View Full Version : Modified JK Tech
- Need Traction Aid
- Anybody Running 52126319AC Coils?
- Anyone Running OME "Light" kit?
- No rear bumper?
- Trail Grappler
- Spacers alone for 1.5" lift?
- Choosing a LCA
- Yes ANOTHER noob tire and lift question
- What's the point of an oversized tire carrier product?
- 305/70 R17 tires on stock Sahara wheels
- Corbeau CR1 Seats
- Question about EVO Lower Control Arm Skids
- Any opinions of these wheels?
- Need some help, bushwacker pocket style fender.
- Thinking about drilling my hardtop, need advice
- Labor cost to regear
- Wheel Backspace Question??, Could Not Find Answer Searching
- how to test if you need extended brake lines
- How often should bolts be retorqued?
- cheaper parts
- Do I need an alignment?
- lets talk about headers
- New Muffler on a 2012
- Lift Question
- Track bar advice.
- Augh!
- Replacing all LCAs and Trac Bar Bolts..Can i do it without raising my Rubi?
- Did I Make A Mistake?
- Identifying a gear set?
- Bumper Decisions
- Is the XRC aluminum fair lead coated?
- Will a lift void the warranty?
- Top off with tubular doors. Are side mirrors really necessary?
- What size bolt is the top one in the rear shock?
- Driveshaft question
- Help me complete my set up plx
- Teraflex 3" with spacers
- Need pic's of 2.5" lifts with 33's JKU 2012 Sport
- Iggee seat covers
- 285/70r17 Duratracs on stock Moabs--Is this article true or bs?
- Shocks
- Need help
- Confirm my thoughts?!
- Bolting a security box down but maintaining easy removal?
- cut pocket flares ?
- Shocks
- Anyone ever bust a Prorock 44?
- Nitto Tire Question
- Seat covers
- For Sale thread?
- FYI Rough Country is now offering exhaust Spacers!
- Superchip flashpaq
- Have to replace one tire due to puncture others more than half tread. Is this a prob?
- Axle breather extension
- Upper or lower control arm adj for Caster
- Do 15" wheels fit on the jk or not?
- body roll?
- body roll?
- Teraflex 2.5 Rear Speedbump Bumps Stop Kit
- I think shes lower in the front...
- 3.5" lift questions
- MBRP Exhaust with Hushpower II Resonator
- 35's on stock Rubicon 4 Door
- Will i need spacers?
- Sport 4-door suspension on 2-door model?
- Fender flares/wheel wells
- Steel wheels????
- Tall riders, seat height
- seat covers which ones?
- Nee help - Teraflex PreRunner
- Correct Rancho shocks for 2.5" lift?
- Maximum articulation with minimal lift? What to do next...
- 4.5'' shocks on 2.5'' of lift?
- RK 2.5 Max Travel - Will TF Exhaust Spacers Be Enough
- brake lines rubbing
- offroad evo envy links?
- Different gears in front than in back????
- stinger stubby bumpers
- 35" fit on stock wheel help
- Qaudratec Floor liners question
- zone offroad exhaust extension
- Ripp charger and Liquefied Petroleum Gas
- Oil change question
- Can I swap wheels with my '97 TJ?
- Adding Steps to 4D 2012 JKU with OEM Rock Rails already installed
- 4.10 non rubi?
- Just drove 2012 JKU Auto 3.73 stock and then one with 35s
- New Drive shafts or not?
- Superchips Flashpaq for 2012
- Wheel well mounts JKU
- I need advise on shocks to match HD OME.
- Tires tires tires
- Goodyear MTR/K
- Is Rear Track Bar Adjustment Required on 2" Coil Spacer BB?
- Offset Question
- Just lifted my jeep now a driveline question
- After Procal question. 2012 auto on 4.10's and 35's
- What gear ratio for 32, 33 or35" tires (2012 unlimited)
- Reliable Locker Recomendation??
- best lift under 3inch
- Spidertrax spacers "must"
- Ripp Supercharger tune
- going from 35x12.50/18 mt's to?????
- PRESS RELEASE: JSPEC™ Suspension Products
- Quick Question...
- 2011 JK - At what point would I need extended brake lines?
- Pro comp 4" lift diy?
- Center both axles with just adjustable front track bar and a rear relocation bracket?
- New Lift and Dash Warning Lights Help
- Rear corner armor
- 25k miles and tranny is shot
- Really need some help please...
- Different Gear Question - Towing + Auto + Gears
- Question for RIPP 2011JK owners
- Tpms
- CAI intake question.
- 2.5" Coil Lift w/ 1" Spacer Lift.. Can I do this?
- Yj shocks on a JK?
- Natural gas conversion
- Duratrac 315/70/17
- Wheels, Tires and Wheel Spacers
- gear question
- SRC side armor smittybilt mounting
- Lift Required?
- How much bumpstop for Teraflex 4" LA?
