View Full Version : Modified JK Tech
- Definitive Features Supported by SuperChips Flashpaq at Present?
- Is it my shocks?
- Help With Wheels & Tires
- trying to fit 37's
- Homemade grab handles for under 10 bucks!
- Help choosing wheels....
- Full Traction frame-end bushings -- upgrades or replacements?
- Transfer case driveshaft nut
- 37's on a RE 3.5" Lift?
- Spacers?
- Rock Rails/Body Armor as side steps
- What should i do first, wheels and tires or 3' lift?
- 2 door flares on 4 door?
- Which AT?? Made in the USA (sold at Discount Tire)
- Rubicon Auto Swaybar disconnect????
- ARB Compressor and Inflator install suggestions?
- Painted Steelies?
- tires problem
- MBRP Exhaust Pro's & Con's
- Calculations on Speedo
- short sway bar links and lift.... not the best idea.
- "Hummer" Snorkel on JK?
- Breaking bolts on FT 3" Ultimate
- Alright , can it be installed with out issues??
- Rubi suspension on a Sahara...?
- JKS Track Bar Brace Strength?
- Backspacing/Sway Bar Link Question...
- Non-CV 1310 drive shafts for 4.5 lift?
- EVO Rock Sliders
- Fl control arm question
- Shocks for smoother on-road ride?
- Future mods & regearing questions
- Installing my AEV bumper this weekend...any tips?
- sliders
- Hmmmmmmm.....
- War of the snorkels..
- Loud clunk from front suspension
- Best gear ratio for Daily Driver
- Weakest Link? What should be replaced next??
- Steering Centered on RE long-arm
- Hard Top, Soft Top, or No Top?
- Diff Cover Poll......
- Does anyone have this rear diff slider?
- Best Lift for @$3500
- Winch Advice
- Pro Comp v. Skyjacker
- Teraflex Lift question
- Sleep in back
- Mopar Fuel Door
- Airaid Cold Air Intake and Rain
- Acceleration Hesitation
- Full Traction Econo Kit w/ Stock Shocks?
- Teraflex 3in install write up?
- Re-gearing opinions...
- Rough Country lift installed
- Engine runing very HOT!!!!
- RIPP Meth Controller setting???
- LOD Shorty Front Bumper with Winch Guard or Stinger?
- Rugged Ridge RRC Armor Guards
- Multiple Double Cardan Driveshaft
- LOD tire carrier - Hi-Lift ?
- expedition one rocker guards?
- '08 JK Factory Stereo install in '98 TJ
- is this a good kit?
- rear bumper/tire carriers in canada (EMERGENCY!)
- lift install tips and tricks
- BFG Krawlers yes or no
- 2.5 lift what extras are needed?
- quick question
- 37's with 2.5" Teraflex BB and Fender Chop?
- Rubicon regeared, rear locker issue
- Can someone please clear the air???
- Searching for rocker guards like RuggedRidge
- Just Ordered Lift question
- upgrading from 2"bb to 3.5 springs questions
- Do I Need Flex Arms?
- ARB switch connection harness
- winch fix for fab four bumpers
- Paint the trail rated badge?
- Help with misfiring unlimited
- Search help please...
- Rocktrac Transfercase
- Rugged ridge wheel spacer
- brake lines
- Driveshaft advice..........
- What the heck does a stinger do?
- Just bought a new wrangler X - where to start?
- Gobi Stealth Cargo Rack or Wild Boar?
- Help with decision/performance of tires
- New Bestop Top?
- Rock Krawler 3.5" lift?
- A/T Tire advice!
- Duratrac's?
- Steering clunk. Any known upgrade?
- Starting from Scratch - Suggestions?
- Aussie Locker Installed
- Teraflex front trackbar versus rear trackbar
- suspension lift suggestions
- Flowmaster - 50 series or 40 series
- I Need help deciding the kind of wheel to put on my jeep
- Can you help???
- Warn power plant HD or M1200
- Off Road Evolution Front and rear doulble throw down system
- Lift Suggestion
- ProComp Beadlock Rings?
- rockkrawler rear arms, now bumpstop issue, pics included
- D60 RockJock oil change?
- All components needed for a RC 4" lift?
- going from teraflex 2.5 bb to 2.5 spring
- Need help with MBRP light bar install
- Fabtech 5" rock crawler lift kit w/dirt logic shocks
- How to remove emergency brake cable on axle?
- AEV 3.5 Nth Suspension v Driveshaft
- Kore vs AEV suspension.
- Jk on 42 KM2's!
- Clover Patch Window Roll - Bar Inside or Not?
- benefits/drawbacks of black steel wheels
- jks track bar
- Grab Handles Block View?
- rough country 2.5
- tf bb trac bar bracket...
- How hard is it to install....
