View Full Version : Modified JK Tech
- Spidertrax 1.5" spacers VS Rough Country
- LIFTING MY JKU Rubi
- Powder Coat Question
- Decisions, Decisions , Decisions....Warn or Brand X
- Bilstein steering stabilizer relocation bracket?
- gears
- Convince me to buy 35's
- PERSONAL EXPERIENCE with 5.13 or 5.38 in....
- smittybilt xrc rear tire carrier help
- Hidden Jeep kill switch anyone?
- cb mounting location for 2012
- lift for 35's?
- 33s vs 35s 3 inch vs 4 inch help!
- Canadian buying jeep parts
- Beefing up a rear Dana 44?
- Thump when i accelerate
- Expedition One rear carrier with Hi-Lift ? Anyone mounted diagonally ?
- Steering Stabilizer Question
- Show your wheels
- Teraflex or rock krawler rear track bar bracket?
- JKS 4th generation trackbar
- Springo lingo
- Steering flip?
- 40s on factory Rubicon axles?
- Ultra Crusher rims?
- JKs disconnect pin sheared and axle bracket bent. How? Fix?
- Intake for 2010 JK (3.8l)
- Wear tabs on brakes
- Odd feeling in front end after axle swap
- Superchips Auto Trans Tune 2010 JKU Rubi
- Steering Stabilizer Bolt Size???
- Teraflex spacers or rough country spacers?
- Process Question
- Rock Krawler 5.5 Triple Threat
- mountain hwy driving with 35s|4.10 combo vs 32s
- Lift kit suggestions??
- Coast 1310 front shaft on lifted ''12 JKU, still need exhaust mod?
- Vibration after changing driveshafts
- Lift questions
- rear bumper/ tire carrier
- 4.10s in Sahara?
- Poison spyder rear tire carrier.
- My head is spinning!
- Engine swap in a 2008 jk with a 2010 motor??
- Tow Strap vs. Tree saver
- Dana 30 beef up suggestions?
- Maybe an issue greasing control arm?
- 2012 JKUR Shocks & Springs + AEV 2" Lift on 2009 JKU Sahara?
- Question about Full Traction 2" lift
- Shaking after leveling kit??
- Taillight Issues!
- Input on prices for welding labor of gussets needed
- Spring problem??
- TRE on Drag Link @ Knuckle / Flip Kit?
- removing body mount bolts (ques)
- Rock Krawler mid arm xfactor plus rear shocks
- newbie question
- What length shocks to use?
- Wheel question, probably asked before...
- Rock Krawler long arm kit - exhaust mod question (pics inside)
- Have AEV2" lift, which shocks should I go with?
- Help I just got the Smittybilt GEAR overhead Console
- Full Width LoD Carrier??
- need help
- RC 3.5' Series II Suspension Lift Question
- Should I, or shouldn't I
- Lift heigth question.
- KC Lights, Wires on switch very HOT!
- Switch Panel in Stock Location?
- What mods should i start off with???
- Spacer lift with full suspension lift
- Suspension kits
- 35 x 12.5 x 17 vs. 315/70r17's
- Viper Throttle body is worth it!
- Pic request:black hinges white jk
- 285/70-17
- Off road trailer build phase one complete!
- Front Brake Lines
- rust from rivets?
- Anyone have any first hand experience with the EVO-full-protek-skid-system?
- Dynatrac PR44
- Newbie to Mods...Need Advice
- The lift that is right for me
- Teraflex 6" lift questions.
- Rear bumper pic help!!
- HELP NEEDED ON LIFT for fairly new jeeper
- TeraFlex upper rear control arm install? Need assistance.
- Which Rock Krawler Lift?
- M.O.R.E 1" vs RC 1.25" vs PA 1" body lift
- Rocker guards with steps that wont break the bank.
- 37 tires for a daily driver, good and bad tire options please
- Anyone put Headers on there 3.8 JK
- any one with fuel hostage wheels
- trackbar brace.
- Locking the smittybilt tire carrier
- aluminum driveshaft maybe?
- Transmission cooler bib issue
- I have an idea... opinions?
- Mystery Wire!!!
- Hemi JK on 40s, transmission cooling concerns
- EVO Tire Carrier latch Pins
- harness instead of standard seat belt
- Setting Procal
- forum stickers
- What exhaust is on the Mopar Indpendence JK8?
- ACE Tube Fenders
- Need Help Finding Right Lift!
- TPMS worth keeping?
- Axel swap
- Soft brake pedal
- Rock Krawler X Factor 3.5
- air intake squealing. need advice.
- VIAIR On Board Air (OBA) for 2012 JK, Constant Duty (#45044) or Heavy Duty (#40044)?
- Questions on pulling trigger on Ripp Supercharger and possible regear
- Air Intake
- Transfer case leak after Je Reel driveshaft and yoke install
- question about red loctite
- Tire question
- How long do I wait??
- 315 75r16 with 2.5 spacer lift??
- Anyone in virginia wanna help instal lift lol
- Could someone explain backspacing?
- Superchips Tranny Tune for 35's with 3.73 gears??????
