- leveling lift and track bar
- Knocking noise underneath driver side while driving at high speeds
- Lizard skin instead of LineX?
- Teraflex Leveling Kit w/ Bushwacker Flats and 35's
- No rear trackbar, cross link system instead?
- Xrc rear bumper
- will a 35 on a 15inch wheel fit on my stock jk?
- Stinger bumper
- Dorked up Airaid CAI install
- weird noise issue
- Old Teraflex 2.5 in. coil lift on new 2012 2dr sport
- 2.5" Teraflex coil lift wth teraflex leveling kit = have to worry about lifting 3"?
- Weld On LCA Skids
- installing new lift, what size tires would be best to run?
- Need help adjusting my caster
- je reel instal question..
- what front adj trac bar to buy?
- Need Help! Shock Extensions Teraflex 2.5 Coil Lift with OME Shocks
- Confused about gears
- If I'd only looked on the forum first!!!
- Help rear tires close to pinch seam
- What steering stabilizer to get
- RIPP Header Help
- Is This Normal???
- 4" Full-Traction LongArm on 2door enough for 40's?
- BMF Novakane's
- 2012 and Procal problem
- Squeaking question
- Front shock top bolt tightness?
- Squeak on front passenger wheel?? Help??
- 15" rim question.... Again
- Trimmed stock silver fender
- LOD bumper install help
- Can anyone answer this?
- Pro-Comp Alloy "Cast Blast" finish issues????
- Wobble when turning. Help!
- Gobi Stealth rack issues
- need light recommendation for grille guard
- True dual exhaust coming soon
- AEV ProCal Module for Jeep JK’s.
- teraflex 2.5 coil lift and 3in lift w/shocks
- Problems with LOD Skidplate
- Best programmer for 2012 JKU?
- teraflex disco question
- Lift Suggestions...
- Blacked out interior
- Jk to tj seat brackets
- Or Fab rear bumper
- Spare Tire Mount? 33's
- Got my headers look!!!
- lift question
- Gear Change 3.73 to 5.13 Observations After
- Longer ABS cables
- Anyone tried this for tinting soft top windows
- plasti dippin the grill
- 34' with 2.5 Lift and Bushwackers
- MT Classic II care
- Lift questions and no answers????
- 1/2" spacer on top of a 2" spacer question
- What da.....
- train horn /airbag sensor ?
- Post lift install question
- Summer time soft top?
- Tire carriers.
- For those with remote QD OBA connections - Mount location and hose route
- Mounting a larger rear spare?
- Is this too much for gears to be installed?
- Who makes the new 2012 Mopar lifts...
- Not A Jeep Bumper, but
- Rancho lift?
- Broken sway bar mount
- Need Help
- Possibly Trading Tires, okay deal?
- what different with 2.5" Budget Boost Suspension and just normal 2.5in lift kite?
- teraflex 2.5 question rear spring retainer?
- Improved MPG...I'm a believer!
- Flowmaster on 2012 JK
- is the steering stablizer really needed?
- What tire will look better?
- Holy Cow Man......replacement shocks for unlifted JK?
- Adding extra lift
- Excellent Document Regarding Supercharger Technology From the Man who Designed both
- Stripped the Threads In My Differential Installing My CRC and Need Help!
- Opinions on these parts?
- Rock ring
- Red Rock w/ Black Rock Viper Wheels?? Anyone???
- Help me figure out the brand of this stubby
- Full Face Steelies for JK????
- ARB diff covers with OME 2" lift
- Tires and a lift + lots of help
- Question for anyone with rock rings
- DuraTrac Tire help (again)
- Self Threading Bolts for Rock Sliders???
- Bumpsteer and Death wobble are making me losing my mind
- 33"s on my JK?
- What will shock extensions gain me?
- DRIVELINE vibration question
- LOD Bumper Question
- 4.0i
- Bestop Highrock Slider Step opinions
- Currie Antirock Sway Bar?
- She said I could spend money! Opinions.
- Rock Krawler HD Tie Rod Steering Stabilizer Bracket
- Lift
- Used Banks "ram' air CAI and Superchips programer worth it?
- " 35's and lift kit, how stuck can you get"
- Serious mods coming soon! Where to go?
- Corner armor--the plastic stuff any good?
- Stock flares cut really narrow?
- whats a good BB for my 07?
- about teraflex 2.5 lift kits
- Tire size diffrence
- 4" Rough Country Write-Up
- EVO protek skid for manual transmission. anyone has it? comments about it?
- What different with mopar 17'' wheel black and aev sarverge?
- Wheel question
- ? about any 3" lifts
- Securing Bolt ons
- 2" rear spacer
- TeraFlex 3" Lift Kit Question
- Which Front Driveshaft ?
