PDA
View Full Version : Modified JK Tech
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 [243] 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296
  1. Floor Jack?
  2. Adding spacers to 2.5" Coil Lift?
  3. Rusty's vs Rough Country shocks?
  4. 2.5 BB and control arms.
  5. I saw a thread.....
  6. Urgent American Eagle Question
  7. 3" rear coils
  8. Sway Bar link vs. brake line
  9. spacers
  10. Wrangler AT Extreme Tires
  11. Which locker should i get???
  12. Throttle body spacer with snorkel?
  13. TPMS ? on ordering tires on line
  14. ABS after Lift
  15. ???Total lift confusion???
  16. Blistein Shocks
  17. TSB - Electronic Stability Control Disable Feature For Modified 4WD Vehicles
  18. front gear install gone bad
  19. Trackbar bracket advise
  20. Backspacing? From Stock
  21. Alignment
  22. adjustable ball joint
  23. Lift Installation / Mechanic Advice
  24. Face lift help.
  25. About to re-gear ?
  26. conversion to long arm kit?
  27. 3" teraflex lift with arms
  28. Air intake - do they really work
  29. AEV Snorkel with CAI???
  30. Shocks too long... Suggestions, help please?
  31. Dirty AEM intake filter?
  32. 2.5" lift.....now what?
  33. Will Superwinch fit the ARB Bumper
  34. 15x10 with 2" backspacing, too much stress?
  35. Jeep J8 scoop
  36. After Market Clutch
  37. Xenon flares; rusting bolts
  38. Changing wheel size? (to 5x5.5)
  39. Full traction trac bars
  40. New Rubi Owner Needs Accessory Advice?
  41. ABS freakout
  42. Trying to widen my stance...
  43. whats going on...
  44. ?? about bed liner spray
  45. Aeroforce Interceptor parameters demystified
  46. jks control arms: anyone using them?
  47. 1.75 spacer/alignment
  48. Cummins 4BT in a JK ?????????
  49. 33's on stock rims?
  50. Snorkel Poll
  51. Lightest steel wheel ?
  52. State (us) laws impacting altered-height vehicles
  53. screaming eagle
  54. Mirror solution needed...
  55. milage just dropped at 4k miles
  56. Hypertech Users
  57. What tire will fit?
  58. 08 Rubicon w/ 4.10s. What for 35s?
  59. headliights adjusrment
  60. Rear trackbar bracket weld at axle broke
  61. Front Trackbar
  62. Engine ups grades
  63. 16 inch tires on 17 inch rims
  64. Just installed PA 1" bl...(I have tips)
  65. riddler cover?
  66. True lift height
  67. QA1 Adventure series shocks......anyone running them
  68. RC 2.5" Coil new spring install help
  69. widest tire with no rubbing?
  70. Stupid question
  71. Quick Control arm question
  72. Process to Re-center steering wheel after lift?
  73. 2" body lift with manual
  74. Rugged Ridge bumper a aftermarket fogs
  75. Side Marker & Signal Lights
  76. Any thoughts XDI cold air intake
  77. Lift advice for an idiot.
  78. Lift comments please
  79. Beware Superlift
  80. My 4" Superlift finally arrived...what's next?
  81. "Driving" Lights on Bumper...Thoughts/Comments???
  82. anyone have the hanson sliders??
  83. Unique-ish mods...
  84. 17x9 soft 8s
  85. 33's do I need shafts?
  86. wheel spacer bolt pattern question
  87. short to long question
  88. torque for lower and upper link arms
  89. Please help quickly...
  90. Gass Tank and clerance issue
  91. Lift and Disco
  92. spare tire weight
  93. tire questions?
  94. CJ 7 style mirrors
  95. Who Makes this Tire Carier???
  96. Mopar CAI
  97. Supertop or Superturd
  98. Help with Evap Canister
  99. 35s regear yes or no?
  100. 15 inch wheels will or will not fit?
  101. MORE body lift problem NEED HELP PLEASE
  102. Driveshaft Question
  103. bestop trektop
  104. deployed sailor looking for advice
  105. Another rear bumper question
  106. smittybilt extended brief top
  107. 35s and stock gears
  108. Teraflex rock sliders ????
  109. PA Body Lift and 2dr 6spd?
  110. New Driveshaft = Low speed Vibration
  111. 35's stock gears & hypertech module
  112. Rear Stinger???
  113. anyone using dyna beads on stock wheels/tires
  114. combining spacers with longer springs?
  115. Bumper opinions for my rig
  116. Lifts
  117. HighRock 4x4™ Slider Step
  118. Lift kit info overload
  119. Comfort Ride Lift
  120. 4" lift kit....really 4"?
  121. Driving without front driveshaft
  122. Trackbar Bracket and Drop Pitman Arm
  123. Help!...have $1500 bucks and wants to go 35! how?
  124. Offroad performance of 18 inch wheels
  125. Rubicon Express Lift?
  126. Suspension Stuff
  127. Teraflex Flex arms??
  128. OME Shock Question
  129. Immediate help needed!!!!!!!
  130. Have 3" lift now, but wanting to run 37's
  131. question about PA 1" BL
  132. front track bar pre-adjustment
  133. Tire - ProComp xtreme MT or DC MC
  134. CO2 Tank
  135. raked?
