View Full Version : Modified JK Tech
- Installing a lift for the first time
- 15 inch wheels?? On 2011 jk unlim???
- Rancho rear bumper and carrier
- JeepSwag Cat Back Exhaust.
- Ok I need help w/ my Heavy JK and rear suspension.
- Exhaust Question
- Rugged Ridge Opinons
- New bumper and winch question with stock rubicon suspension
- So Much for my LOD Gerry Can Mount(s). :(
- Found a Tire that I Like, BUT.....
- GY MTR Kevlar 35's Load Range C ?
- Winch Question
- 5th Wheel
- Mod Suggestions - Ride Quality
- Advise needed on JKS Adjustable Control Arms
- Rear Axle Shaft???
- Exhaust Question!
- Will my JKU be level with a 1.75" spacer lift?
- 2" skyjacker, finally got it !! anything I should be aware of or look out for ?
- AEV 3.5" Premium w/ 35" BF KM2s rub?
- 2008 JK Rubicon Unlimited Lift??
- Pulling left when braking
- gear now or later?
- Oil pan skid
- Shocks and Bump Stops Question
- Drive shaft upgrade options
- Will upgrade locker require readjusting ring-pinion?
- ox lockers. the good, bad, and the ugly
- Stock Unlimited Rubicon rear sagging with new bumper and larger spare
- RRC light bar killing my mileage?
- Eaton TrueTrac vs ARB/OX
- Help me upgrade smartly
- Re-gearing question
- How wide are the Bushwacker flat fenders?
- Upgrade stock Dana 30 front axle to mopar new gen Dana 44
- ARB aircompressor
- appropriate tire pressure for 275/75 GY Duras?
- ultra motorsports wheels?
- Warn tubular bumper winch plate
- Aeroforce interceptor vs. Flashpaq?
- Rough Country 15" Steel Wheels
- Removing shift knob on manual
- 1 1/2" wheel spacer question
- What's the difference between a spacer lift and coil lift?
- Any recommendation for Superchip Settings
- Viper Throttle Body
- PRESS RELEASE: PUREJEEP All NEW Jeep JK Wrangler Skidplates
- Help with alignment (Caster/Camber questions)
- Steering not straight after Offroading !?!
- SuperChip Flashpaq
- What's your MPG?
- Superchips Flashpaq
- 1.75" spacer lifts - Need your opinions! And pics!
- 33's or 35's
- wooden steering wheel
- Need ARB install manual and info
- 2.5" teraflex coil lift + 1.75" rear spacers...or any suggestions
- ARB, AEV, LOD, and Rugged Ridge Bumper Rub Questions
- TeraFlex 2.5 lift with shocks/springs
- Manifold Vacuum Gauge
- 35s or 37
- Adjustable trac bar? Which one?
- ACCU PRO Speedometer and Odometer Calibrator - Jeep JK Wrangler
- MB Wheels? Good or Bad?
- warn 8000 question
- up-grade help
- rear drive shaft?
- 0-2 inch JKS discos with 2.5" Teraflex Coil Lift
- Tackling Evo rock skin install, any tips?
- does PSC sell a working kit for 6 speed?
- 2010 can you change diff. from non lock to lock
- help removing seat adjuster please
- Experiences w/ Superchips Flashpaq 91 Performance Tune
- Rugged Ridge Seat Vest
- Tow Bar using D-Ring Brackets
- Mamba MR1 rims are in fact hubcentric !!!???
- Pro comp 7189 or eagle alloy 185?
- Help: Teraflex rear sway bar link install
- Poison Spyder Bumper Opinions
- 35" Spare Tire mount
- Looking for a good set of coil spacers....suggestions?
- Rim questions?
- BDS suspension????
- Trailmaster Suspension
- Rear Brake line rubbing on shock TF install
- CV Drive Shaft or Regear, which one should go first?
- Why are cam bolts bad?
- LOD rear tire carrier question
- Double check my setup / Lift / Rims / Tires
- MT or AT tires??
- Regear with the Dana 30 or scrap it completely?
- RIPP whats the difference between the gen 1 and gen 2
- Teraflex brakes kit
- Pin size for d-rings on ARB bumpers?
- Anyone customs their rear seats of a 2dr JK?
- Dana 44 Breather Hose?
- Rusty's coil springs! How is the ride?
- 5.13 gears with Dana 30
- Rock Krawler 2.5 Stock Mod Lift Kit
- best jk rear bumper and tire carrer for under $900
- TN/KY Laws
- Flat Fenders
- Shocks
- Next Step...
- Pics/opinions about rear bumper/tire carriers.
- Airaid MPG Decrease??
- About had it with Superchips installation...
- i need help!!
- MPG with 33's and 2.5 lift
- Teraflex leveling kit in Canada ?
- Rubi unlimited and 37's
- Looking for new tires
- Dynatrac 'Unlimited' PR44 caster
- Ready for a CHANGE!
- How do i get these pics of my jeep as profile pic?
- Spare tire
- Wheel spacers
- who makes the best crusher type corner for a 2D
- Lifts and Suspension for JK Rubicon Unlimited? Suggestions?
