View Full Version : Modified JK Tech
- Superchip vs. AEV ProCal?
- rear bumper off a YJ would it work?
- Goodyear MT/R Feedback
- Accident - front axle shifted and turned
- Someone Vandalized my Jeep
- Detroit locker in the rear?
- Wild Boar Hardtops
- Driver side tire rubbing
- Time to regear, What to do?
- RC vs. Teraflex
- Adding shock extensions to a teraflex leveling kit. Need help!
- Info on retreads
- Old style Goodyear MTR
- OEM front driveshaft torque specs?
- Full Traction JK 4-Door 3" Jeep JK Premium Plus 0% Maintenance Questions???
- Need Some Answers Prior to Next Weekend's Install
- Budget boosts
- Or-Fab Tire Carrier Question
- RIPP Supercharger and tranny cooler
- Teraflex 2.5 Budget Boost w/adaptors
- Rough Country lift question
- Smittybilt SRC Roof Rack
- Recommended grease
- Most lift for a '09 2 Dr without changing drive shafts?
- 37s. Whats the best road tire?
- Is it possible.........
- Is it Ok to put heated seats between seat and covers?
- Swapping wheels between wrangler and compass?
- Smittybilt Vs. Rugged Ridge rear bumpers
- Magnaflow cat back installed!
- b&m trans cooler
- RC 3.5" lift and trackbar question
- 4 inch with 35's or 6 inch with 37's ???
- Currie Johnny Joint not taking grease where it should...
- Can someone please tell me which wheels these are ?
- Auto trans cooler
- help me find this part
- Engine Mods?
- Grease gun eats zerk!
- stock 17s or cheap 15s??
- 6" X-series ROUGH COUNTRY LIFT QUESTIONS !!
- BB vs. Leveling kit
- Wheel Question- Backspacing
- 2.5" teraflex coil lift questions
- Which programmer?
- Benchmark or LoD please help
- Lift Kit Advice?
- Bushwacker w/Bumper -- ?????
- best BS for 37" tires
- Freedom Top Clear top
- balljoint warranty? with 4 lift and 35 plus
- Steering Stabilizer Resistance
- Soo many questions!!!
- Should I Stinger?
- Notes on installing a Woods Steering Stabilizer Relocation Bracket
- Rear Bumper Tire Carrier Selection
- Rear Bumper Tire Carriers and Bolt Pattern
- Recommendations for under armor??
- NITTO TRAIL Grapplers and snow
- greaseable ball joints
- Is This Normal?
- boat anchor
- To all RC 4in Xseries lift owners
- More Winch choices...
- How is the flex w/ teraflex coil leveling kit, and stock shocks???
- Anyone runnin Duratrac 285-70-17 on stock wheels
- Zone Shocks
- Off Road Evolution EVO Coilover Install???
- Rhino lined floors?
- Does anybody have this and what do u think?
- Pro Comp 4/2 Suspension System
- IROK radial???
- Rear Bumper w/carrier
- 33 inch tires
- what size spacers for rockstars?
- How do I get the most out of my budget boost?
- 4.56 vs 4.88 gearing
- 325/60/18 *&%^*&^%$
- How to measure your suspension sag and what spacers to buy?
- 285 75 16 on a stock 2007 JK
- Leveling Kit / Tire Set Up ???
- my build-what shoud be next?
- Which skid plates?
- 33's on 15's?
- Bump stops
- Fitting Factory Rear Sway Bar Link w/ Teraflex 2.5" Coil Lift??
- Caster and Pinion Angle
- AEV Snorkel + Bushwacker Pocket Flares = Recipe For Destruction?
- Bumper matching - I need some opinions
- 5.38 gear durability
- RR XHD Modular Front Bumper or Superchips FP??
- Budget Boosts vs. Full suspension lifts
- 35's with 3.21 Gears
- Disco'd and DS damage?'s
- auto to manual
- Warn 9.5ti winch on Smittybilt XRC bumper
- spring sagging
- Adjustable fuel pressure regulator
- Exhausts
- Any Pwr. or Tor. Mods That Actually Work for the 3.8?
- Dana30 jk and dana 30 tj front tru trac
- New LOD Gerry Can Mounts
- Rubicon Springs in an X
- Cam Bolts? Differenece in 3.5" lift and 4" lift!?!
- Bumpers n Winches?
- Rim offset
- lca length for 4 " lift
- some tire and wheel questions
- Black Rock Viper Rims Fitment?
- clearing hypertech for resale
- Smittybilt hard top
- how do you guys fix sag from winch and bumper weight?
- Noob Looking for advice
- Radial SS IROCs 37s or 39s
- Goodyear DuraTrac 285 70/R17 Air Pressure
- PRESS RELEASE: Full-Traction Suspension 3″ Economy Plus Lift Kit
- sway bar link? after bb install
- Delta Fogs w RR XHD bumper
- New driveshaft time. Anyone install the differential yolk themselves?
- Tires Poll
- Mounting spare to tuffy security deck
- Looking for different tires...
