View Full Version : Modified JK Tech
- Is this useless to me now?
- GF Performance Chip FOR JK
- Rugged Ridge Snorkel
- Pro Comp Radial Xtreme M/T
- need some winch HELP please
- Black wheels on stock jku
- 3k plus or minus to spend?
- my first mod
- rear end "clunk"
- Teraflex tire carrier installed
- Need help!!
- re-align
- popping in reverse?
- What lift kit is this?
- Another Rattle Question
- Re-Gearing to a 4.88
- Brand New Procomp Control Arm Came Apart
- Grand cherokee brakes swap....
- Advance Adapters Heavy Duty JK Shifter Cable Upgrade-Installation Write Up?
- Need help finding an exhaust installer in central jersey
- Lifts 101 for a newb
- Which lift?
- Which tire burn faster?
- TF leveling kit problems...
- Bestop Trektop NX
- How much weight will I save?
- My HEMI Conversion!!
- coil or spacer?
- New jK
- Draken 8 inch long arm
- Re-gear ? Or stay stock
- Nitro Axel sleeves
- sway bar light came on?
- What is the best mud terrain tire for my jeep jk?
- Re-Gearing info
- Rock Rail Suggestions
- 2012 Jeep JK Sahara Unlimited driveshaft
- source for used navigation system?
- Powder coat??? Yes or no
- .5'. Is that so diferent?
- Poison Spyder Tramp Stamp II
- best way to adjust control arms ?
- Question on ReadyLift SST lifts
- 37s and pinch seams
- Stock JK tire carrier
- 38 mud grapplers or 37 pitbull rocker radials
- soft top attachments
- Mirrors are stuck
- hard to soft top switch??
- Thoughts on Q-Series Winch by Quadratech??
- AFE Intake w/ Throttle Body Spacer 2012 Wrangler Questions
- Tuffy security deck question
- Can I add Suspension Pucks
- Yukon Gears (4.88's)... Cheapest place to buy?
- ARB Awning Gobi Rack Question?
- Another spacer question
- what's next?
- Nitto 38x15.5x15 question
- What locker in my pr44?
- Jet ski anyone??
- Will king shocks make a big differance?
- JKU 2012 with a 2.5 " speacers lift, do ireally need bumpstop extension or speacers??
- How to adjust pinion angle.
- New Jeep Mod check
- Do i need my spidertrax?
- Do I need a new shock?
- Aev 2.5 coil lift
- Budget boost vs TF 2.5" coil?
- teraflex or rock krwler.. time to decide
- time to decide
- Dana 30 Front Axle swap - Difficult?
- LOD Gen3 rear bumper with tire carrier finally shipped!
- Swaybar link placement, lil help
- Jack and Jack Stand sizes?
- NEW transmission
- Those running RC rear upper/lower control arms
- Flashpaq vs. Bully Dog
- sweaty back has got to stop!
- Trektop NX for JKU Rear Retaining Bar/Bow
- brakes
- How do I make this level & add lift?
- Diff Gear Oil Question
- What's your rear bumper + tire carrier?
- Will any d30 locker work?
- Skyjacker 2.5" lift drooping sideways...
- finally ordered the Superchip tuner for 2010.
- Tube Fenders
- Where can i get this grill guard?
- Minimum requirements for a 285/70/17
- Poison Spyder body protection
- Help me find a front bumper!
- how so cheap this site?
- This seems crazy!
- Exhaust Headers Comparison
- calibration module
- exhaust upgrade size?
- RIPP - Headers
- RIPP SC - 35's vs. 37's
- air conditioning condenser - replacement
- Terflex 2.5 lift question
- Please help with lift recommendations
- 2012 JKRU Roll Bar Add On
- Treadwright Backbone
- Dead Winch?
- Need ideas: steering stabilizer with Rock Krawler 3.5" mid arm kit
- Bestop trail cover questions
- Bolt kit with RK control arms
- Towing with EVO tire carrier.
- Odd winch question
- Looking for 40" tires
- Teraflex 4" long arms upgrade
- Front brake lines on 2012 with Teraflex 2.5 lift?
- Ok i know it is no problem with 35' with stock gear..
- JK 3.8 in older Jeep???
- Help please
- Fender trin with src front?
- Teraflex 2.5 or Rough country 3.5
- no fenders but black diamond plate to cover the holes?
- Want a pic of a 4-door with 2.5" spring lift, 35" tires and Bushwacker flat flares!
- Magnetic Sheets for Trail Protection
- might have rubi take offs sold need advise
- Auto tranny rattle
- Best "bang for your buck" power upgrade.
- Src rockers
- buy bilstein shock
- Spacers
- cutting off the winch hook...suggestions!
- 2.5" Rough Country w/ Nitto Trail Grapplers
- Has anyone installed a DoubleD lift kit from EVO themselves?
