View Full Version : Modified JK Tech
- New Winch or swap off my Cherokee
- Looking for a specific bolt. Where to find?
- Online store for fittings and hose for on board air?
- Question on mounting RRC Side armor.
- e3 Plugs - add me to the list.
- Kelly Safari TSR
- Rear Driveshaft ?
- Triple D in Hawaii(TF suspension)
- Katzkin stitching
- Klein 6350 Onboard Kit
- Superchip and real time gauges
- Which Lift
- Mounting Beadlocks........Need Help
- getting more lift out of the teraflex 1.5" performance leveling kit
- TF 2.5" Installed.. have question about rear springs mounting position
- Shimmy when braking?
- Best lockers for the money
- Blistein 5100's
- Recalibrate after installing 295/65/18 on stock?
- Black Wheels
- ORFab Tire/Gas Carrier and TF CB mount
- Low COG fitting 35" tires
- '12 JK and Warn Elite Series bumper & winch install experience
- Can I re-use my gear oil?
- what is the black paint that can be used to coat rock sliders bumpers etc.
- REAR sway for 3" lift???
- Any secure trunk solutions w/ rain protection?
- Good wiper blades?
- AEV Hemi - Will a Charger 5.7vvt Work Well?
- Will caster cause death wobble/shimmy?
- Tire PSI Question Geolander A/T-S
- Spare Tire Carrier - without changing rear bumper - pics needed
- Steering Wheel Cover
- Smittybilt XRC amror fenders??
- Which Beadlocks, help!
- tire carrier help!
- Shock boots
- Help with chosing a lift!
- Help with Front Stubby choice! Or-Fab, Rock Hard, ACE, Rugged Ridge
- Help picking out an aftermarket clutch
- Tire/wheel size?
- muffler??
- Mounting a Rugged Ridge winch on a Rampage bumper
- Rims and spacers n such...
- Did I orient my front track bar correctly?
- bug net.. need help
- Diff cover clearance with RK trackbar
- Auto Trans Pan Leak
- Rear Driveshaft Needed on a 2012 2 door JK Rubi with 2.5-3.5" lift?
- prorock44 and PSC hydro assist
- Air Intakes
- Engo 10 000 winch REVIEWS updates w synthetic line
- Price for Ball joint install?
- black protection paint
- leather interior
- Nitto Terra grapplers?
- Vibration problems - helppp
- Cost of Matte Black Pait Job?
- (Almost) Complete Mod Plan for 2-Door 2012
- Who has instailed the Xrc rear fenders????
- Tie Rod Upgrade?
- XD Addicts Maintence
- 2.5 lift with 35"
- Airaid TB spacer for 2012
- Spark plug wiring...Mixed up????? Please help.
- JBA or Gibson headers??
- 37in toyos and bumpsteer!
- Rock Slider Painting?
- Do I need Adj track bars?
- Bedline Entire Jeep...yes or no?
- Looking for A/T tire advise
- Question about draglink flip kits?
- (Jeep Noob) I think I finally made up my mind
- Should I switch out 2.5 to 3.5 springs?
- shock extensions or shocks needed?
- Fender flares
- Rubicon express front track bar "CRAP"
- 35s on order
- final questions before purchasing suspension components...
- LOD mid width front bumper its on!
- TeraFlex Leveling Kit
- Aluminum Rocker Guards Opinions
- MW3 bumper winch help?
- Tailgate organizer ?
- At what lift point are new shocks required?
- rustys 3.25 advance kit
- AEV Drop Bracket BS
- Buddy just got a 11' JK4 Rubi, 35s
- Painting Center Caps Advice?
- A-Pillar Mount with Rigid light bar 50"
- Bushwacker Flats or Stay Stock w/ RK 2.5" lift & 33s
- Rock Krawler 2.5" Max Travel post-install questions?!
- No lift 2012 rubicon squeezing 35's
- How reliable are the spyderlock wheels?
- Is there a rule of thumb?
- longer shocks
- Changing out trac bar and LCA bolts.
- RE Shocks - Quick question
- Wheel question
- Smittybilt flares/fenders
- Power Programmer
- new balls/gears
- Got the 5.38's installed today -great experience!
- Bumpers from Ebay
- Next Mod?
- Pro comps, Pacers or Cragers
- Rear end squeaks only when i have a passenger
- I have a Steering Stabilizer problem...Need solution!
- Tire/Gas Can carier help needed
- Who makes this guard/cover?
- using a 2010 grill on a 2011???
- Banks CAI on a 2012 3.6L
- Do I need anything else?
- Rear sway bars with 3" lift..??? help please...
- Who makes this bumper?
- 5.13's & 305/65/R17 for 3-6 months...
- RCX Wheel
- Squeak/thud from rear after Daystar 1" BL
- Vibration at 80km/H
- Please take a FINAL LOOK fellas-PLACING ORDER TODAY FOR MY EQUIPMENT
- Steering Stablizer question for PR44
- recommdations for new shocks...
