PDA
View Full Version : Modified JK Tech
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 [186] 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296
  1. Update on $6,000 u-joint repair
  2. Axle sleeve install recommendations
  3. Wheel suggestion
  4. Water /methanol
  5. lowering stock running boards
  6. TF Leveling kit now too low in the rear. Add spacers?
  7. Rubicon Express or Teraflex
  8. Bumper and winch need to get level again
  9. Help! What bumper is this?
  10. steering wows
  11. anyone running the new smittybilt stinger?
  12. Feeler and question about Moabs and Pro Comps
  13. Lifted and now can't get alignment, HELP
  14. AEV ProCal work on 2011?
  15. Changing Gears
  16. Front sway bar links!
  17. Question about overdrive
  18. How do you fix a wallowed track bar hole ?
  19. rugged ridge XHD Rear bumper?
  20. warn 9.5 xp problem...could have gone bad!
  21. What size tires fit my wheels?
  22. is this the right tire size?
  23. Help Please
  24. Hill Assist Retrofit
  25. If you are on the fence about re-gearing...
  26. Rock Trak Transfer Case IN!
  27. Do I have to use the dust cover off the stock flange on my new Yoke?
  28. How to decompress/extend driveshaft?
  29. Added 1" level spacer to my 3" Zone lift, now i have some issues
  30. Rear axle pinion seal leaking? Help me out
  31. My jeep goes nuts on 4 HI
  32. Thinking of Upgrading to Rock Krawler 3.5 entry kit from RC/have questions
  33. Rancho rock sliders!!
  34. Compression Adjustable King Shocks -- Anyone Using Them Yet?
  35. Smittybilt XRC-8 Winch Mount???
  36. adjustable rear control arms
  37. LIft Kit: Coil springs or coil springs w/ short arms?
  38. do i need a oil pan skid
  39. HELP!! PJ rocker gaurd hand rivet tool
  40. Anyone with the borla headers?
  41. ? For those using OR-Fab Carrier
  42. Another DW
  43. Building a lift kit, help!
  44. Bolt Pattern for larger tires
  45. Painted facotry fenders
  46. K&N Drop In Air Filter
  47. Which would YOU buy?
  48. Any deals on HD tie rod's?
  49. any body use any type of beads to balance tires
  50. lod sliders vs evo sliders + long arm issues
  51. Which Cold Air intake!!
  52. Thumping coming from rear after SRC install
  53. MBRP Cat Back Differences???
  54. Will These Diff Covers Work Stock??
  55. End of life for stock Rubicon Tires
  56. Do I need to extend ABS line while doing lift
  57. Lockout hub for JK with 5 on 5 pattern
  58. what modification needed for lager tires
  59. "Low Tire Pressure" indicator after tire swap (stock rubi wheels)
  60. Anyone have the Red Label Grabber tires?
  61. Ordered Superchips yesterday, delivered this morning
  62. Buying a used Superchips Flashpaq
  63. Superchips in MA area?
  64. Gas Mileage Improvement?
  65. Anyone using a OR-FAB rear tire carrier?
  66. Is there a crush washer for the differential drain plugs?
  67. is tire install free when you buy tires
  68. Teraflex leveling kit sway-bar end link question
  69. Bushwacker Pocket Flares....33" tires & Teraflex performance (Coil) Leveling Kit
  70. OME: 2" HD or 3" LT
  71. MBRP Rock Rail With Step Impressions From Those Whoe Have Them
  72. help on wheels
  73. Problems with Superchips?
  74. Body Lift with Teraflex Leveling Kit
  75. rock slider advice
  76. Falken (Rocky Mountain ATS) tires
  77. Gear swap - what fits a D30
  78. wheel and tire combo availability
  79. Which D30 parts are usable in a Rubi D44 housing?
  80. PRESS RELEASE: Rugged Ridge Fall Bonus Bucks REBATE
  81. rim/spacer question
  82. Rubi Transfer Case in a Sahara? Worth it?
  83. Which Goodyear Wrangler MTR w/ Kevlar - 37X12.50R17 or 38X14.50R17
  84. Pro Comp Series 52
  85. How would YOU upgrade a front Dana 44?
  86. BDS 2in suspension lift
  87. Rocker Guards vs. Step Rails
  88. Axles. dont know anything?
  89. BinaryPie's Build Up Thread!
  90. Off road mirror brackets
  91. Anyone Have Any Rear View Shots with Stock BFG MT and Spacers?
  92. 2.5" TF lift do i need the shocks?
