View Full Version : Modified JK Tech
- TERAFLEX 3 inch VS. FULL TRACTION 3 inch lift?
- 35s to be but wanting 37s in the future...so...
- Picked up the new 4 Wheel Drive mag today...
- 2.5 lift question???
- piecing together 5 1/2" lift
- TeraFlex 2.5 lift questions and advice
- Putting Together a Lift Kit for 35's. Need a little help/advice
- Skyjacker Adjustable Control Arms
- Newbie to Moab need trail info
- Red Lock-tite... Stud replacement?
- Firestone M/T put on today.
- 35 x 12.50 km2's
- Coil Spacers
- How Many have Death Wobble/Wheel Shimmy?
- Those with 6"+ lift, need your opinion
- Bestop Bikini Top Question
- Rear Bumper with carrier
- 4" lift and ESP issues
- Wheels question
- Spacer lifts????
- Rough Country 2.5 in. Coil Lift w/ Shocks...
- 33's with a 6 speed rubi: regearing necessary?
- 6'8 Clearance
- 6-Speed, 295 or 315, 4.56 or 4.88, Altitude
- Tire size
- Teraflex vs. Skyjacker
- Superchips Flashpaq '09 Unlimited X 6sp
- Super Chip off-road???
- aev hood is black- jk is flame red
- Rim backspacing
- Brand New JK XS 4 Door Now What?
- Rancho Rear Bumper problems
- 2.5" BB and 1" Body Lift = 3.5" Total lift, Yes? Any issues?
- Bumper Recommendations & Pricing
- Tires
- Do the BB when U do the susp. lift or not?
- D30 with 35's 37's
- Installing my TF HD track bar tonight..
- which rails to rock
- Rock n' Road Suspension???
- front upper control arm bolt size
- Hummer parts on a JK???
- About Project-JK Basement Builders Virtual Crafts Fair
- Adding front adj. Control arms
- Ideal tire width/size for sand?
- Question for the good folks at Tereflex...
- Help! Axle Seal Leak After 5.13's Install
- 3.5" skyjacker lift non mechanic perspective
- Rockstar wheels: can I get them in a 17"
- Locking Black Lug Nuts
- Lug nuts on pro comp X alloys
- AEV ProCal
- Adjustable trackbar
- Are spacers a must?
- Can I run two sets of TPMS
- Death wobble, bump steer, shimmy you be the judge.
- Wheel Spacers
- Pure Jeep tire carrier problems
- LOD bumper rake?
- Anyone convert their Roll Bar into an Air Tank?
- Questions about lights, bumpers, and building plan
- Saggy?
- 35's & Xenon flares next Friday! (the 15th)
- 37" tires on 17" wheels or on 20" wheels
- Full width 60/14 swap
- Cut Stock Fenders
- homemade rock rails need your opinion
- Short arm vs. long arm - newbie lift question
- Removing Factory bolts!!
- can i install 2009 rubicon wheels on 2009 sahara
- Wheel Centered - Stability Ctrl still coming on...
- sure wish my LoD sliders would fit!
- Trackbar
- Which is the better MUD tire? KM2 or Toyo MT
- modified softtop, what do you think?
- Installing lift and have a question...
- Tranny Cooler
- MAX Hyper, Chips, ...
- real dumb questions
- Gobi Stealth Rack & LOD Bumper Compatability?
- Beware of Smittybilt ! SRC Side Armor
- Seat Glovers
- Trackbar
- MPAC Rack, Tailgate Shock Solution
- Leveling spacer kit?
- lift and tires
- Flexatrunk install and product review (long + lots of pics)
- Rear Axle Housing
- RC $50 Discos
- Synthetic Auto Trans Fluid
- New wheels/tires suggestions?
- Recommended mods for 37" tires with beadlock wheels?
- Aussie Locker in the winter
- teraflex BB drop bracket
- Am I forgetting anything
- JE Reel
- Full Traction front Track Bar question - (Jam Nut size)
- I got to take a leak! said the brake line HELP
- ''zone'' 3'' lift
- Measuring castor?
- Does the Trectop door frames fit with the RockHard Sport Cage installed on 4-door JK?
- Sway Bar Rub
- Question on lift install....
- what length/front lower control arms?
- lifts and On Road performance
- So, who's clearing 35's with their OME lift?
- Quick Tire/Wheel Question
- looking for numbers on an avenger sc
- Anyone mount a winch to the stock bumper?
- warn powerplant hp
- Possible to rhino line/line x mopar chrome side steps?
- Cracked exhaust/Headers questions???
- Smittybilt SRC Rocker Guards
- CV and U-Joint Grease Type
- shrockworks 2dr slider installation
- Mile Marker Winch w/ Factory Bumper Mount...
