View Full Version : Modified JK Tech
- Rear bumper w/tire carrier, front bumper advice needed
- Poison Spyder Brawler sliders/steps
- How to center rear track bar?
- How much will tires stick out....backspacing question?
- Clearance problems
- Ome lift kit from nothridge 4x4
- control arm dilemma
- General Grabber HTS
- Drive line input and Suggestions (J.E Reel or Coast/1310 or 1350 ?)
- ARB air locker vs OX locker
- Pro Rock 44
- New drive line?
- Can you help?
- Can I just have rear wheel spacer installed? Will this cause driving problem?
- what to do?
- Tire Help
- Wifes jeep. Flighty feeling
- axle shaft dummy question
- 5.38 vs 5.13
- Benchmark Bumpers
- Rear bumper advice need
- Third Brakelight
- RIPP Gen1 -Gen2 Conversion
- Broke the lower 2 ears off my stock PS Gearbox
- Steering wheel wobble/bump steer
- AEV 3.5 or 4.5 lift?
- Full Traction's bushings fixed?
- Pro comp 7069 17x9 tire size? No lift
- Anyone with 17x9 10mm offset with 315/70R17 on?
- 35's on a 2" budget boost
- Help with tire choice!
- 35's 0n 16 x 8's
- Teraflex Monster adjustable trackbar
- 37's 3.21
- 08 sahara unlim w/ issues.
- Eagle alloy series 185 pics
- Front Dana 30 Questions.......HELP
- How to Install coil springs?
- went from a 4" rc to a 2.5rc lift
- Anyone every use or see these - Prothane 2" spacer lift - ebay
- EVO vs. Teraflex -- Drag Link Flip
- 35 inch tires and 5.38's? Will AEV programmer help?
- 4" lift or 3.5" lift?
- Diesel jeep?
- bushwacker flat flares, ideas??
- 65 PSI In Swamper Irok ND!!!???
- Coil spring spacers w/ 3" lift to fix passenger lean???
- Rear swaybar links bent brakeline
- front axle torqe specs
- Tire carrier for ARB rear bumper???
- Is there a "gearing for morons" thread tucked in here somewhere?
- How's the ride and MPG w/ 37's?
- Can you fit 35/13.5 tires on a 4" lift?
- Need a little help with power guys...
- My wife told me to!
- has anyone replace factory grill?
- I finally did something...
- help - question on bumper lift needs?
- 34 inch tires
- What determines if a tire wheel combo will rub?
- What shocks for a 2.5" coil spring lift???
- Headers and exhaust...?
- 33's on stock tailgate???
- After Market Wheel's? Unsprung weight?
- Riddler Diff Covers
- Whos running 37s with a Dana 30!!!
- Couple of concerns with Dynatrac ball joints..
- How can I correct BUMP STEER?
- Evo silders with Rock Krawler lower control arms
- Will an ARB diff cover rub on stock Trackbar?
- Air intakes
- Caster vs Pinion Angle
- Upgrading - Wheels, Tires, Lift, Re-Gear, Bumpers, Etc. Spacers or no spacers?
- 305/65/18 on stock Sahara wheel
- Help Me Decide which 37" Tire for DD
- 2dr springs on a 4dr
- 2Dr suspension on a 4dr
- Rock Hard Jerry Mount with Mopar Rear Bumper?
- Anyone here ever heard of Zone Offroad Products??
- Does anyone have any experience with Expedition One's rear bumper and carrier?
- Lift upgrade
- Question on "Flat Fenders" (Factory Cutouts, Bushwacker, etc.)
- More confused now than I was when I started...
- Bumpstops...what kind are you running?
- VDP Stubby end cap kit
- Free DIY mods
- 2" lift recomendations
- offset measurements
- RIPP GEN2 and auxiliary tranny cooler
- Bump stops
- a lil bit of bump steer
- debating on lift or no lift with my 35's....need help...pics please
- Superchips question, should I be concerned about side effects?
- Teraflex Track Bar Drop Bracket Template
- Want to go with 17x9 wheels but keep the same tire stick out...
- Need a new Tire carrier.. How about this?
- Cargo Nets#####
- Raceline Raptor wheel
- Paint defects on black wheels (Pro Comp in this case)
- stick shift lift issues?
- Diff Cover Advice????? What should I get?
- noise passenger side
- what am i not understanding here
- Metal Bang on Terra 2.5" BB
- Stock JK with Rubicon wheels and tires?
- Neoprene winch cover
- New Rear Bumper
- ARB Diff Cover & 2010 Rubicon?
- JKS Rear Bar Pin Eliminators?
- On order
- wheel offset?
- Tire Size Question
- Best shocks
- Who has an ORO JK York air supply kit installed?
- Help!!!!
- Evap Skid
- Can I get some advice on bumper sag?
- skyjacker dealer installed lifts
- Lift, Tire, and Gearing Question
- Rugged Ridge XHD Modular Bumper
- Optimal Automatic Shifting Points
- Gears question
- If I got these wheels&tires, what else would I need?