  136. Rc bb
  137. 33s and 3.23 gearing?
  138. Snorkel question
  139. Crush Cans
  140. Body lift help!!!
  141. another suspension & driveshaft question
  142. KC HiLites Hood Mount Light Bar
  143. Wheel Back spacing Question
  144. 2.5 lift with or without Tracbar relocatation bracket
  145. Rugged Ridge ORV 2.5" Coil Lift Kit??
  146. 2" BB..wheel spacers...stock tires-need Input
  147. JEEP will not honor my warranty
  148. Help
  149. Tools for Driveshaft Repair
  150. Mods that won't Void Warranty?
  151. spacers & spring compression?
  152. Lifted and have a Torn Driveshaft Boot?
  153. Thanks so much GUYS 513 Gears!!! WOL thanks again for all you do!
  154. Oil Change Light
  155. Aftermarket handles for our automatic shifter
  156. Lift level
  157. 488 and 33's
  158. JT front fenders
  159. Adj Rear Link Question
  160. Gas milage, 35's and other questions.
  161. OME long travel shocks
  162. steering adjustment
  163. Billet Hood Latch kit by ASM
  164. Accessory Part Numbers
  165. Alloy Axle U-joint??
  166. Would Ya? Firestone Destination M/T
  167. Shift Knob
  168. Bumpers
  169. Any Heavier duty springs out there?
  170. TPMS Replacement ?
  171. 2" Superlift - what's that sound?
  172. OR-Fab Rear Rocker Protector with Bar
  173. Toyo Vs. KM2
  174. RC 2.5 Coil Lift and 35s on Unlimited
  175. Best Gears
  176. Spend $5k on Jeep
  177. DriveShaft Help
  178. Center console removal help
  179. 2-dr LoD Rock Sliders
  180. bumpers and air bags
  181. rugged ridge modular bumper?
  182. Lift Question
  183. Did search still wondering (tires & gears)
  184. Balancing and Calibrating new rims and tires?
  185. Gas Milage on 33's
  186. OX Lockers
  187. Teraflex 2.5" BB Lift voids waranty?
  188. Hypertech Accupro or Maxpower for 6spd?
  189. 5-Point Harness
  190. Suspension Upgrades??????
  191. Warn M8000 pricing
  192. 2.5" lift. Talk to me about swaybar links
  193. Upgrade opnions...Clayton 3.5", BFG KM2 or Toyo
  194. 2.5" lift. Talk to me about trackbars
  195. steering wheel wobble
  196. Wierd Noise = New Driveshaft?
  197. Anyone running 18x9 wheels, like XD Hoss??
  198. Center Consoles???
  199. Bumper gap from Body lift?
  200. AEV Snorkel Options
  201. anyone running kumho mt tires?
  202. Lift ESP
  203. 2.5 progressive coil rough country lift help
  204. stock shoes with TF 2.5"bb lift?
  205. Tire Question
  206. Is 3/4" enough?
  207. For the few who have painted there rims ???
  208. Evo Rock Star Skids w/ TF 3"???
  209. Stock Sahara 18" rims w/no lift - Recommendation?
  210. Gear UPGRADE - Have questions and need help.
  211. Fence Mender Brakeline extension
  212. Pressure Vented Differentials
  213. Tf 2.5 coil issues???
  214. Wheel spacers
  215. cowl dent
  216. Help Wheels!!
  217. Help? ESP bas and handling issues after lift and 35's
  218. Rear Control Arm & Shock Bracket Skids ?
  219. Problem with Superior Gears HELP!!!
  220. Upper bolt lengths for rear shocks
  221. Riddler and JKS Trackbar
  222. dana 60's with stock 5on5 bolt pattern?
  223. Superwinch EPi9 with Shrockworks Mid-Width.... Anyone running this?
  224. About body lift 1"
  225. Gear Ratio Question?
  226. safety harness
  227. Detroit Locker Rear non-Rubicon D-44 Part #'s Please
  228. Rim Width Tire question....
  229. full traction 4.0" long arm anybody got one?
  230. What size Jack Stands?
  231. 2.5" suspension lift **BUT WHICH ONE?**
  232. Tires to fit my driving habits...
  233. Body Armor "Recon Rack" for JK
  234. Just need a little more room for those 35's
  235. Currie Control Arms
  236. Tom Woods Driveshaft Question and Problem
  237. What do you think guys of this lifting set up?
  238. clearing SOLID diff covers
  239. Question about Wheel Spaceers
  240. Ran into a problem with RC 2.5 BB
  241. Will Skyjacker 2.5 coil kit cure rake?
  242. Wheel alignment gone wrong!!
  243. warn xp 9.5 in a fab four bumper pitfa
  244. softest ride?
  245. Rock Krawler lift anyone?
  246. Cooper STT
  247. longer wheel lug bolts????
  248. MOPAR Slush Guards
  249. Currie cotrol arms
  250. MOPAR Rock Crawler Bumper