  93. 3.02in. backspacing, bearing failure, how long?
  94. Diablosport Predator or Superchips Flashpaq
  95. Does anyone make a light weight rear bumper?
  96. This is why I want Off Road Evo rock rails ...
  97. Improving a Stock Wrangler Unlimited Sport!
  98. NITTO MUD GRAPPLERS!!!!! I have a few questions
  99. TF 3" do i need any thing else?
  100. Smittybilt armor/fender anyone?
  101. rear upper/lower adjustable control arms
  102. Seat Belt Help Please
  103. high quality 35"s
  104. Help locating tool for LoD slider install
  105. 7Pin trailer plug damaged on the trail
  106. Need to change Sahara sway bars but have questions
  107. Speedometer and tires
  108. Lift kit Ideas
  109. Lift ? - What am I missing
  110. Need advice from those who have the Hi-lift tailgate hinge mount
  111. TeraFlex Levelling Kits - Spacer vs Coil
  112. slop in my front tcase yoke
  113. Can Anyone Critique the Pro Comp 2.5" JK Suspension Kit?
  114. Bilstein 5100 Shocks
  115. Tom Woods vs. JE Reel Front Pinion Angle...
  116. RCV axle boot
  117. Soft top rear window question....
  118. Which end are my driveshaft vibes coming from? t-case or rear end
  119. Adding coil spacers to susp kit?
  120. Rusty's exhaust
  121. Hot as Hell!
  122. Banks Exhaust question
  123. Gear Break In
  124. Smittybilt XRC front fenders
  125. painting emblems
  126. G-2 full spool
  127. Another Homemade Bummer
  128. Switching Lifts??
  129. 37s and d44s
  130. Suspension seat questions?
  131. Stock spare tire holder cracked on back
  132. 37" tires and 17" wheels
  133. 33'' tires installation tomorrow
  134. tire psi for toyo mt
  135. Mpg
  136. Anyone see any problems with this set up?
  137. Axle Truss Questions
  138. more mods - what would you add
  139. how important is a diff skid
  140. 15" Wheels a good idea?
  141. Rocker Skinz question
  142. Yes another Tire/Lift question.. Yes I read the sticky...and Yes I searched
  143. tranny cooler install
  144. Redrill on Eaton Locker's Carrier? Does anyone done it before?
  145. Leveling
  146. 5" lift with stock moabs; Bad Idea?
  147. Assumption Right or wrong.
  148. Need Help Please!!!!---Cross Treaded Bold on Tire Carrier
  149. POR Chassis Coat
  150. Need Suggestions for Potential Problem(s) with my Setup
  151. Eaton Locker Installation HELP ASAP!!!
  152. Nitto Grappler AT Recommendations Needed
  153. Winch mount question
  154. Rubber isolator or spacer better?
  155. Anyone Running MAXXIS MA-761?
  156. Rubi Lockers Not Engaging?
  157. 15x7 rim with 4" b/s work?
