View Full Version : Modified JK Tech
- 4bt cummins swap
- 3 inch body lift?
- Rock Krawler 2.5 max travel
- Poison Spyder Rico Step DIY Kit - Opinions?
- 35's on 16's vs 35's on 17's
- im looking for dark black rain deflectors
- K&N Cold Air Intake
- Leveling Kit
- Wheel spacers with AEV pintlers.
- Help me pick the perfect front bumper.
- Bent Housing...now what?
- Adding a 2" receiver to the front of the JK.. ?
- Rubi or Sahara
- How Much Weight Before Having To Level (Pic Attached)?
- Master Overhaul needed at 5K?
- Genright Spare Tire Carrier or Poison Spyder?
- '10 Rubi, 35" duratracs, stock 4:10 gears... is it bad?
- full traction vs rock krawler
- Why some fairleads are not centered on some bumpers and some are centered?
- Jeep leaning with teraflex lift
- TF Performance Level, do I need spacers to run stock rims/tires?
- Fire Safety
- please help with gears
- TERAFLEX brake master cylinder question!!
- What fire extingushers are these???
- Muffler with some back pressure?
- Super Flow / SmityBilt MV-50 plus under-hood mounting bracket.. from the same vendor
- Nitto Terra Grappler AT vs Goodyear Duratrac opinion
- No Good 5G Scepter Fuel Can Mount for AEV Rear Bumper & Carrier
- Interco Super Swamper seperation
- Best mod yet
- Is anyone running this centerforce clutch?
- 2.5" + 1/2" or 3/4" coil spacers
- teraflex 2.5 lift?
- How much lift do i need to firt 325/65/18??
- Simple question about Rough Country's JK Front Bumper
- AFE releases a 2012 Loop Delete in addition to their Y Pipe..
- ESP wheel trick
- Supercharger Wiring Issue
- Anyone running one of the JKS lifts?
- Teraflex 2.5 or 3 with Saverge Wheels
- bolt-on front track bar bracket?
- Terra grappler
- Springs and shocks
- 4.5 vs 5 backspacing
- Leveling kit & spacers?
- Will it fit?
- OME HD w/ AEV components??????
- Question on Duratrac tires (275/65/18)
- Can anyone recommend G2 gears?
- PSI Chalk Test/PSI or Allignment or...
- 4in lift=new driveshaft?
- 2012 JK 2DR Front end creaking!!
- stock bumper mod
- Tuffy security drawer?
- My Hemi swap
- 2011 TPMS same as the 2012?
- PSC crusher question
- Newb suspension question!
- need help with new rims!
- Aluminized vs Stainless
- Help with a stock Jeep
- stretched brake lines
- Question about wheels
- Expedition One Rear Bumper with Tire Carrier
- Mopar Tubular side Steps
- Hardware needed to mount Rubi Rails?
- AT Tire or Mud Tire?
- Bilstein 5100s for 3" lift?
- 40s lift info
- Which Mud Terrain-Wrangler or BFG?
- 2dr 2.5 lift with stock wheels and tires??
- Rubicon step for wife. Not for rockcrawlers.
- rubicon with 2.5 lift, and stock tires?
- Money to burn...but how?
- Are 35's really 35 inches tall?
- Picked out my LSD have one more question....
- Jks 2" lift
- Tire size on a 2008 Sahara
- new tire options
- Rough Country 4" X-series Suspension????
- Anyone install Star Fab Smart Door Stops ? Feedback please
- EVO MFG 4" DoubleD JK Bolt On Long Arm Kit
- Quadratec rear cargo liner??
- Need help telling if my Warn Locking Hub is bad
- Tips for Removing/Repairing Leaking Transmission Lines?
- What light bracket/mount is this?
- Tinging/pinging when in gear
- rusty's 3.25 lift kit?
- Disconnects question?
- JKS Steering Stabilizer Rubbing
- Tire help please!!!
- really disappointed in bestop, are there alternatives?
- Need advice
- EVAP Canister
- Build List. Need Comments. Thanks!
- Will you help me pick my rear end?
- Steering stabilizer recommendation
- Does Your JKU Budget Boost Sag To The Right?
- Upgrading to a Long arm kit
- HighRock 4x4 Slider Step
- Tube fenders
- Avg price labor for lift with shocks, front arms, brakeline relocation?
- If the OD is the same?
- Need help picking a locker for my non rubi D44 seriously, so many options......
- $450 to spend need some help
- JBB Mfg hood latches
- So about installing the OR-Fab tire carrier...
- Finally lifted, new tires, re-geared --- now how do I tune?
- best bumpers ????
- tpms
- New Bumper/Tire Carrier Question??
- RIPP Header Question
- Anybody have an electronic guage on your 2011 JK?
- Big voltage drops winching: new battery or duals?
- AEV 3rd brake light ideAs
- lifted jeep steering question
- Electronic swaybar help!
- Thoughts on bumper selection and mixing bumpers
- Newbie needing help...
- Ripp Supercharger won't pass TX emissions
- Warn winch dissembly
- 2012 JK with 2" RE BB
- trailer hitch
- 315/70/17 with no spacers safe?
