PDA
View Full Version : Modified JK Tech
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 [190] 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296
  1. Aftermarket bumpers/airbags
  2. What does the Lube Tube in the Tcase adapter do exactly?
  3. Differential Protection
  4. Spare tire spacer. Which one to get??
  5. Old Man Emu or 2.5" Teraflex
  6. Actual height of Goodyear Duratrac 315/75/16 ???
  7. $6,000 U-Joint Repair?
  8. New bushwacker flats and OME shocks on and OME lift question
  9. Which Long Arm System and Why? PROS and CONS
  10. RUBICON EXPRESS CHROMOLY DRAGLINK help
  11. Air Horn
  12. Dropped of the JK for gears today ...
  13. Budget boost VS standard lift
  14. auto tranny not shifting correctly after battery disconnect
  15. Caster Degrees? Stock then to 4" Lift and 33'S........
  16. 35's and towing 3200lbs of camper
  17. Mirror Relocation Kit
  18. Toyo Open Country MT vs. Mickey Thompson MTZ? Which one ?
  19. Will not changing the gears hurt anything?
  20. RR winch opinions?
  21. LOD shorty rear bumper with flat Bushwackers?
  22. Front axle bent - How to tell?
  23. Reason for Regearing
  24. Rust on Shock shaft?
  25. B&M Supercool 70268 Tranny Cooler - Install Question
  26. Rear Recovery Point - Rubicon w/o Receiver
  27. Newb tire/wheel question
  28. 40s for $300
  29. Bulldog Winches?
  30. Daystar Tailgate bump stops
  31. ARB or VIAIR
  32. what should I pay for set 538s on rubicon
  33. down side to gears?
  34. Wheel spacers? Dangerous or BS
  35. How STRONG is this HighRock 4x4 RACK
  36. question about aftermarket ss
  37. anyone have this bumper?
  38. Lift and alignment
  39. LoD slider w/ stock rubi rails..
  40. New Trail Master 3" Lift
  41. Rewiring Rubicon Lockers
  42. Smittybilt xrc8 question
  43. Snork or CAI
  44. Rim help
  45. Anyone running the Tera LCG 3" kit?
  46. Advice for onboard air
  47. Rusty's---good stuff?
  48. Too Fourty or Not to Fourty... That is the real question
  49. Can a bent SS cause pseudo death-wobble?
  50. Transfer Case Gearing
  51. Another gear thread 5.13s & Dana 30. . .
  52. Question and pics needed
  53. most important gauges
  54. Am I correct?
  55. Where are mud grapplers and spidertraxx made?
  56. Rocker skin/armor, Poison Spyder or Offroad Evo?
  57. Anyone have pics of Iggee Black/Gray seat covers?
  58. Death Wobble... Really need help
  59. Do I need spacers
  60. M.o.r.e, XRC or SRC bumpers (front & rear)
  61. Hybrid design exhaust?
  62. Need to know what lift height I have on a rig we just bought
  63. Drive shaft advice !!!
  64. Gussets and sleeves
  65. Alloy Axle Shaft Upgrade
  66. Newbie Tire Question
  67. Supercharger
  68. Fluid Recommendation for Gear Break-In Fluid
  69. Shrockworks sliders on rubi rails
  70. Anyone removed rear sway bar ...
  71. FYI: 15" Cragar V-5 fit with no rubbing
  72. CAI Issues
  73. help me with a bumper/winch combo????
  74. Stock soft window tinter?
  75. Arb compressor won't shut off air leak
  76. Unlock a Superchip
  77. Synthetic winch rope choices
  78. Maxxis creepy crawler
  79. Detatching the drag link from the pitman arm (any suggestions/tips)?
  80. Third row seat in a JK
  81. What to do?
  82. Tire carrier bumpers that swing w/ the tailgate??
  83. Superchips vs. AC
  84. TeraFlex 2.5" Coil Lift with Shock Adapters Question
  85. Hemi = more towing power..?
  86. Olympic" Smuggler" feedback
  87. Rear Bumper/Tire Carrier combo
  88. Winch Mount Show them OFF
  89. Aftermarket rear seat replacement
  90. Tom Woods Driveshaft Vibration
  91. Stock Rubi 255s on 17"x9" Pro Comps
  92. Rugged Ridge Mirror Relocators
  93. Goodyear MT/Rs w/Kevlar thoughts after the first 5k
  94. Recommend Auto body wrap?
  95. Have a TF 2.5" lift, want to replace with TF 3" coils what else do I need?
  96. new guy with a bumper question
  97. need your opinions....