- Rear Deck grommets
- Trying to install rock rails have problem
- All-terrain tires offroad?
- Steering stabilizer bracket...
- Making Changes
- Hi lift jack or AEV jack base for 35's?
- Old Man Emu = level ride?
- Regearing and Gas Mileage change?
- another stupid question
- the best steering stabilizer ???
- new tires that might hit the frame
- what to do next??
- rough country lift and stock/ drop pitman
- 15-12 wheels
- Gas Milage
- 33's
- Who has the most complete 2" lift under $700 ?
- Warn high mount winch shorty bumper
- Calling All Shrockworks Mid-Length Front Bumper Owners With Winches!
- Wiinching times
- Death Wobble? Im not sure?
- dana 44
- figured out what lift i have!!
- Warrior Adventure Rack
- Removing Front Bumper Bolts
- Rugged ridge front bumper w/winch!
- Flashpaq for 2011??
- Tire advice please... Changing from 33s to 35s
- Do i need spacers?
- What order should I build in?
- Help deciding on a drive shaft
- Getting new tires
- Front Axle Shifted Off To One Side, Need advice
- License plate mounting options on a front bumper?
- Got my new tires and wheels on today!!!!
- lift questions
- 3 inch lift installed, but what size tires do i use?
- 2011 Rear Bumper
- 44 upgrade
- Bikini Top for a 4dr.
- Warranty
- Wanting a new lift! Need help to figure out what kind...
- Q on Currie Rear Anti rock
- Needing some help on my first lift kit...
- Starting the the RedBeast build (2008 Rubicon)
- Superchips tow mode with 87 octane?
- Stock Rubicon Rims
- cat-back exhaust help ?!?!?!?!
- 4.88's 35's and 6spd MPG's?
- '08 Rubicon - Will 33/12.5's/17 Rub
- Spidertrax wheel spacers
- Anyone having problems running wheel spacers with stock wheels and 35's????
- Gear oil
- Section width
- lock right
- Rugged Ridge hinge overlays.
- 2 quick winch questions
- I am in a really bad mood...Teraflex leveling Kit Help Please....
- Winch in Stock Bumber
- New Superwinch Epi9.0s
- HELP...why are my front hubs spinning in 4wd?
- ???snorkel, mirror relocation braket & windshield light bracket
- rims
- Sprint Booster or or Flashpaq
- Rusty fairlead
- Rugged Ridge XHD Front Bumper
- Fold down tailgate anyone?
- Rough Country Quick Disconnects
- Paint top
- RC 2.5" Coil Lift with 2.2 shocks reviews?? Please
- PRESS RELEASE: Rock Krawler DIY 2-Door Reverse Triangulated 4 Link Assembly
- Warn Winch Aircompressor
- Need bump steer advise for Rubicon Express 4.5 lift
- Wild Boar Wide Body Fenders
- Availability of Hard Top Panels, NOT the Panels for the Optional OE Hard Top
- Exhaust Exhaust Exhaust...
- DD tire pressure for 33" Duratracs?
- Traction light came on today--
- Lets get this straight! Death Wobble!
- Need new springs...help please!
- Smittybilt XRC Winch cover, need guidance
- which dana 44 gussets
- Help me spend my fantasy footbal winnings!
- Superchips return to stock setting??
- G.E.A.R. Overhead console
- Max width tires on stock Rubicon Wheels?
- AEV ProCal
- Rock Monsters
- Bird Cage in Winch Line
- air sensor
- PureJeep rocker guards
- Front Axle
- Vibration with slight right turn 60mph
- Vibration with Mopar lift and sterring stabalizer "death wobble"?
- Tires and Rolling Resistance
- Lod + superwinch
- Tyre Pressure Sensors
- Installing rock rails, do I have to worry about weight?
- Tereflex 2.5 coil/shock lift
- Winch question
- Sir Sways A Lot
- Old Man Emu Sport Shocks?
- This doesn't look right, should I be worried?
- new axle, what to look for
- 37s and dana 44s
- Getting Colorful
- front end sagging...lift?
- Aev lift?
- U-joint Help!!!!!
- POLL: Engine/Trans skid OR heavy duty oil pan and trans pan?
- Fix Gas cap
- 2.5" TF BB with front 3/4" leveling spacers. Any problems?
- Rear Bumper
- Amsoil
- GY Duratrac 315/70R17 (34.4") on stock tire carrier?
- teraflex = rough country!!!???
- Aries Front and Rear Bumper
- 33's with 3.21 gears?????
- Expedition one bumper
- G.e.a.r.
- 37" nitto mudgrabbers?
- Gears or Supercharger
- Tire help anyone?!
- TeraFlex 2.5" Budget Boost w/ Adapters Under $321 Shipped?
- Running Rich
- im gonna get higher
- Spacers--Tereflex vs Spidertrax
- Experience with TreadWright tires???
- Is Mopar Softop hardware compatible with the Bestop Trektop?
- Sway bar questions
- 2.5 inch lift vs 3.5 inch lift?
