with Warn PP 9500
- Full Traction Suspension Question
- 15" wheels?????
- PSC pulley and pump problem
- Double check my tire choice
- Headed to get tires!!!
- 35's rubbing on the back
- Hey thanks!
- Can't decide on which 4 inch lift to get..
- mtr/k
- do i really need 5 tires
- Found my DW! Here is a few tips
- 33" and stock 3.73 gears with an auto tranny
- RC 3.25 lift with 35's??????
- started prepping for raptor lining, Pain in the butt!!!!!
- Sagging front coils, replacement advice please
- looking for a good off road bumper...suggestions??
- What would I need to do this?
- 2dr with 3" of lift
- Help me Determine what I Need
- Suspension issues. needing some advice
- Tire/Suspension FINAL DECISION!!!
- 33 on stock rubi
- Americas 2011 Expedition - Need advice/help/opinion
- AEV Procal worth it?
- The parts are in!!!!
- What suspension lift do I have?
- Gears and Lifetime Power train?
- Caster Angle - Question?
- Rock Krawler 2.5 Max Flex Installation. Did I install the trackbar inproperly?
- were can i get my spedo adjusted
- poser question
- Just installed airaid and poweraid spacer
- best dilema EVER ??????
- Rim size vs. tire cost
- weed wacker exhaust help!!
- Rubi Shock Question
- Rubi Rails
- new to the jeep culture
- Alarm on a Jeep with manual doors/windows
- Front Control Arm Brackets
- Who makes the best disconects and why?
- Air lockers setups
- 513 and 6 speed unlimited
- POLL! Can't decide on bumper...
- Replacing rear shocks what do you recomend for a 3.5 lift
- Full Tracion Premium Kit + Drive Shaft OR Ultimate Kit
- Any tips for installing 3/4" coil spacers
- need advice after gear install
- Why are my dynatracs ball joint readings so off?
- Teraflex 2dr Performance coil leveling kit
- Install help: teraflex stabilizer
- What's a fair price for a set of used Duratracs?
- 5.13 vs 5.38
- possible blown o-ring arb locker
- Sorry another what tire post!
- 3.5 - 4" short arm lifts ??????????(vendor comments welcome)
- Help Me Decide on a Winch from Amazon.com
- new lift, new tires, new noises
- 315 70 17
- 2011 steering wheel on 2010?
- Roof Rack load bar solution - $39.99
- 4 dr springs in 2 dr
- NEW TO THE JEEP SCENE: Looking for experianced advice on the soon to come upgrades.
- Cutting Corners ???
- Gears or Ripp Headers?
- Rubicrawler ... anyone using one?
- Question on switching out my stock transfer case with a Rubi
- Bedlined Windshield brackets?
- skid or non-skid?
- Another tire debate: 325/65 or 305/70
- What is your gear of choice, 5.13's or 5.38's?
- XHD bumper with Flat Tops?
- 07 JK 2.8 CRD 2 Door On 33s (255/85/16) BFG MT KM2s
- Tire Carrier's
- Pull to the right/reman vs. new caliper prices
- Superchips
- rubicon advice just bought lift and tires.......
- Full Traction 5100 shock "Q"
- Tires
- Rubi Rock Rail Question
- Mud inside shift boot/Trans?? From Body lift?
- Two Questions
- New popping sound!!!!
- long awaited rocker rails
- AEV Nth Degree 3.5" Lift...with 33" Tires???
- Newbie going to lift
- Smitty Bilt GEAR Overhead Storage
- 3.5" RC or 2.5" TF
- Mopar fog lights & rear wiper install
- Activating Factory Lockers
- 2008 and 1980
- Rubicon Gearing - Newbie Question, Please Forgive
- How much lift/tire is too much?
- Do I need front brake line relocation brackets to disconnect?
- Rubicon Sway bar e-disco
- 16x8 or 16x10?
- take 2" of lift out to make jeep better?
- Gear installation labor prices
- Extra Viair ail line?
- Long arm
- Bumper or no Bumper?
- Metal Cloak Fenders!
- Trigger Pulled! Smittybilt XRC Bumper and Smittybilt Comp Series winch!
- tie rod boot......
- what lift should i get for 35s?