- Gear Install, front locker troubles. Dana 44
- Granatelli MPG Plug Wires - Bosch Fusion IRs
- Gerry/Gas Can Mounts...
- Leak Advice
- Hardtop Panel Storage Idea
- Which Track Bar Brace
- Underwater winch
- 4" Backspacing on 17X9
- 3-4 Inch Lift for 09 Rubicon Unlimited
- Install / Remove softop with roof rack.
- Help needed ASAP!! Harley mirrors ?? Part number ??
- Tf 2.5 bb
- 33" Nitto Mud Grappler Pressure?
- Roof Rack
- Anyone running Pitbull tires?
- Best muffler or exhaust to go with
- ESP on a lifted rig - tips
- Lift question
- 3 inch lift
- Disassembling the Soft Top
- Windshield Top Wind Deflector
- I think I have a bent rear axle shaft (video)
- anyone got mirrior relocation & windsheid light?
- Unhappy with PureJeep Stubby Bumper - Rust and bubbling after 14 mo. - Includes Pics
- Best Bang for the Buck....
- What's the Best Option for Third Brake Light with Stock Carrier
- Bikini Top & Hard Top Question
- RIPP Engine Integrity Question
- a new damn squeak!!!!!!help please!!!!!
- 3in lift Drive shaft
- aiming lights
- SO indecisive, can you relate? Lift/Tire input wanted.
- 35s Now and 37s Later?
- Can somebody help with a lift install question????
- 3" TF lift.
- Add spacer to BB, or get front coils?
- Anyone using the 2.5" Procomp Lift?
- How Did I Break This?
- Issue with my warrior rack
- Front Bumper Question
- Clarification re Aftermarket Tops
- Best mirror relocation
- Rough country 6” lift - How to adjust the draglink?
- 4.27 Gears for the D30 and D44?
- rugged ridge mirror relocate brackets
- Arb locker for rubicon
- Need help putting lights into my bumper
- Bestop 2 piece front doors?
- jack stands.
- Teraflex control arms question
- "c" Gussetts
- Driveshaft going??
- 33s, who is happy with them?
- LoD mid-width +winch install...
- ARB Air lockers or detroits??
- Need Ideas on yah or nay
- Dana 30 with 5.38 gears (How do they hold up?)
- PSC Hydro Assist steering - they really performed!
- Matching an OR-FAB tire carrier w/a different bumper
- breather hoses
- Lift for JK Unlimited Rubicon
- jeep lift and tires?
- Who makes this bumper?
- Rampage Front Recovery Bumper
- help
- Regearing a Diesel auto 4 door
- Rear Trackbar
- Lift kit Question
- Need Help LoD Signature Series Shorty Front Bumper
- ARB Bar with 37 Tires rubbing
- Help Suspension questions
- REAR Bumper suggestions
- Pure Ride Quality LIFT ANSWERS!!
- Help me find this!
- Need your opinion . . yet another lift question!
- JK Unlimited on OME with Standard Coils
- hood scoop??????
- 33 tires with 3.21 gears
- BDS 2" BL Installed
- JK belly protection
- superchips TIPS
- Question about Rivserts...
- looking for good mods
- 15x8 soft 8s with Toyo 35x13.5xR15 ?
- Computer flash after lift install question
- rockhard evap skid
- rear sway bar or no rear sway bar
- Has anybody run a 180 thermostat?
- Rough Country Wheel spacers
- Rugged Ridge XHD weighing down front end?
- sport bar
- MOOG Adjustable Ball Joints.....
- Who makes these skid plates?
- Need help with an issue I'm having
- RIPP meth problem
- Which lift kit and why
- Km2's vs. Procomp Extreme MTRs
- questions...
- Adjustable swaybar links from Northridge
- Real time help - Please - coil lift
- What gearing for 40 inch tires?
- Currie brake line leak
- LOD Rear Shorty or Full Width
- 15 inch Mickey Thompson Classic II's: do they fit?
- new lift
- Spare tire carrier/tire size
- Unlimited WARRIOR rack and Trektop notes
- Shortend Antenna? Anybody?
- Added 33's and it feels sluggish
- OME Lift Install ?'s
- hood hack
- Adjustable Track Bar/Allignment Question
- rotation, now a bit wobbly
- Grease Questions - Currie CAs and CV Reverse Zerks
- Whats the best rear tire carrier for 40 inch tires?
- Corner Guards with rock / tree tube?
- Future JK Build Up help
- rear stinger bumper/tire carrier?
- Axle Storage?
- Help with Wheel Width
- I am leaving it in your hands.....I'm done
- Which window tint closely matches OEM
- tire width
- Hy-lift steering mod
- Does anyone know what bumber this is?
- What rims/tires are these? ver. Teraflex Jeep
- Did my painted door sills
