View Full Version : Modified JK Tech
- Help me engineer my junk!
- articulation and bump stops
- Question about Rancho 9000XL shocks
- Need help making desision
- JKU long arm + aftermarket driveshaft owners answer me this...
- 6" Tera Long Arm or 4" Tera long arm with flat fenders
- Poison spyder bumpers?
- tpms has no light on?
- Tire Size Question
- Need another 1/2" of lift on the front
- Would this setup work? 285/70r17 on Rubi w/ only .75 front lift
- Who has 5.13 with a auto???
- A question for those with experience in situation
- Smittybilt Front XRC Bumper
- My Superchip milage.... FAIL!
- lift help needed!
- winch help
- Anyone know about body lifts???
- Bikini top, Windjammer, Deck Cover question....
- JK Wrangler Grill Mod - A Different Way
- Popping sound
- Safari Top / Sun Bonnet....Help Needed
- 40" tire fitment
- Dented oil filter
- should I regear?
- Dynomax exhaust
- Bestop Highrock 4x4 Flares, that attach to OEM flares.
- safari top ...
- Exhaust + CAI + Programmer + stock = 24 mpg?
- Body lift or spacers???
- weak link
- How much space should I have between bumpstops
- Bilstein Shocks
- LoD Mid-Width Installed - Couple of Questions
- mopar seat warmers
- It's new drive shaft time
- 37s Stock 3.73 Gears?
- Front Passenger Seat Rail Extension
- Squeaky Wheels?
- Not sure what lift. Tf or rk
- which lifts is best?
- 33 inch spare
- External air temperature off.
- is it better to buy 16inch rims with more backspacking or just get spacers?
- What Lift Kit to get?
- EAP BSP light is on ?
- A couple problems on my last long road trip - thoughts?
- Upgrading brakes and rotors
- Dumb Question, Maintenance Free Lift?
- backspacing question
- Question on upgrading lift????
- What gears to run?
- Which lift kit to get!
- susp lift springs
- c-gusset question
- ESP and BAS light on
- Point me to Maxxis Bighorn specs showing weight
- Rokmen
- rock krawler tie rod
- bumper weight...
- Tire from beadlock to stock rubi wheel?
- which c-gussets & sleeves to go with??
- Question About Front Driveshaft Yoke
- gear oil level
- Cover for Tub Holes from Rubicon Rocker Rails?
- Lift Decisions
- Performance Distributors coil pack & wires
- front diff gear oil question...
- Tailgate Storage options...
- rear sway bar link rub vs TERAFLEX 2.5 LIFT
- Stock license plate holder with shorty bumper?
- Regearing 2010 4dr JKU Rubi AT with 33's
- rear swaybar
- What's with all the lousy stickers on my winch??
- Replacement Steering Box
- Bilstein 5160s........
- Question about my front sway bar links/disconnects.
- Mopar 2 inch lift kit
- 35s on a moab or a 15" rim
- Alternative to MOPAR Sun Bonnet/Windjamer kit
- Anyone got a Trektop NX yet?
- Changing Gears
- What lift for ME?
- 2dr driveshaft help!!!!!!!!!!!
- Superchips Tow Tune on 87 octane
- What do I gain from a long arm lift?
- premium gas
- Teraflex lift
- Bestop Highrock Tray
- Question about wheel spacers.
- Question on how long jk will last?
- Gears, Covers and C-gussets done
- Gobi Rack + hardtop question
- Trutrac vs Aussie (et al)
- Best offroad mods but stil good for daily driving
- Superchips or Bully Dog most user friendly ?
- Electric Sway Bar Disconnect
- Which sound do you like better?
- 295/70/17 with Tereflex leveling kit?
- Rear pinion angle??
- Questions about airock
- Rock Hard Oil Pan Skid on 2door - rattle issues
- Gears for a JKU
- Black rock series 997
- fox racing 2.0 ?????
- I want to cruise in the Desert
- Brake line being rubbed on rear shock after 2.5" TF lift, what to do?
- General Grabber Reds 35x12.50x17
- 2dr vs 4dr w/ superchips
- New tires being ordered
- 2nd Post newbie (I know you love us) with some questions
- Atlas kit?
- Rugged Ridge Weather Lite Cab Cover
- OR-Fab Jeep JK Rear Tire Carrier , that much stronger?
- Just got back from getting my frist Road Force Balance....FAIL
- Tear in Currie Drag Link boot
- Tire recommendations: M/T vs. A/t
- Tire holder question?
- Similar ride height? Teraflex 2.5" Coil Lift vs Rock Krawler 2.5" Stock Mod
- Rear track bar hitting diff cover...
- Rampage Hood Lock and Flat Fenders
- Anyone answer a superchi ????
- 2011 rear seat fit other years?
- AEV Hood Owners!
- XHD Bumpers with endcaps!
- Rugged Ridge Hinge Overlay or Replace ?
