View Full Version : Modified JK Tech
- 4 dr lift on a 2 dr?
- Coil Spring/Winch Bumper Questions
- How loud is a snorkel intake?
- Destroyed driveshaft - safe to drive at low speeds? Need help!
- Rubicon Shock Question
- Diablo, SuperChips or Bully Dog?
- Which Drive Shaft Do I Want?
- Wheel offsets
- Going big
- What Black Wheels Are Closest to OEM Wheel Specs?
- **Direct me which way to go for a LIFT**
- Do I NEED a lift with 33's?
- new here and need tech help
- Universal off road rack by Garvin - 61330, does it work on a 2011 JKU?
- GenRight Flares versus Poison Spyder Flares
- Need help
- TF BB shock extension help please
- AEV front bumper - need help with the right Winch
- full traction lift help
- Trying to understand gearing
- 2012 jku 4" full flex teraflex kit
- Actual measured size?
- 265/75r16
- DW I think
- Gear question
- 35s flat fenders no lift Questions
- OME springs stock shocks
- 33's and flat fender flares...who's got em?
- Bump steer cures... Ready, Set, Go!
- rough country 3.25 lift? whatta you guys think?
- XD rockstar rim problem!
- Will this cheap setup work/last?
- Tuff Stuff or ACE rails
- Theft deterrent?
- future setup!
- How loud is a cold air intake?
- question on 2012 front bumper
- Rear only body lift question
- Auto Locker or Not...
- Body roll after lift
- torque lbs question
- Problems with my JKS front trackbar
- 33" Wheel Combo Question?
- rusty's long arm upgrade........ not so happy
- Uber dumb tire size question
- Rough country coil lift question
- All Terrain Tire Question
- 2" Lift--Superlift vs. Superlift Spacer Lifts w/Shocks vs. AEV
- Opinions of Leather Package
- 2012 rubicon wheel whats the widest 35 i can get on it
- Currie Enterprises Rock Jock 70 and D44?
- stock tires
- Garvin Racks
- 15x8" Rim for 35x12.50 Tires?
- what size tires?
- D60 rear and D44 front...... or?
- Anyone hear of the gf chip?
- Grill paint/ tips!?
- Noob??Fender trim for Sahara????
- Help with BB
- Newbie Question Regarding C Gussets/Sleeves/Truss Kit
- Need help picking out new shoes
- Need a roof rack......
- Control Arms - Currie or Teraflex
- Throttle body spacer question
- Track Bar will not stay tight
- Bumpers...powder coat, rattle can or dip paint?
- 2012 grill guard , light bar or brush guard?
- 2012 4dr lift/exhaust question.
- Shocks and springs
- Winch in a stock bumper
- just installed 35s, not as slow as i thought!
- need help looking for grimlins....they are there!!!
- Poison Spider flares steel or aluminum
- Exhaust
- Cold air intake
- aFe performance package??
- Question about Procal and new tires/shift points
- Programmers
- RR bumper mount light bar, will hella 700ff fit
- Best cold air intake
- bedlined floor..?
- Axles. I want the serious off roaders opinions.
- Skids and warranty issues?
- What to worry about
- teraflex leveling kit?
- Gears question
- Poison spider
- 295s, stock rims, spacers, and shipping problems....
- Different Falken Wild Peak tread patterns...?
- Super Chargers
- It's time
- Steering stabilizer travel
- Drake billet aluminum grille inserts...
- It's new tire time...
- Fox steering stabilizer?
- the shop wont mount 35's to 15x8 wheel!!
- Aev black pintlers
- Ride quality with bigger tires
- Teraflex Prerunner - opinions
- Best/Easiest mod I've done yet
- Lookin to buy a black TMD hood
- What to do?
- Upgraded Steering
- DS question
- What are options for side protection with a body lift?
- Anyone got a 2D steel blue w/ black stock wheels?
- Newbie to the jeep world ? On what's needed
- AEV ProCal and TPMS -2012 JK
- Mastercraft handles
- COP 4x4 Hardtop
- Where does the AEV Procal mount ??
- AFN Front Bumper
- Tricks to Exhaust Install
- front bumper weight
- Some better pics of new 4" RC lift, control arms, stabilizer, etc
- Teraflex 1.5 leveling kit, springs or shock relocators?
- 30 spline rubi front locker?
- calling all 2 DR JK owners with the RK 2.5 MAX TRAVEL SYSTEM
- 15s on a jk
- Powdercoat
- driveshafts or regear? hmm
- What gears? (again)
- 2012 OME Lift w/ 3.6l JKU
- Evo rear LCA skids vs evo rock stat skids
- Newb Lift ?
- 17x9 wheel and tire question
- Need help with a mess in suspension and/or drivetrain. Calling all pros
- EVO Bumper
- OME lift showed up - kit changed?