- oil change
- Bead lock rims
- Teraflex 2.5 ?
- skid removal
- MTR/K odd tread wear
- Skid Plate question
- Plasti-dip finish is fuzzy
- ripp gen 2 superchaeger by pass valve
- Corbeau Baja SS Seats and Center Console-Seat Betlt Question
- Wheels in ARB Ad
- Most efficient CAI?
- Help with properly seating rear coil spring after RC 2.5 Spacer BB!?!
- Minor gear oil leak near right front lower hub area
- Superchips Flashpaq help? fan setting
- Advice - best way to center front axle with adjustable tracbar
- Aev vs evo high steer draglink flip
- Superchips Flahspaq... Yes or No
- Lift?
- Installing 5.13 gears, need your opinion on gear pattern!
- new rims and tires?!?!?
- Coil Questoin
- Rugged Ridge XHD Modular Snorkel install instructions
- One of the best mods to my JK.
- Tire question and gearing
- newb suspension question
- Caster and toe help 2012 JKU Rubi
- Beadlocks
- terra flex 2.5
- Wheel / rim expertise needed
- new poison spyder Brawler Lite Front Bumper with Trail Stinger
- 2012 JKU Lift Questions - Newbie here!
- Trektop NX help
- Put my mind at ease....need help!
- Flashpaq tire settings and how you properly calibrate?
- Tie Rod, Drag Link, Pitmarm issues.. advice if you have it.
- Or-fab mid-width winch bumper (offset winch) - jeep jk wrangler '07-12
- Hoodlift shocks - brilliant!!
- Should i just spend the extra on 4.10s
- Melting pot Jeep
- Anyone running Pro Comp Series 1089 - Polished Alloy Wheels?
- Does anybody off road with Nitto Terra Grapplers? 285/75 R17????
- Full-Traction Replacement Bushing Options
- Good example of Open diffs. vs Locked Diffs- Video
- Which tire relocation bracket??
- rancho front shocks
- No drill roof rack options, 2012 JKU
- rock hard 4x4 front bumper problems
- Solar Panels
- Question about tire size, gearing etc..
- backspacing offset on wheels
- Springs on 2.5" BB Lift Shifting?
- Once lift is installed, what's next?
- Bigger impact on performance: tire weight vs size
- Please Help With TA KO Measurement
- Another tire question
- Which 2.5 " Lift?
- Installed lift, first mod... is this right?
- hanson tire carrier
- Lift?
- No fenders?
- Teraflex HD Carrier
- Cheap third brake light
- Pinch seam
- Need help: next mod
- New Jeep owner needs advice...
- about rock sliders
- door interchangability?
- Front: 2" Mopar springs. Rear: 4" Rough Country springs.
- 295 65 18 duratrac on stock spare tire carrier
- Bestop Element Doors
- AFE 3" Exhaust Question?
- Just spent some more $$
- New set up on 2012
- what tires to get
- JK exhaust
- Rock Krawler Max Travel 2.5" on a 2012?
- Hard top help
- Worn tires
- Teraflex 2.5" lift with 35's, Question on brake and ABS lines?
- Which coils?
- Front and Rear Bumper Question (Brand Loyalty)
- Bikini top
- Dana 30 with elocker and rcvs
- Is this bad?
- Lift, tires, and gears - First post!
- Corbeau Seats and Harness
- New 2.5 teraflex BB, any installation advice?
- Gearing for 35s
- rc 2.5 or zone 3
- Differential Fluid questions
- 33" tires and new wheels- need to trim fenders or fender flares?
- What lift kit to go with?
- Sway bar disco's on the rear
- Evo stinger on RR stubby??
- Help_ESP,ABS and traction control lights on!
- Tire size/type suggestions for OME 2" lift
- VSC light help
- Painting rims
- JK8 maybe be my only choice....
- Teraflex Budget Boost Question
- Transfer case leaking after installing coast ds
- 3.5" RK-X Factor pro lift with stock 32" tires?
- Poison Spyder Rear Bumper with Tire Carrier & LED License Plate & 3rd Brake Light
- Homemade Rear Bumper with Tire Carrier and Flush Mount Rigids
- Tint VS. Insulation...
- Tire Size Help
- Adjusting pinion and caster????
- Long arm kit or coilovers with stock arms
- Marathon Seat Covers - Digital Desert Camo
- OMG... Mu new jeep...
- Skids and snorkel for the CRD / Diesel
- MW3 bumper question
- Driveline vibration HELP!
- Mickey Thompson rims
- Rear bumper + tire carrier - PSC Rock Brawler vs. LoD Gen 3
- teraflex 2.5" review please
- 3" Teraflex w/ flex arms vs. 3.5" Rock Krawler Max Travel
- What size spacers do i need?
- 37" tires on only 3" lift?
- 37" tires with a 3" lift??
- Passenger side coil spring making contact with sway bar