- Quiet car soundproofing. Anyone using it???
- Stock fuel tank skid issues
- 2.5" BB Teraflex - E-brake lines question
- Black Kmc XD Addicts vs Pro comp 8179s?
- Rear upper spring perch issues
- Rear driveshaft vibration
- New Gears
- License plate mount?
- Should i install my diff gears myself??
- 35" with flashpaq tune with Rubicon 4:10 Gears
- Black w/chrome wheels - 17x8 or 17x9 with 4" backspace
- RC 1.25 Body Lift on Sale
- Or fab rockers
- How much did you pay?
- Or-Fab Side Armor...
- putting a Rubi front D44 in an X
- Leveling Rear of My jeep
- 33's
- Stock D44 strong enough?
- EVO Suspension On Road Handling
- Hummer wheels
- Need advice!!!
- BB vs a Coil Lift
- Best Reprogrammers???
- 2010 Owners that installed a M.O.R.E. front stubby help
- Dana 30 and 37s?????
- Another Tire Comparison
- make gloss color satin
- tourqe help!!!
- 1/2 Body lift? Any one make it?
- What is 'flighty' steering?
- Rear Cargo Tie Down Mod
- Wheel spacers
- sway bar
- AEV bumper MOD???
- Control arms vs drag link flip
- spacers question!
- New to upgrades... Guidance on my first modifications... (Lift/Wheels/Tires)
- PRESS RELEASE: EVO JK Draglink Flip Kit!!
- Rear Control Arms & AEV Lift
- Power Mirror Inquiry for Pre '11 JK's
- 3.5" Suspension Lift Questions
- evaporation canister relocation kit choice
- Lod Signature Series Rails - How long to install
- Aussie locker in the mud?
- Dana 30 upgrade, or ?
- Full traction long arm
- 2.5 coil lift install hiccup
- New to Jeep world
- tire opinions
- PSC Brawler Lite
- 09 JK Rubicon manual 6 speed REGEARING QUESTIONS
- Any opinions on the "Standard Gear" brand on ebay?
- 35 or 37s for DD????
- Dunlop Fierce Attitude M/T
- Help me kill my rake!!!
- Warranty repair question
- Hearing a slight whining from gearbox
- Best 3.5 inch lift?
- Is 35' nitto trail grapper need a snow chain??
- Drives like crap
- Well, here goes phase 3?
- Lug nuts and pro comps
- 35s with nothing else?
- Lift kit suggestions
- How High
- Nitto tires
- Wheel question
- MY Death wobble solved.....I think:)
- Rusty's Control Arm replacement
- TeraFlex Leveling Kit SKU: 1155200
- "Flighty" = FR adj. LCA's
- Ticking/Rattling when cold start in the morning??
- Winch difference
- Tuff Stuff Rocker Guards?
- 4 in lift with 2 in body lift
- Drive shaft question? Do I really need one?
- Death Wobble After Dealer Replaced Tie Rod & Drag Link
- My X-Mas list
- about Superchips Flashpaq for JK
- Dana 60!
- Rattling noise when cold under load??
- keeping rubi rails with more protection and a step?
- What mod first?
- Nemesis Industries Aluminum Flares
- Pro Comp 4" Suspension Lift
- Cat back system removed: just sharing...
- bump steer
- snorkel
- what 37x13.50 or 12.50 x16 mud tires are out there???
- Seeping rear diff
- Dirt and mud friendly CAI?
- Expert help needed
- Death Wobble After Bumps @ 60 MPH+ RK 2.5 Stock Mod Kit
- Can you tell me what wheels these are???
- Is AEV worth the money?
- 35's or 37's for jk 2 door
- Carrying Snowboard on 2-door
- Aeroforce Interceptor gauge question
- Gobi RANGER rack measurements...
- Help Me Build a Well-Rounded Rig
- Ripp supercharger questions on codes
- Ripp Gen 2 Review
- In the garage
- Help me choose betwen 35 or 37 MT/R Kevlar
- What lift should I get?
- My plans...
- Duratracs vs dick cepek fc-2
- is this enough trackbar movement to cause death wobble?
- Rock Rail recommendations
- Roadmaster Base plate
- Track bar relocation bracket and new popping sound. Has anyone found a solution?
- Specific Question
- Advice on setting up my 2011 JK
- Clearance Questions: 37s on a 2.5" Coil Lift
- Would this look bad?
- Lift install problems to be aware of?
- Wife said - "Get a roof rack and tent"
- Gearing for non rubicon dana 44?
- Rough Country 1.5 Wheel Spacers?
- Does bushing type really effect bolt holes wallowing?
- Looking for a Bumper that
- can you remove the bolts on the procomp 1028/7028 wheels
- skids / armor...???
- Help!!! lift questions... and rubbing ????
- Teraflex 2.5 coil lift question