- MPG's: 33's w/4.88's and 6-speed???
- 37's on 17's?
- Define bump steer please!
- Supercharger Bolt-On Kit
- Prorock 44 question
- Is my winch waterproof?
- Got my 9.5ti on my shrockworks...kind of
- Teraflex, RE or Skyjacker BB?
- What next???
- finding the truth
- Wheel clearance concerns
- 35's and 1 inch of lift
- 3.73 to 5.13
- TeraFlex quick discos
- Rubi | D44 | 5:38 | Auto
- Question for Smittybilt XRC rear bumper owners
- Coil spacer take away articulation?
- need advice on tires?????????
- Quick question for those w/tf 2.5" coil lift and bumper/winch...
- 4.88 or 5.13 on a Automatic
- Corbeau or Mastercraft seats?
- Exhaust
- Need help on TF 2.5
- Why are beadlocks not for street use?
- Gearing
- In the market to replace rock sliders
- Lifts & Backspacing
- our bolt pattern is 5x5 right?
- Axle alignment issues-JKS adj bar
- Regearing from 3.21 to 4.88
- Front lockers
- Who has a "Locked" front Sahara Diff.? (Dana30)
- Roof/ Rear/ Side Cargo netting
- Lift Question
- Track bar bracket for leveling kit?
- drivetrain
- exhaust system - warranty
- Warn M8000 Solenoid location
- Height measurements for setting speedo with procal
- 33'' & 35'' BFG KM2 real heigh mesurement
- Injecting expanding foam into the hard top?
- Upholstery - Hardtop interior
- Looking to up grade coil springs
- Superchips craw mode?
- Rough Country 4" X-Series vs. TeraFlex 3" w/ Full FlexArms
- rock krawler lift and ripp headers ?
- 3.8L Engine Build
- Factory Plastic Garbage Mods
- Fairlead
- custom built bumper question....
- Hot Gears
- 4" rc shocks with a @" b.b. ???
- Gear set
- LT285/70R17, stock rims, no lift, no spacers?
- Banks or AEM CAI?
- What will fit.....
- Lookinh at lifting my 07 unlimited sahara
- synthetic vs wire winch, which is better?
- Bump stop space-your thoughts.
- Best all around tire
- How is the Evolustion Coilover system, especially for the front part?
- Long term hard top removal for outdoor storage in the summer.
- Tire vs. Wheel/Rim - Which is best?
- daystar dash gaps?
- Looking for info on cutting down the padding on my stock driver's seat
- Anyone have a hard top insulation kit?
- Driveshaft Vibrations....
- Spare tire bracket help....
- Putting 32's on stock X
- I'm confused!! Dana 30
- XRC-8 on SRC Bumper install questions...
- Foam or Padding
- quick question guys
- Broken Headlight Guard (Rugged Ridge)
- No fender liners
- Lifts, Bumpers, etc
- Teraflex 2.5 question
- front driveshaft length
- should i be worried?
- Gen right aluminum tire carrier
- Hey guys
- Rugged Ridge Mirror Relocation Help
- Finally time for lift and tires
- Snorkel
- Front in rear brakes gone in just 3.5 years!!!?!?!
- New to jeep lifts
- What Do I Need To Modify?
- Will tires and wheels fit my JK?
- What Next???
- Floating Feeling??
- Anyone running the rugged ridge extreme rear bumper and tire carrier?
- Jeep warranty if lifted
- Or fab rear bumper
- Newbie - Will 285/65/18 tires fit without lifting?
- Protecting Interior Wheel Wells
- Drake Off Road Billet Aluminum Locking Fuel Cap DOES FIT 2.8 CRD DIESEL
- Lunchbox locker in a open 2010 d44(rear),need help?
- How much coverage from Bushwacker Fender Flares (if any)
- Gearing recommendations
- Rugged Ridge or HyLine
- Any reason not to buy the tuffy security decklid?
- Spacer lift
- Tips on Or-Fab Side Armor Install
- Pro Comp 1.75" leveling kit questions
- HELP! Rubicon Express JK Front Track Bar
- Goodyear Duratracs at 52 psi...in the SNOW!!!
- auto driveshaft in a manual
- anyone running the zone offroad lift??
- spacer install qustion...
- anything wrong with the track bar here???
- Advice needed... Proper components to do a 2.5" - 3" Lift Kit with 35" tires
- Spare tire reinforcement kit?!
- Broken rear track bar mount!
- dual steering stabilizer help!
- Wife just got death wobble.
- coil spacer 3/4" vs 1 3/4"
- .......What can I get for.....
- what's wrong here??!!
- OME lift Concerns
- 2.5 lift questions
- Tire carrier recommendations. Fast washboard driving.
- nfg here - will this combo work?
- JK Rubicon tire problems
- TPMS question...
- Rancho Oil Pan Skid
- What is the best option for running a 35" spare without replacing rear bumper?
- Will Bestop Supertop windows work with stock softtop?
- Would I need Axles for a TF 2.5 and 35s?
