View Full Version : Modified JK Tech
- Good place to get gears installed?
- Rear stock bumper swing arm?
- RE 2in spacer
- Pic Request 2 door w/ 35's NO LIFT and flat fenders
- Will I fit if I upgrade?
- Cheap but effective air compressor?
- 2012 Gears
- synergy 3" rear shocks?
- Front shock help
- 18" to a 15" wheel
- Spare tire rattle
- Opinions on tire carriers
- Does anyone have 37's on stock Sahara 18's?
- Rear Driving Shaft rubbing gas tank at full flex
- Lockers
- TF Leveling kit and front end alignment?
- Question about 33's on stock wheels
- Changing Shocks?
- LoD lite rear bumper ???
- Do balancing beads really work?
- Powder Coat Cost?
- TF HD steering stabilizer
- 35s or 37s?
- Smittybilt XRC with integrated fog lights.
- 60s
- Jeep noises, new lift.
- New owner needs lift advice
- Want to piece together a lift.. NEED SOME ADVICE
- Flat Fenders & RR Snorkel?
- trail only tires
- Rock Krawler Suspension Question?
- rear bumper suggestions!
- PIC Request, stock 4 dr with 1.75" Daystar poly spacer lift, or 2" spacer
- Hypertech MaxEnergy custom 3.8L tunes
- difference between rubicon and non rubicon rear 44?
- Lift Question - need help/advice
- Ram Intake or snorkel??
- Bending axle shafts
- Ever Break This???
- Xrc stinger pics??
- 2013 Rubicon wheels
- Fender ideas
- Bolt On Cages
- Scraped front diff and banged rear diff on rock
- Advice needed for 35's
- 6-Week Transition
- New gears for a JK
- Smittybilt doors!!
- Smittybilt Fender Flares XRC
- Lift and tires help please
- Shocks
- Supercharged 2013 on 37s!
- Front EVO coilover with Rugged Ridge Intake
- Rear Bumper Help
- Vector off road JKE dock
- Duratrac 315/70/17 question
- Help.. 3 dash lights on after putting on 37s
- Roof racks
- 6.4L Hemi $3500 ????
- New Lift - needs adj. front track bar???
- Chicago Area Line-x and final decisions
- TF 2.5" w/shocks - question about wheels spacers required
- First lift, some advice would be great!!
- Help selecting a lift kit
- 2.5 and 3 inch teraflex lift, on and offroad
- Mtr/k psi. New guy.
- what about these?
- help to select roll cage.
- Deciding on suspension
- Suspension question...
- Installed Raceline Bead Lock and now I have the shimies/wobble
- Super swampers
- Sad day for jeeps
- stacking spacers
- Genright
- Buying my 315/75r16 today duratracs need help.
- Quick EVO D Ring Mount question on stock bolt size
- Offroad 4x4 repair shops?
- Poison spyder help
- Another mod question. Gears or lights? Which first?
- 1st Gear Question - 4:10's, 6-Speeds, 35s
- Which set of control arms and driveshafts?
- Teraflex LCG and ACE Sliders Compatible???
- More tire help **sorry**
- Rocker Guards
- What's making this NOISE?
- JK Lugnuts... Help!
- Bout to pull the trigger!!
- Body Lift Quality?
- Adding Rubicon Shocks to my Unlimited Sport S
- Teraflex Performance Leveling kit and a winch
- $1000 first mods?
- Front lower control installed with angle wrong, help needed...
- Wobble over bumps
- Teraflex carrier with adjustable mount and stock rubi wheel question.
- I want to relocate the O/D button!
- Hit a cement divider last night with the jku
- 4in lift skyjacker
- Mickey Thompson ATZ P3
- camber bolts or not
- Was Rear Ended last night in my JK...
- Which 33's for a daily driver
- Any tips on aligning front LCA's with stock mounts?
- Will 295/70/17 rub on 2.5 with -6mm offset?
- Big mistake
- Creaking noise
- Rancho Exhaust Pipe Kit - Thank you Matt @ Rancho
- Suspension Question
- Front End Noise
- Quick fist holders
- Which Fox shock for my TF 4" kit???
- Magnaflow exhaust for 2011 JK
- Lift for my unlimited
- Help With Tire and Wheel
- Check my Budget Lift Setup?
- Pro/Educated Feedback needed. Research has led to more direct questions.
- Rubicon shocks and 1.75" spacer
- New Jeep Pre-Planning Questions
- Back from 11,000 mile roadtrip/expo. What maintenance?
- New Tires and Wheels
- Lift for 2012 Sport S Unlimited
- Just went ti 35's
- Anyone running 38's
- AEV Gen1 Snorkel 2012-2013
- Help Me Choose a Lift...
- Will 305/65R17 fit factory 17in wheels?
- What size wheel spacer?
- Help!!
- Trinity programer on 2011
- Drive shafts questions..