  98. PitBull ROCKER bias ply 37x13.50x15???
  99. Anyone know what this is and what it does??? HELP
  100. Mouting Warn 9.5XP on LOD Mid Width - Help
  101. My rear tailgate starting to go?
  102. 35s, TERRA GRAPPLERS VS OPEN COUNTRY'S???
  103. Rubicon Express Radius Long Arm Kit
  104. Rancho 4" Sport VS Teraflex 2.5 Coil Lift
  105. inner fender removal
  106. Wheels with 5.00 backspace and 12.5 wide tires?
  107. Anybody know of a good 37" tire for my 2door ???? Will be used as an every day driver
  108. Whats up with the Warn 9.5si?
  109. Olympic" Smuggler" feedback
  110. TF 1,5" Leveling kit or 2,5 budget boost with 33's???
  111. Issues with soundbar cap and wraparound windjammer on 2 door
  112. Do i need a steering stabalizer?
  113. This is what I am ready to purchase for my lift! Any suggestions?
  114. Jeep warranty?
  115. Which wheel to get????
  116. Xenon Flat Flares Painted or Not
  117. upgrade to 245 75 16 Any thoughts?
  118. What's an over all better tire nitto mud grappler or the pittbull rocker in size 37
  119. Superchips data logging for auto trans temp and engine knock/ping?
  120. Hawse fairlead with wire rope?
  121. Stubby bumper mod end caps
  122. Bushwacker fenders
  123. new tires of same size=steering wheel off centre
  124. 4" rancho sport lift?
  125. Greasing teraflex sway bar links
  126. A little overwhelmed....
  127. dealer reflashed my computer and turned off all my esp, bas, abs, trac-control :)
  128. Off Road Evolution rear corner armor
  129. I have a dumb question
  130. Shocks-best ride-smooth-non jarring??
  131. Harken Hoist a top question ?
  132. 35's or 37's? Wil 37's actually fit?
  133. Question for JKS front trackbar users
  134. Geolander M/t's
  135. Snorkel and mirror relocation brackets?
  136. Hitch made, Carry-all.......Check it out!!
  137. I NEED SEATS! Advise Please
  138. 35s and 513s..Add a Calibrator or Tuner???
  139. B&M Hi-Tek Automatic Transmission Coolers or Derale
  140. Utility/Cooler Rack on WARN Carrier
  141. I told the wife I wanted to start using protection.
  142. Rookie Question
  143. Best sized tire for 16x8 wheel and figuring out backspacing?
  144. Kelly Tire Safari TSR
  145. 2010 JK mod questions
  146. Evolution front coilover question?
  147. 285/75/16 Duratrac proper tire pressure?