- Look what I got of Craigslist for $150!!
- Sun Bonnets
- Cop4x4 Nack Attack?
- Leveling Kit on My Stock JK
- After lift: rear drive shaft angle too steep?
- xhd rear bumper
- What would you do? Painted stock steelies or leave them silver?
- death wobble
- Resting JKU on jack stands ?
- Hello Everyone!
- Cobra magnetic base mount and firestick II cb antenna
- Is this going to be needed?
- rough country 3.25 lift
- Any info on a Rusty's 3.25" Advanced lift kit out there?
- 2012 sway motor flip?
- replaced lower control arm brackets
- Aluminum or steel bumper
- 35" tires on Stock Rubicon Wheels
- After market leather seats or rewrap the current factory seats?
- Am I the only one
- What lights for the RR XHD bumper?
- No Spare Tailgate
- Rock Hard "Straight Across Rear Bar" for Harnesses?
- recommend me good 2.5in lift kit brand..
- Rugged Ridge light bar with lights... wind noise?
- Modding in Moderation
- Changing rear pinion angle with stock drive shaft?
- ETA on tuners for 2012?
- Best overall wheel/tires to go with?
- Love/Hate relationship with the Trektop NX
- My planned upgrades.
- How much backspacing do i need?
- Looking for people that have the Pure Jeep Dana 30 axle truss
- Labor - ball park estimation
- Alignment question
- teraflex qucik disco issue
- Fox Racing vs Bilstein 5100
- Teraflex 44
- Just started on my jeep build
- Vector GGR (or option?)
- Gussets and sleeves for 35" tires
- new to the game opinions on my future set up....
- new to the game options on my future set up....
- Your advice pls on Catback Exhaust
- Radius Arm and drop bracket vs upgraded control arm
- Low down on 2007 Sahara with 325-65-18 and 4.10s w/ auto
- Track bar install help!
- BEST LIFT????....for running 37s mild to moderate
- Wheels for a black jku
- trail grappler on sahara stock wheel?
- Rubicon Lockers Vs. ARB lockers
- Front coil spacer without factory isolator
- 37's Prep Talk
- ABS and traction control lights...
- Any info Zone 4" lift ?????
- quick question..295/70/17
- All SRC Pics?
- Should I put TPMS on my 35's?
- Smittybilt rock rails
- Exhaust spacers or equivelant
- Fast back 4 door w/ rack
- new exhaust
- problem with AEV 3.5in lift plz help
- Rugged Ridge XHD bumpers=Rust!
- Changing gear ratios to 5.38 - what parts to buy?
- Tire size
- Whats the correct gearing and cost???
- Ace rock sliders
- roof rack or mount for tire inside rear cargo area??
- Berserker JK Bumper!?!?
- Or fab gecko skin corners with ps rocker
- Beadlock shopping....
- 3:21 question
- rough country 2.5 coils ???
- Homemade Sun Shade question - Dimensions needed
- New 35's
- Hot oil light
- tire weight????
- Best tire deals
- Regear?
- Actual height of 35" KM2
- Transmission Noise any help appreciated!
- Body Armor rear bumper
- Tuffy Security Deck Question
- Any opinions on RubiCrawler product (or reduction kits in general)
- Shocks or Springs
- Bestop Trektop NX issue on 2012 JKU
- opinion on tires...
- Pulling my stinking hair out!!!
- Thinking of upgrading to a 4" lift
- regear -or- tuner??
- Front Bumpers: Skid vs No Skid
- opinions between these two anyone?
- Rear Axle/alignment after small hit
- Rubi suspension
- 2011 / 2012 Dash Overlays ??
- Will a 2007-2010 (2 door) hardtop fit a 2012?
- Truetrac
- EVO Tire Carrier
- Drive line planning Part I
- Want to run 37" tires, can I keep my drive shafts (2011 Rubicon-U)?
- smitty tube doors
- What would be the best gears.
- Grill mod write up
- Jk wheel adapters 5x5 to 5x4.5??
- Best Place To Mount Auxiliary Lights
- Smaller wheels bigger tires
- Stock parts after lift install - How long do you keep
- 35s or 37's
- Axle shopping
- My First Mod
- hard time finding wheels
- Lift/Wheel/Tire Question
- Advice
- when is it done?
- Sahara Bumper Covers - Removal
- Ordering shocks...suggestions?
- Looking to lift 2dr but..
- What size tires?
- Hanson euro spec bumper - anyone running one?
- Wheels sticking out past fenders question
- Removing GRILL Question w winch
- 4" Frankenlift Needs Help!
- Tire Carrier help
- BDS tunes fox shocks or bilstein5100 ...?
- federal couragia mt
- What shocks should I get??
- Throw out Bearing toast****what to expect
- ARB Lockers