- 5.5" backspacing, enough?
- Smittybilt XRC or LOD Front bumper?
- Fitting tire chains
- TF 2.5 coil lift / Questions
- Looking for Opinions on Grizzly Lockers
- Stock sway bar links with 2.5" lift?
- tires!!
- What Size Torque Wrench?
- Teraflex 1.5 coil levelIng kit tire/wheel question!?! Help!
- 2011 for 2012
- Wheel questions
- Teraflex upgrade from 2.5"-4" Lift
- Rear Winch Inside
- Rough Country spacers-lugnut issue
- Help me understand gears and ratio's
- humvee wheels on jeep
- Really need input on regearing.
- Which wheels???
- aFe Y Pipe does not fit 2D 2012 JK
- help identify some things for me
- Got to look at the new Mopar parts catalog a little today, some cool JK parts!!!
- Tools for a Lift
- Need help- 18X10 Moto Metal 961's OR 18x9 Procomp 7005???
- 15" Allied Raceline Beadlocks
- Carbeau or mastercraft seats
- TF BB...shocks or shock adaptors "required"?
- Help! Magnaflow offroad exhaust doesnt fit?
- Rusty's RX-300 Shocks
- whats a good 35inch tire 4 my 09 jk
- Installing headers...other additions to the exhaust system?
- Bumpstops
- Diff covers compatible with skyjacker lift
- Auxillary Bumper Light Advise/Recommendations Needed
- XD Rockstar Wheels with a twist
- New owner - need some wheel / tire advice
- If you have a TF 2.5" lift on 2dr, I need your help
- Which shocks with an AEV 2.0 spacer lift?
- Fenders
- trash or treasure
- Roof Rack Tire cage compatability
- 2011 auto on 4.88 top speed 37mph???
- Ultimate 2" Lift, Dumb Questions will Follow
- wheel spacers vs no rear swaybar...
- Recon 17500???
- Stubby bumper with hitch
- 2012 jk 3.25" lift question
- Brush Guard and stinger
- 37's with flat fenders+daystar boost
- Recon In Cab Controls
- Sleeve and Gusset question Please Help!!
- Power steering issue...please help
- blacked out grill
- AEV Nth Sliders Dana 44, anyone use them?
- Where to mount winch solenoid?
- 2.5 on 37's
- Does this geometry look correct?
- Which skid plates first?
- How do I know how long brake lines should be?
- Mopar Locking Gas Cap (matches ignition): $74 + $50.
- Swaybar link dilemma...
- Anybody know anything about this bumper?
- 4:88 vs 5:13 for regearing my jeep. Need some advice please help.
- Superchip advice
- Ready to install Currie UCAs on JKU
- Rubi Springs + Flat Fenders + 35's
- OR-FAB vs. Rugged Ridge
- TFX performance exhaust
- Nitto trail grappler
- rock hard cage fitment issues
- Installing an aftermarket bumper
- should I lift even more?
- Procomp 8069's backspacing question.
- What is an oversized tire?
- Rugged Ridge 8500 VS Smittybilt XRC8000?
- Decisions, decisions.
- 2012 JKU Exhaust Resonator Skid??
- JKS Front Trackbar Brace - Pic Request
- removing sway bar link- Advice please
- Which Tube Doors?
- Trektop nx
- GPS vs. SpeedO
- 20" monsters and 33.5 duratracs
- what to search or post up here
- Teraflex Monster Front Trackbar Issue
- Offroad LONG ARM UPGRADE
- 3.5 rk caster question
- Painting chrome rims?
- Rough Country Suspension
- Tpms ?
- Tips or tricks on the OR-Fab tire carrier?
- Steering stabilizer inadvertantly removed
- 3,500 rated chain enough for winching?
- Step w/ Rubi rails
- About to install 1" spacer up front.
- Procal Help
- Front Lower Control Arm Install Questions
- 35x12.50x18 toyo open country tire pressure
- Locker Light Flashing after regear install.
- 2 dr back seat removed - unique ideas
- Gears and Diff covers
- Warn Elite bumper on 2012?
- Soft Top, Half Top for JK?
- Oil pressure gauge question
- xenon flat flares lets see some pics
- Smitty Situation... Lift and nothing to step on :(
- American Off Road Dual Tip Performance Cat Back
- throttle body and k&n cleaning.
- Do these charges look ballpark for these mods?
- Need some mpgs
- 35" Tire Advise Needed.....
- WARN rock crawler v.s. Rugged Ridge stinger
- Help to surprise a friend
- Anyone have the Daystar Cam Can?
- smittybuilt xrc front bumper
- Rugged Ridge front bumper light bar moves around
- Frozen/dirty door handles....ugh!
- flat fender flares or pocket style ?
- Trying to figure out lift kit terminology...
- Thread read overload- help with lift for 2012...
- Choosing an on-board air system..
- Help for Deep Water Driving
- Anybody running the old Hutchinson/Mopar JK beadlocks?
- Spidertrax vs Rugged Ridge wheel spacers
- Shock length help
- Kind of ramdom