  148. Rancho Tube Doors....... Badass
  149. Max size tires on stoke 16" wheels with no lift
  150. Lost evap canister last night
  151. Newbie question
  152. Back seat swap
  153. Noob Body Lift Question
  154. Removing lift, can Adj trac bar stay?
  155. From 4" to 6"...Components?
  156. 2dr congo cage questions URGENT
  157. JK Dana 44 front carrier options??
  158. Best 35's for Street & MPG
  159. Another 37" wanna be post
  160. Stock Driveshaft on 2 door with lift question
  161. Body lift question
  162. HD Tie Rod Flipped over the Knuckle?
  163. About to take my Jeep to dealer...
  164. Our 08 Rubi w/ upgrades so far
  165. Bushwacker flats on the way!
  166. Wheels (opinions needed)
  167. Skid Plate / Armor Priority Recommendations
  168. Son of a M&*()&&()( (Stripped my mirror)
  169. Sway bar disconnect question
  170. Rough Country 3.5 lift kit new
  171. Big Problem installing Benchmark Oil Pan.
  172. bedliner sound bar
  173. Punctured Goodyear Duratrac tonight
  174. Help with getting mud tires and rims??
  175. Cutting the pinch seam
  176. Jk daystar arms ?
  177. Long Arm Kits....What one?
  178. Daystar or Teraflex level kits?
  179. Thinking about Synthetic winch cable and have questions
  180. Fender rub and full flex?? Will bumpstops help?
  181. modify tail gate door handle
  182. $700 or Less Lift and 37's? Without sacrificing ride quality and drive shaft mods
  183. Looking for info on Kilby skids
  184. My lift plans...(Frankenlift)....see any problems?
  185. Teraflex 2.5" lift
  186. Heavy Duty Springs Recommendation for 2.5" lift
  187. Can I use spacer w/ Skyjacker 5" lift?
  188. Un-even tire wear!!!
  189. Superchip setup advice
  190. dirtydog4x4 smittybuilt cres mopar soft top help
  191. 37" nitto mud's what would be the best size rim ????
  192. 1" M.O.R.E body lift to reduce floor heat
  193. How long are vent lines on Tcase and Front axle and where do they go?
  194. Your Spare Tire
  195. Help Front Track Bar too long...
  196. Anyone here go from Fender Chop to Bushwacker Flat Flares?
  197. MPG help???
  198. Tire rub (inside)
  199. 4" Lift with Fox Racing shocks What to do?
  200. odd popping
  201. Fox or King shocks?
  202. Mamba M5 Rims
  203. Rock Hard Oil Pan, Transmission & Dual Catalytic Converter Skid Plate
  204. Yet another steelie wheel question
  205. Bushwacker Fender Flares with 33s ?
  206. Steel or plastic Flat Flares
  207. Would this 4" lift set-up work for me?
  208. Help Me Choose Some Shocks
  209. What size will work
  210. Tera Flex leveling kit
  211. Rough Country 3.5"
  212. Mickey Thompson MTZ vs. Nitto Mud Grapplers
  213. Thoughts on proposed setup?
  214. Looking for power!
  215. Control Arms for the Rear
  216. exhaust, power increase?
  217. Spiral air intake
  218. Good deal on CoverCraft Neoprene Seat covers from JC Whitney
  219. How can I improve the MPG in my stock Rubicon unlimited?
  220. Rubicon Express 3.5 super-flex install ?'s
  221. Wrinkle Paint
  222. 275/65/18 Tires? Load Range E?
  223. Wheel Spacers
  224. Rough Country Suspension lift vs. TeraFlex Lift
  225. Lift Install Questions
  226. Weight conscious?
  227. Help with seatbelt light
  228. What size holes in your XRC front bumper do you have?
  229. Trailmaster 5"... Now esp nag
  230. When to add control arms?
  231. jeep feels like it's bottoming out
  232. Procal programmer worth the $$?
  233. Mod under $50 - Birthday Ideas
  234. 5.13 or 5.38's for auto 4 door with 35's
  235. Thoughts on the new Rough Country 3.5 lift.
  236. missing plastic cap...what would you do?
  237. Low Tire Pressure Alarm
  238. Questions about lifting and tires
  239. Exhaust removal......
  240. D30 to D44 Axle Swap Using MOPAR Parts
  241. Mopar off-road/ olympic defender
  242. Superchip
  243. Weld-on Rock Slidders????
  244. What is this Jingle!!!!!!!!!
  245. Front driveshaft
  246. Pure Jeep Rocker Guards & Aftermarket Fenders???
  247. Inline muffler along driver's side?
  248. OME HD LT vs OME HD LT +40
  249. front coils 1" spacer install
  250. Lower Control arms install concerns?