- Yes i know! Another tire thread
- Front Track Bar Problems
- Why can’t anyone pin down the best lifts?
- Superchip help please
- Need help superchip question
- Wheel color opinion
- AEV Snorkel + OEM to AEV Heat Reduction Hood - bracket or no bracket?
- Superchips Flaspac purchase
- Anyone with 5.13? On a automatic?
- Replacing footman's loop (that plastic looking handle on hood)
- Painting tow hooks?
- Towing 3000 boat with jku on 35s with 3.73s
- Build Questions???
- Bias Ply Tire Question.
- Procal - This is odd or is it?
- Start with 35s or start with 37s?
- trektop windshield knob solution
- What are the options for non plastic flat fenders?
- Rusty's FLCA's
- Front Springs Bending Outward
- Maybe a driveshaft click not sure need help!!!!!
- Got some goodies... and some ???'s
- Help with spacers and lift ???
- Old Style Trek Top Any Problems?
- Old Man Emu shocks for 0" lift?
- Breather tube extensions
- why do BFG's run small?
- Steering wheel centering
- 35" Tires with minimal lift
- flashpaq questions
- Bilstein 5100 mounting orientation, confused?
- Shimmy at 55 to 80 km/h
- Lift Question
- Looking for a Body Lift. Which one?
- advice on front drive shaft install
- Side steps that can be used with the rubicon rock rails?
- Best Quality Lift
- spidertrax spacer question
- 3 inch shocks with 2.5 lift?
- mopar rear bumper issue
- Teraflex 2.5 BB kit questions.
- Rock Hard 4x4 Rear Bumper and Tire Carrier; are you pleased?
- license plate bracket for spare tire
- The jeep green picture thread
- Bad ball joints? What if I don't replace right away?
- Com bolts/Caster bolt, Am I screwed?
- Mamba MR-1s or takeoff Moabs?
- I believe i have an idea about 2012 wrangler release time table
- Stubby Front Bumper Under $500
- Alignment specs
- Death Wobble - Need Help
- Sanity check: Going for 4.88 & 33, some towing, 6sp, no 35's in future
- Exhaust getting squashed by my rear tracbar
- Anyone have Rough Country Shocks 2.2
- M/t or a/t
- xd series badlands
- starter not turning flywheel problem...
- Can I install a TJ rear bumper on a JK
- K&N replacement air filter or oem?
- Lift kit for 33's
- Poll: Pulling the trigger on 35's need help making up my mind
- OME Lift Conplete... now for the sway bar disconnects!
- Help with a few tools that would help with my modifications.
- Worth replacing factory limited slip with selectable locker?
- Zone 4 inch lift on a 2011 Wrangler unlimited sport.. I need some help
- What is needed for 60 install?
- Installing a Rubi D44 into a Sahara or X
- How much to re-calibrate speedo
- Front or Rear Shock Replacement - Which one first?
- It's official...getn atlas!!
- Besttop Intsatrunk and Mopar Boot
- Do i need Leveling Kit Shock extensions with aftermarket shocks?
- Rock krawler 3.5 x factor mid arm!
- lengthening wheelbase and compatibility issues- need help
- Need HELP or advice on bumper and spacers please
- anyone running 37s on 4.88?
- Good spacers?
- Bumper weight????
- Track Bar help - Clayton, Currie, or JKS
- Currie Upper Adjustable Control Arm - Caster Adjustment Reference
- **NEW** Magnaflow Offroad Pro Series Cat back Exhaust
- Front axle u-joints for JK Rubicon?
- Mud + Winches = Good Idea?
- New front winch bumper
- exhaust help
- I have the RR modular light mount bumper and want to put a winch on it.
- Teraflex spacer problem
- gobi roof racks
- I need help!!
- Stock Rubicon shocks and lift springs?
- Need help with lockers
- which mod next?
- Best Roof Rack
- In search of the perfect RUBBER
- Bolt size?
- help need- looking for a picture of the stock front DS connecting the the Tcase
- Steering shimmy/vibration question?
- Pitman arm ?
- Bed lined the inside now......
- Best Leveling Kit
- axle centering question
- cargo netting getting in the way of soft top?
- 37" Setup
- Aftermarket parts different for 2011 Wrangler?
- Doubts about my build...
- Lets talk steering components and larger tires!
- Safari Straps cargo net
- JKS front trackbar bushing replacment
- Another lift question? Please help....
- Whats the best lift for 4dr jk?
- Another.. Opinion on lift thread Rough Country
- XD Hoss rings
- Just mounted new tires. Help with what PSI to run
- Possisble issue with JKS trackbar... does this look normal?
- hood latch
- Tubular Doors
- Winch help please
- Pros and cons of using Axeltech Bolt-It. When operating JK.
- Superchips tuning
- 2dr-Goodyear Duratracs 35's
- Ripp headers
- Regearing JK 2 Door 6 Speed
- Bilstein or ???
- Please Help, Bad Driveline Vibes!