- HELP..bigger tires/Auto trans question
- Problem with TPMS after 35's
- Rugged Ridge rock rails
- Tera Flex SS Brake Line Problem
- What gears for my JK? Worth doing?
- Which wheel?
- Real beadlocks or fakes?
- Liscense plate -- after winch install
- Need help with TF 2.5" lift
- 35's vs 37's towing trailer
- Intake Question
- MOPAR 4door mats on 2door
- Help needed with Front Lower Flexarm install...
- Teraflex 2.5" BB w/shocks or Teraflex 2.5" lift kit w/shocks
- Firestone Destination M/T or Pro Comp Mud
- Anybody running Jeep Commander Wheels ...
- cost of ring and pinion install
- How to avoid wheel spacers
- this setup??
- throw some paint on the inside?
- I want to lift but worry about wear and tear.
- Instatrunk install
- Mounting New Shocks Question
- G2 gear set
- Skid Plates / Sliders - Order of Install
- My lift idea...looking for opinions:
- Dana 30 Metric front differential discussion
- 37 inch tire vibration
- bye bye flaspaq
- Update on TC,gear, locker, woes.
- long arm
- Kc Fog Modification!!!!
- Favor please.....
- Rough Country Lift..
- 4.88 or 5.13 which one
- bumper fab
- Half/Soft Door recomendations
- best 2.5 to 3 in lift?
- C-Gusset Chatter
- Rear Axle Alignment
- Flexatrunk Strength
- Reprogrammer Question
- Teraflex shock question
- Shocks
- Steel or Aluminum wheels?
- People with Riddler's
- Installed new Rugged Ridge mirror relocation brackets
- Rebar Light Guards?
- AFE Dry air filter vs AFE Oiled air filter
- Boomerang Tire Covers for JK
- Drivers side front spring spinning out of perch
- AEV ProCal module and day time running lights
- Rocker Protection
- OK listen-up! Time to be serious....
- Reduce Heat and Noise
- Wheel recommendation
- PRESS RELEASE: Die-Tech Off-Road Doorless Mirror Brackets
- PRESS RELEASE: Die-Tech Off-Road EVAP Canister Relocation Kit
- Do you use a front Auto-locker??
- rough country 2.5 or terra flex 2.5 coil lifts
- expedition one
- Warrior Products Yay or Nay???
- Snorkel+Roof Rack...will it fit?
- RR stinger on stock metal bumper
- 2.5 Air tank install w/ARB air compress.
- one last thing
- Ome lift needing anything else?
- Rugged Ridge Bumper and Superwinch EPi9.0S install Help!
- 1.75" Lift Question...
- Whats With JK Snorkels?????
- Rough Country
- trektop windshield header solution!
- Biggest Tire
- Tie rod and drag link rod
- Recalibrating speedo
- placing the order
- drag link adjustment
- leveling kit
- Axle question wanting to regear
- Next Mod?
- Black Lug Nuts..
- Wheel spacer torque?
- Alignment
- Lug Nut torque
- Currie Rear Sway Anti Rock Sway bar
- Trektop Question
- gear change???
- All your suspension kit questions answered!
- Have you replaced winch solenoids?
- Obi Won what is this f-in part?
- 1000.00 for a lift what do i do
- Front JKS adjustable bumpstops
- Ordered C2 Gussets - Adjustable Ball Joints Anyone?
- what gears are best?
- OR-FAB Tire Carrier Question
- 4" backspacing, 285mm (11.25") wide tire, rubber stop for spare doesn't make contact
- Lift that changes it all!!
- Discos and lift
- ughhohhh broken parts
- tire on tailgate?
- ALL 40's
- Spacer leveling kit, do I need longer swaybar links?
- Teraflex says 5.38, Forum says 5.13s?
- rhino lining
- Hitch Motorcycle Carrier?
- Wheel spacer questions...
- Full Traction Track Bar Bracket
- 3" to 4" Lift sugestions
- Spare Tire Bike Carrier for 35" tires??
- How are your bedlined wheels holding up?
- Need Advice - ReGear, Lockers, etc.
- Stupid question
- Aberle Offroad Aluminum Bumper
- Help! Front pinion seal diameter????
- Switching from Rugged Ridge to LoD Bumpers?
- Driveshaft prices
- backspace ?
- Rubicon Rear 44 differences by model year
- BFG KM2 35's
- Mopar bumper with rocker guard
- Removing Evap Canister?
- Help Me Fix My Problem
- Alternative to Cragar wheel caps
- broken front trackbar bracket help
- How do I do this?
- LoD Rear Bumper and HiLift Jack
- Stock stubby bumper
- LOD stubby and Blue Ox base plate
- 35'' tire pressure
- Aussie Locker guys
- nitto mudgraplers
- for or-fab tire carrier owners
- sitting at service department need advice
- LOD midwidth w/out hoop... any pics?