- TF Speedbumps - What do they do?
- Jeep Leaning to the right?
- 4.88 or 5.13 ?
- Cheapest black steel rim
- Heavy Duty CLutch Recommendations
- best tool for cutting into metal bumper?
- powdercoat or bedliner
- Benefits of a Long-Arm Suspension
- Alignment after upgrading to Rubi takeoffs?
- 2010 jeep wrangler
- stock Rubicon 2 or 2.5 inch lift pls help a newbie
- 33's or 35's...can't decide
- Tube vs Plastic fenders
- Steering Stabilizer
- Cat back vs. rear section?
- Too many tire choices!!!
- Custom wheels causing an issue....
- Do I really need 513's?
- Disappointed with Shrockworks Rear Bumper Tire Carrier
- Question on backspacing
- Question on Rear Upper Control Arms????
- Don't think this is good?
- Duratrac or Nitto Trail grappler
- Superchips and OCTANE at different elevations
- bumper
- Lift advice
- 5:13 gears and 33 inch tires.
- Mopar hitch receiver, worth the money?
- OME 2" lift installation
- Help
- What fenders to use with my ARB Deluxe Winch Bumper
- Ready Lift SST mild lift kit review on a Rubi?
- 265/75/16 or 285/75/16 On Stock Alloys On An 07 2.8 CRD
- Aftermarket E-locker for RUBICON D44??? Stocker does not want to disengage??
- thinking of going to 37s need advice
- AEV or Expedition One rear bumper w/tire carrier.
- has anybody sealed their AEM cai?
- Suggestions
- Rugged Ridge XHD RRC - Mounting the D-Rings
- rear pinion bearing install question
- TF leveling kit on 35" mtr kevlars? 37s on how small o lift?
- Side steps with benefit of rock sliders?
- Can I fit 35x12.50s on Stock 16" jk X wheels
- AEV Milspec Bumper Question
- Steering Coil Wire?
- Axles
- Toyo M/T's or Kumho KL71's in stock anywhere (315/75R16s)?
- Need help on where to go next with Build?
- Shock advice
- RV Towing of a lifted 2008 JK
- Anyone running a York Compressor?
- 35s & 3.73 gears
- Shock Choice?
- Death Wobble When Braking?????
- will my highlift jack tail gate mount cause sagging
- Front Bumper Spacers Anyone?
- What spacer size will I need?
- 2dr auto with 3.5 rk??
- 35's on a 16x8 ?
- Correcting Bump steer on a 2.5 in Lift?
- Daystar rear tire Isolators.
- Steering stabilizer
- Any pics of 2.5 bb with the standard X 17" tires.
- Steering Configuration??????
- Where do you mount your fire extinguisher?
- Superchips Question
- Dealer cant align..need new offset ball joints??? HELP PLEASE
- Fender chop and rain
- CAI vs Snorkle
- Trailer hitch and oversized spare issue!
- Bought a used 44 housing how can I tell if the tubes or C’s are bent?
- Won a Lift kit,,,now I NEED TIRE and WHEEL HELP!!!
- Winches?!
- 33s??? 35s??? HELP!!!
- rock guards or running boards
- HighRock 4x4 Door Entry Guards
- Check out the new JE Reel DS!!!!
- Keeping away the rock chips?
- Pro cal tuner question
- Evo rockstar info.
- Do you guys think these are safe to run on our JK's?
- 35/10.50-17
- 2" Budget boost Pic request and question
- Two Single Folding Flat Back Seats...?
- Warn PP and MBRP front bumper?
- Half doors?
- 315/75 r16 toyo m/t
- superchips optinion again :)
- 315/70/17 on a 17x8 rim?? Highway manners???
- Front wheel bearings
- going with 4.88 ?
- MT Classic II Wheels
- One Locker or Two Limited Slips
- Tire confusion!!!
- Why does DW go away in 4WD?
- Fab-Fours Stubby Front Bumper
- shock boots?
- Front Drive Shaft Suggestions????????
- winch advice
- Steering Wheel Swap
- Chart for fender flare width for JKS
- Rugged ridge flares---Anyone use them yet??????
- OME LT shocks. Will sway bar link be long enough?