- 2.5'' rough country lift
- Aftermarket Steering Wheel
- Moonroofs in freedom panels
- Frankenlift or RK? With EVO coils...
- lift questions...
- Question about Teraflex HD carrier
- just got my relocation brackets and one lil prob
- 2.5 inch lift with Aev Geometry correction Brackets.
- What 315/75r16 to go with
- Any simulated bead locks with removable rings?
- Jerry cans on Mopar rear bumper??
- Braided lines
- 2 door jk on 37s
- Seat Covers
- Death Wobble
- New JK Owner - Need Some Tires, Suspension and Ring/Pinion Advice
- 35" or 37" tires with rugged ridge or rampage hi lift jack mount????
- Tinted soft top windows
- Rockstar Center Cap Measurements
- What Wheels Are These??
- Issue with a new u-joint on my rubicon express drive shaft... Anyone else?
- Rear window netting
- Proper maintenance for M/T tire?
- How much lift will rubicon springs and a leveling kit give an X/Sport?
- Help with pricing parts. Sliders, Teraflex 2.5'' lift, etc.
- Lug nut 3rd brake light
- Will these wheels with this width and backspacing by okay?
- Adding winch to ebay bumper
- 50" led whistle fix
- Show your frankenstein (pieced together) lift thread
- JK wheels and tires for my Sport
- Rock sliders
- Diablosport Problems...
- 5inch lift?
- Swapping s rubi transfer case into a x
- VDP endcap removal question
- 1" teraflex spacers
- Dick cepek gunmetal 7 and dc mud tires
- Wierd sound in reverse HELP
- Yukon 4.56 gears? Where?
- Brand new guy with a wheel question
- Ebay HD Tire Carrier (like the Teraflex HD Tire Carrier??)
- dynomax Evolution Competition exhaust
- TF tire carrier
- Metalcloak 72" Full Width Bumper
- 3.25" lift, anything missing?
- JK remote start bypass?
- Aftermarket Foglights
- Minimum lift
- Mesh Windows?
- Drivetrain losses
- Decals
- Smittybilt xrc bumper with winch
- What should I look for in gear/drivetrain upgrade for a daily driver?
- Ace vs EVO Rock Rails
- Skyjacker Lift Club - post your pics.
- Dynomax - Not too happy!
- RK 2.5 Max Travel Pro
- Where did the 15" wheel thread go
- Good deal on neoprene seat covers!
- Recommend a lift kit
- help with axle seal replacement.
- Trimming REAR REAR pinch seam??
- HELP!! Best replacement for blown front diffrenentiall and drive shaft.
- Fox shocks
- Help On New Rims & Tires
- Aluminum bumper?
- Looking for aggressive AT tire - 285/75/17 or 285/70/17?
- I'v got a gear ? Need help quick !
- AEV snorkel and Metalcloak fenders work together?
- Lift kits
- Jku 08 pulling left and wanders
- Hidden winch mounted upright on OE bumper
- Which shocks would u get? Or which is better?
- Goodyear MT/R's or Nitto Grapplers?
- Rr snorkel install sealent question
- Help with Flex
- AC vent paint fail
- help me find somw wheels
- Tera30 Heavy Duty Axle Housing
- Pentastar, 35s, 4.10s ????
- Metal Cloak Control Arms
- Rear axles advice 2010 Rubicon
- Installed Teraflex Track Bar and Steering Stab, now ESP light is on?
- Can you powdercoat?
- JK exhaust diameter??
- Viking's New Sexbomb of a winch
- Replacement springs leveling kit question
- flash to stock
- Which mod? Truck-lite/rigid combo or exhaust?
- HELP ME CHOOSE: Highrock Full Element Doors or Bestop Full Soft Superdoors
- Currie rear anitrock sway bar
- 2012 JK8 $65,000... Really??
- Mounting method for ORI struts in the rear
- YAY I fixed my Death Wobble!, thank you planman!!
- Poison spyder diff covers stock suspension install
- TPMS AEV procal / diablo trinity tuner
- Backspacing for mb chaos 5's
- Rhino lined rocker panels
- AEV pintler black or argent show you pics
- Body Armor JK-1951 Tube Bumper?
- Wrecked Rubi
- Bumper end caps
- Winches
- Anyone ever had regrets after getting 37's and go back to 35's?
- 315 treadwrights on stock wheels
- 2.5 TF coils and Adj control arms question
- flighty steering problem, need advise!!
- is this roof rack for 2 door or 4 door?
- Jeep shocks what to get with leveling kit time for new shocks.
- 35's or 37's for a DD
- Teraflex Performance leveling kit VS. Eibach Leveling Kit
- Any pix of bestop nx with smittybilt cargo netting on in safari mode.
- Busted Tie Rod, Drag Link and Steering stabilizer....
- Question for the 4dr Trektop NX Owners
- exhaust opinions
- Anyway to extend out the steering wheel?
- Regearing cost
- Eibach front 1 3/4" coils.
- Lower rocker protection