  158. Anyone running Pro-Comp Xterrian's or Xtreme A/T's
  159. Taraflex 2.5 BB lift issue??
  160. Hard time removing mirrors from Rugged Ridge mirror relo brackets - suggestions?
  161. Aftermarket rims and tpms????
  162. Best lift for your money
  163. Avoid Axle Regear by using Atlas II transfer case?
  164. Superchips flashpaq and 1st gear sycrons connection???
  165. Need some info...
  166. Trying to decide .... 305/70R16 or 315/75R16
  167. Removal of rear bench seat to facilitate 2 offroad buckets seats
  168. Air Raid install,, Squeal or whistle now??
  169. Rear Sway Bar links NEED HELP.
  170. Upgrade to dana 44 with OE locker?
  171. 3" OME LT lift write up
  172. Wild Boar Fastback tops
  173. Need Help - Strange Shake and Pull with new tires
  174. Packing grease in the front driveshaft Stock CV Joint?
  175. Will 4.88 work with 35" and 37" tires.
  176. isolators
  177. regearing my 08 unlimited x
  178. U-joints
  179. rancho 4 inch long arm lift kit
  180. Downsides to a 5.13 Regear on a 6-Speed Manual Rubi
  181. 1.75 BB lift and rig is not level.... help?
  182. mopar side steps and sliders?
  183. WHAT MPPG ARE YOU GETTING WITH YOUR 4.88's?
  184. Switching to ARB 35 Spline - What is the real performance gain
  185. Need advice - BUSHWACKER Flat Fenders or Pocket Fenders???????
  186. AEV Pintler beadlock rings
  187. km2 vs mtr tire comparison
  188. Lower control arm question
  189. Still having death wobble issues.... Help
  190. Aussie Locker & 3.21 Gears
  191. Tire sizer. This is cool.
  192. Teraflex Advice
  193. hooking a hammock up inside the jk
  194. Transmisson sending unit location
  195. ARB vs AEV bumper. Which one?
  196. body lift choices
  197. SuperChip or New Steps/Rockrail
  198. BFG KM2's Question
  199. 2 3/4" spacer to much ?
  200. Drive shaft
  201. looking for suggestions on how to setup a flowmaster super 44 offroad muffler
  202. Teraflex or Rock Krawler??
  203. Locker in the back [D44], what about bearings?
  204. YATQ (Yet another tire question)
  205. Tire carrier for 35"
  206. $299.00 winches are they ok if used occasionaly
  207. ESP problems.......
  208. J8 Sarge Top
  209. With Superchips tune And 33's what type of mileage you getting?
  210. trimming fenders
  211. Nokian Vatiiva Tires
  212. Kargo Master Congo Cage/Safari Rack
  213. PRESS RELEASE: Full-Traction Heavy Duty Replacement Cross Member
  214. Wheel Powder Coating vs. Painting - Pros/Cons?
  215. pics of jk on narrow 35's
  216. 13.5" wide tire???
  217. Lift Kit Decisions NEED HELP!
  218. What do you think about your ESP
  219. Shocks Upgrade
  220. Supplementary fuel injector (TBI)
  221. Rubicon Express Twin Tube Shocks......keep em, or sell em?
  222. XHD or Rancho bumper tire carrier
  223. Bushwacker flat flares and Mopar billet fuel door?
  224. Intake, Chip, Exhaust Help
  225. 1" off side to side after lift
  226. Changed my Superchips setting... it might help you as well
  227. Slider Step good or bad?
  228. Anyone running 4.88 gears on 33s?
  229. Is any dealership o.k.?
  230. 3/4" or 1" spacer to level Jeep, what are you using?
  231. Build Questions Re: 35s and TF 2.5 inch lift
  232. Anyone see any RED FLAGS with this wheel/tire combo?
  233. AEV snorkel
  234. 35's with 3.21 gears
  235. Tires, Tires, Tires...
  236. What kind of nuts (lug that is)
  237. Full Rhino/Line x Cost
  238. Tire Question....
  239. What rocker guards (if any) will work with factory Rubi rails?
  240. Question for line-x crew......
  241. Bead locks what rims ??
  242. What size Hi-Lift? 48" or 60"?
  243. Rhino Line the Roll Bar
  244. Toyo open country mt tires any good ??
  245. Goodyear 34's
  246. FC-II or Duratracs
  247. Need help with a lift
  248. Question about Goodyear Duratracs and ProCal
  249. is mine the only one w/ this problem?
  250. Advantages or Disadvantages: 16" vs 17" Rims