- Falken Specs
- Sounds good to me?
- need help sorting this all out
- Bumper (F/R) + tire carrier + mounting locations for jerrycans == questions
- Lift Question!
- Steel wheels
- What sized gear puller for installing DS?
- Driveline vibration since gear change
- Tpms turn off?
- What air pressure do you run in your 35"s?
- RC lift vs TeraFlex
- Tire Carrier Advice
- 17" AEV Pintler w/ 35" on stock tire carrier
- Mopar Air Induction
- Control arms
- Backspace help!!
- Need help: What size hole to drill?
- New muffler
- Needing a lift.
- 2011 2DR JK lift
- lift or tires = less MPG?
- AC Compressor
- Orfab Tire Carrier Install Question
- Can tailgate handle a 35
- Regear Speedo Correction
- Caster question with 2" lift
- Pro Comp 7031's - who has them
- jks sector shaft brace
- Do 16" rims fit on a 2012 JKU?
- Brake help
- lift kits
- How Tell What Gears Unstalled
- Stock Mojave Spacer Question
- Screw you 17/32"!!!
- Why is my e-brake light on?
- TF BB 2.5" ?'s
- Is that all I need?
- 3.21's and 33's
- Bent swaybar
- Rugged Ridge Light install ??
- PSC brawler lite bumper?
- Anyone have pics or feedback on Toyo MTs in 35/13.50R15
- Stock Axle Question for Rubicon Owners...37s vs 35s
- Preliminary 2012 Pentastar Gear Chart (beta)
- From 4.10's to 4.88"s on 33's...worth the change?
- Hard uppers for half doors
- pro comp 52 series rock crawlers 15x8 problem..
- 33" Duratrac owners, winter inflation PSI?
- Wheel spacers
- Goodyear Duratrac?
- Pro Comp Simulated beadlocks 7028
- 37" irok radials or SSR's
- .065 gapped spark plug
- Gear Change ?
- Quadratec ball joints any good?
- 2012 jku-gibson duel or dynomax?
- +25 offset AEV Pintlers and 285 tires?
- Anyone running 35's with 4" bs?
- New carrier for gear swap?
- Cooper Discoverer ATP
- Intermittent Death Wobble
- Anyone install a Vector Offroad JKE Dock?
- fox,elka,bumstops?
- Any Recommendation on Exhaust System for JK
- 5.38 Gears and 37's
- Anticipating front end sag?
- After market heated seats
- Help with greasing Tom Woods driveshafts
- Death Wobble? Non-DW Shimmie and/or Wobbles? HELP PLEASE!!!
- Torn DS Boot / installing new drive shafts
- Level 8 Strike 5???
- 35x10.50 17 Super Swamper SSR
- Superchip flashpaq Q's
- those that are using the oem softtop tailgate bracket with trektop nx?
- Death wobble - with rubi springs and shocks
- Tire Upgrade Help!
- What is inner C?
- Yoke
- Rough Country 3.5 Series II or Teraflex 2.5
- Do I need to change my ge ars????
- What else needed?
- Which tie rod fits?
- Help with a front track bar problem!
- Tuners that work for 2011
- Will shocks make any difference in ride height?
- Anyone running the OR-Fab winch plate (87022) with their stubby bumper (83224)?
- New Bumper
- steering pump leaking!!
- OX Locker
- Aftermarket Dana 44 Front Axle Tube Comparison - Stock, Dynatrac and TeraFlex
- AEV 2" Spacer Lift Pic request
- PSC Rocker Knockers
- can i buy aev hood trim separate
- Need Help/Advice with set up.
- Rear Bumper Bolt Size?
- New to me Rubi Pics and a couple ?s
- How should i run this setup?
- What is the "driving experience" in a lifted JK with larger tires?
- Custom winch bumper, what front springs?
- Smittybilt Rock rail with steps
- JKS Quicker disconnects question
- What should I use?
- Questions about wheel sizes?
- New 2012 After Market Drive Shaft?
- Fender Flares; which brand to go with?
- Heated Wiper Blades/ Washer Fluid
- Added a Vibrant Resonator to the AFE Exhaust - no more drone!
- 2008 Manual tranny issue, looking for help/ideas
- Can adding sway bar disconnects effect alignment
- Pintlers are a go - what size tire??
- Hood washer sprayer relocate to wipers.
- You decide
- 3.73 with 35's on a 2012
- Pic request: 2-door Rubicon with AEV 2" Lift
- KM2 "Closeouts"
- What do you know about Seat Covers?
- RR xhd bumper help!
- axle sleeves
- Bump Steer After New 33's and Alignment
- Need an experienced painter opinion - vinyl aerosol paint on my blue Islander seats