- gear manufacture strength
- A little shimmy
- RK 5.5" long arm with coilovers
- Overdrive off with stock gears?
- Anyone change 2012 muffler?
- Eaton Lockers
- Hardtop Options
- 17" Wheel Backspacing
- Demon collector bolt issue.
- evo lever question
- Need Bumpstop advice for my Rock Krawler lift!!!
- Gears and Warranty
- Recommendations for CAI, Muffler, and Programmer..... Please!
- Front running turn signal problem
- " rock keys " is anyone running them in the jk?
- Another Rubi suspenion transplant question...
- Terraflex Disconnect Installation Question
- Building Hard Top
- Need Some Help: Correcting Front Suspension Sag After Bumper (Pics Within)
- Dana 44 front 35 Spline Axle Seal
- Airing down with wide tires and stock Moabs?
- Will this lift also LEVEL my Jeep?
- Teraflex vs JKS quick disconnects
- To lift or to wait
- AEV Procal and 33's?
- What Lift Kit to Pick! Spacer or Coil Spring
- 3.73 and 32's or 33's
- RK 2.5 max travel did I get the wrong shocks??
- Tuffy Tailgate Security Enclosure for 2011- - ->
- Bestop Underseat & InstaTrunk for a 2011- ->
- Fender Flares? Metal or Plastic?
- Safari Straps Question
- magnaflow axle back vs dynomax rockcrawler exhaust
- neoprene seat covers
- Leveling out my rig
- Mathematics of Wheels, Tires, and Diffs
- Anyone have pics of Safari Top and Bar on 4 door?
- mpg estimate
- Which Bilstein 5100's up front for a TF 2.5 coil lift?
- Spare tire removal?
- Borla exhaust
- Will it fit??
- Mid arm or long arm?
- Steering arm brace problem WTF
- RuggedRidge 3" Side Steps - any good?
- How to get a procal help
- Thinking about attempting gear swap.
- diesel
- PSC Rocker Knockers With TereFlex Long Arm Lift
- Project Trinity
- Rough Country Performance 2.2 shock upgrade
- Where to put my 60" Hi LIft Jack ....
- Rubi coils/shocks on 08 JK 4 door?
- Spacers / Wheels or both
- To keep inner fender wells or not?
- Adding a stinger
- Larger tires on 2012 JKU question
- Need help with stuck Jam nuts
- Hitch height - change after 2.5" left and tire change?
- Typical tread-life on a Mud Terrain tire?
- RIPP "SDS" Supercharger Drive System GEN2 Install.
- Skid Plate Question
- 17 Wheels & Tires
- Gears
- Who has this bumper?
- Lift recommendation for 2011 JKU
- Rotional clicking noise: not driveshaft boot
- Want to add coils in front on a teraflex budget boost
- Rock Krawler 2.5" Max Travel Bumpstops
- Death wobble???!
- Smittybilt src 3" tubular side steps
- Dash Mount Bracket
- Front tires not aligned?
- Snorkel Question
- Broken shock bolts, unable to complete my lift instal
- does anybody know of a plug and play skid plate to attach to aev front bumper 12 jk
- Where to mount a large inverter
- Shock extension
- Help! Rubicon express quick dicos
- AEV Procal Tire Sizing
- P vs LT Nitto Terra Grapplers...
- Trektop question...
- Any thoughts?
- Finally have my entire list. Please tell me what I forgot and answer a question.
- Advice please
- What BB is comparable to RC Series II?
- Need help fast
- PSI on 285/70/17s
- Trektop as a winter top?? as well as....going rate for a used Hardtop???
- 2011 automatic vs 2012 automatic gearing
- K&N
- tube style doors
- Daystar lower dash switch panel 11-12 JK's
- Rubicon Express 3.5 Super Flex Short Arm Lift
- bedlining the tub on a jku.
- Continental Contitrac tires
- Tire balancing?
- Boost Gauge RIPP Supercharger
- Suspension and OE Warranty
- Steel coil spacer question
- Rock sliders choice
- wheels ?
- JK Body lift or chop fender flares?
- JK Transfer cases
- Which Smittybilt Winch
- Anyone run a double front track bar?
- Aussie Locker Dana 30
- Storage ideas
- Trouble filling Diff fluid
- Which driveshaft
- 315/70r17 or 35/12.5r17 Nitto Trail Grapplers?
- 3.5" RockKrawler Max Travel System vs. 3.5" AEV DualSport SC Suspension
- Help me find the bumper im looking for!!
- vdp stubby ends and rr factory look light bar
- DiabloSport Trinity or Superchips Vivid
- Can you help with bumper choice?
- Need a Tire carrier that holds a 40
- Garage clearance
- Reverse install of shocks?
- Stock or JK Big Brake Upgrade? Advice Needed ASAP...
- Adding a tranny cooler - will I need more fluid?
- Dana 30 ARB diff cover and oem tbar
- Plastic weld epoxy
- RK Leveling Kit--Help
- looking for solid white steel wheels!