- Pulse Plugs
- Trektop NX vs ORH
- Trying to repair front frame trackbar bracket, help
- Death wobble questions.
- Vivid Superchips questions. Tablet or phone?
- Control arms
- PR44 and D60 with 38s-40s thoughts?
- CAI + Snorkel
- Aftermarket Tire carrier & 1.25" BL w/ bumper relo. brackets
- Kentrol Stainless Steel Door Hinge Set
- Teraflex Leveling Kit Sway Links
- River Raider JK Dana 30 Axle Gusset Kit
- Blisten 5100 Advice
- Ace engineering tire carrier and bumper
- Mamba OEM Look 17x8 4.75 Backspacing with 35s
- Ome 4" Complete Lift
- aFe catback exhaust systems
- Airaid Cold Air Intake
- TeraFlex-JK-Tire-Carrier - Any news on this for 37" Tires
- LoD Fullwidth bumper w/ tire carrier...
- Superchip Tuner Settings
- 07 axle problem
- RC XSERIES control arm length
- Dog 1 cargo pet divider 0
- Bad experience with daystar dash panel
- tire vibration
- tire vibration
- TeraFlex big brakes kit who has it? Is it worth it?
- Rugged Ridge XHD Non-Winch to winch mount?
- 2012 JKR TPI question
- Is a relocation bracket rquired for a Rancho Steering Stabilizer???
- How to flex your suspension on driveway?
- trektop hatchback softop
- Lift Kit Questions / POLL
- Fabtech Driveshaft Issues
- 2009 JK Hard Top
- lift with electronic disco sway bar
- Which axle shafts to buy???
- Jack stand question
- Suspension air bags
- Rough ride question
- 1" lift to 3" lift how to ? (best way)
- Tire Crisis!!
- Max height for front coil spacers
- Lift height, possible problem?
- build list 2011 jku auto
- 37" Toyo Open Country MT True Size
- Wheel Spacers - I need a no BS answer and help...
- Rough Country 2.5 lift. Spacers needed to level front with winch?
- Unloading superchips dilemma
- $4500 budget, my build in the making
- Evo Coilover, Double D advise
- Pitbull rocker true height?
- Best Mods
- Which Rough Country Lift??
- Rusty's Exhaust
- Cold Air Intake & Dust
- exhaust relocation question
- Over active ESP
- Quick Disconnects JK
- AEV Procal/Superchips question
- Gear Gurus noob in need of help selecting New gears.
- Grill Guard or not for Stubby Bumper?
- point me in the right direction (f-250 axle swap)
- housing question?
- rear locker advise
- Opinion On Specific Lift Kit
- Pit Bull Rocker Radial XOR
- tires
- Roof Rack Questions!!!
- Switching to 9/16 bolts, need torque wrench help...
- Teraflex BB kits
- Front end sagged, new springs needed?
- Final Plan: Tires, Lift, and Gearing for 2012 Manual
- Axle shafts
- Which axle shafts for ProRock D44 housing?
- track bar reinforcement??
- 2012 JKUR Auto, Gear and "Limp Mode" Questions
- Will a 2010 K&N CAI work for the 2012 models?
- Summer Build.
- which lift?
- 2" lift choices ???
- Dome light bulb size??
- First Mods
- New to this. Help
- body armor choices
- Atlas 2 and Atlas 4 (pros cons)
- Gear whine with 5.13 gears
- Ome shocks here, now what?
- JKU Superchip Questions?
- 37 inch BFG KM2
- Caster and pinion newbie question
- Teraflex 4 inch lift LA or SA? Pics? 2 door only
- Stabilizer shock leaking.
- Yokohama Geolander
- off road ability AND decent highway speed?
- Highrock lower cargo rack question 2dr
- evo rockstar skids question
- Grill mod
- Do-It-Yourself or Pay for Install? Brawler Rockers
- Angled Tire Carrier
- Anyone running Toyo MT 255/85R16?
- Testing out the new 5.38's
- moog tie rod alternative
- Best Tailgate Gear Holder/Bag?
- Anyone installed the TF RockGuard Rock Sliders???
- steering wheel wobble
- ProComp ES9000 vs Bilstein 5100s
- Driveshaft
- Rock Krawler Kit 3.5 Max Travel system Vs All other Lift kits.
- Air compressor
- Superchips on 2011
- Ramsey Patriot 15000
- My new setup advice
- Tires and Wheels??
- New to lifting need advice
- Am I getting a good deal? $$$$$$$ 3300
- What 35s are the lightest
- Alignment question
- Tube Doors , any recommendations
- Mounting bolt size for warn power plant
- Tire Carrier Help
- Track bar or CAs?
- Fender chop
- What would be a good non-powdercoat armor finish?
- Will the new protek skids work with LOD sliders?
- Just installed new steering components...initial thoughts