- New driveshaft problems..NEED HELP!!
- New tires & Wheels... TPMS question
- 2011 / 2012 tuner?
- anyone add headers to their 3.8 jk? Opinions please
- 2008 sahara 5.13 gears 3.5 lift, flat fenders, go from 35 to 37 tires?
- question about re-gearing
- In Argentina with my JK, need a part, can't get it here......exhaust header bolt
- 2.5 lift
- Changing gears and addind Detroit Locker
- Jax beach drivin
- Bully dog vs. Superpaq tuner
- Phase 1: Let the obsession begin
- Custom stickers?
- Baby got new shoes, what tire pressure??
- Help me decide coils or fender trim
- Crager soft 8, 15" on 2011 jk....issues?
- What first?
- What should be done next?
- cold beer in loxahatchee fl
- how big of a spacer needed
- Cheap mod.
- New Tires, Factory Tire Carrier
- ARB comp on a 12
- 315 70 duratrac /3.73 gears
- 4" and bilsteins???
- Cargo Carrier in Front.???? HELP???
- x-factor 3.5" install instructions needed, mine shipped without
- Teraflex vs. ProComp
- Rock Krawler Spring correction wedge on 2.5" lift?
- Torque spec for t-case cover
- Suggestions on route to take
- State Specific Lift Laws and other vehicle restrictions (liftlaws.com)
- Winch Plate
- Reviews first hand experience with the Teraflex front 44 housing?
- backspacing!?!?!?
- snow tracks?
- Can't loosen control arm bolts!!
- Any last minute tips??
- Auburn Lockers
- 08 X Unlimited Upgrades
- Today is the day I order
- MW3 getting winch today...
- Bilstein shock question for 2.5 max flex
- Does the Smittybilt XRC Modular bumper have...
- Question about coolant
- Rubi electro disco Aftermarket replacements
- 16" rims, tire questions
- Bestop power board mod
- Can you identify this bumper?
- Replacement Wheels/Tires for my '12 Unlimited Sahara Size Question????
- Alternative to Rear Superior Super 44 kit?
- Shackles for Ace Eng front and rear bumpers
- Evo double throwdown system
- Help me spend some money
- Noise in Front Right - Drag Link Ends?
- Anybody seen these yet? Philips LED DayLight 4 & 8 - Daytime Running Lights (DRL's)
- Under side sliders
- Whats my issue?
- New Black Rock Intruders on Order - What to do with old wheels?
- Slight brake pull?!?
- Advantage/Disadvantage or Possible? To replace Sahara swaybar with Rubi electric
- Plasti-Dip the soft top?
- Teraflex 2.5" Coil lift..question about the instructions???
- Annoying whistle sound... please help
- LOD sliders and rubi rails?
- Did 35s void your warranty?
- dynomax 39510 and MPG
- Aev savegre argent
- Stock Rubicon Moab vs. V-Tec Raptor Offset
- Planning on regearing? You may want to read
- Another wheels question
- 33x12.50 with 4.75 back spacing fit on stock unlimited suspension?
- stock 255x75x17 tires on 17x9 wheels
- Tuner advice
- Tuffy Security question
- Hi-Lift Jack Mount---Hood
- Reid Knuckles and 15" Wheels.
- Question on Smittybilt XRC rear bumper with swing away tire carrier
- Diesel conversion seriously being considered
- Rear bumper
- Ahh, the classic "Which Tire" question...
- alarm system question?
- JK Lift
- Prosteer upper Trick
- Help with RIPP SC Intune program
- Superchips VIVID LINQ versus Superchips Flashpaq Programmer
- Capability of short arm kits vs long arms?
- Rubicon Express and ARB help a brotha out!
- does Full traction make a 2" coil lift?
- 2010 2-door Rubicon lift question
- ome light load 3" kit
- Recommend Lightweight Bumpers
- Anyone ever powdercoat control arms?
- Difference between Chips & Tuners??
- Why Bilstein
- Rubicon shocks
- Is this a good chip to buy?
- pros and Cons.
- Rubicon Electronic Swaybar broken
- Smittybilt XRC Armor Rear Corner Guards and Front Fenders
- Complete Onboard air setups - Advice?
- Rock Krawler 2.5in
- rubi springs and shocks
- Airaid MXP Intake for 2012 Jeep
- K&N filter??? Good or bad?
- Rock Krawler Tie Rod
- my modified mopar frond bumper
- AEV Tire Carrier
- New and need wheel and tire help
- Body Armor bumper reinforcement for winch?????
- A little help with castor.
- EVO MFG lift
- Is it possible to just "swap" a sport tcase for a rubi?
- Winch Questions
- Geolandar M-T+
- Superchips vivid. Options for interstate cruising
- Has anyone made a cover for the rear cubby/storage area?
- Tera flex lift questions with pics
- gears and fuel mileage
- 2.5" lift which shocks ?
- OME 2" lift or Rough Country 2.5"?
- spacer lift
- Rough Country 2.5 coil lift questions on aditions???
- New Yukon 5.13 gears making humming sound
- York onboard air system
- Trail Grapplers or MT/R's?!?
