View Full Version : Modified JK Tech
- Sof top window Window Storage Duffle ??
- Lift Kit under $1,100
- Setup for mounting gear to the rear floor
- Can't decide - JCR or RH4x4 Skids
- Need a little exterior help.
- Daily Driver tire ..Duratrac or G2
- Salvage Title JK Rebuild - In a Week and a Half
- Bent sway bar
- Adj. Front Track Bar?
- rear bumper tire carrier combo
- Junkyard Axle Questions.
- Raptor liner--any advice?
- Limb Risers
- P0420 Check Engine Light Code?
- ADJ Front Lowe CA
- ABS Help
- front draglink question??
- Re-gear question
- steering stabilizer?
- 35's and 3.73 gears no problem?
- 2015 Rubicon Hard Rock Wheel Offset?
- Crawler Conceptz Body Mounted Tire Carrier (Pic heavy post)
- 37s on mostly stock components
- what do wheels weigh
- what diff cover sees more damage
- CB radio
- Rear Seat Belt Replacement Help and Advice please....
- wheel liners?
- SuperChips Tire Size and Update
- 2015 JK Sahara getting lifted today!!!
- OffRoad Xtreme gives the ProCharger Supercharger kit a whirl.....(3.6L Boost!)
- Alternate TRE for Synergy Tie-Rod & Drag-Link?
- Has anyone used justjeep.com and liked?
- Help and possible fix for rubbing issue
- Help and possible fix for scrubbing issue
- Help with AEV Control Arm Bracket
- Thoughts about Dana 30 armor?
- Code readers
- Upgrading my wheels, info please
- Tramp Stamp
- Manual transmission fluid for NSG-370. Has it changed ?
- A quick favor
- Will 5.13's & a 3.8 auto with 33's work?
- Help. Bestop underseat lock box wint open.
- help with hemi running poorly and really bad gas mileage
- Rubicon Express 2.5 Spacer Lift to 2.5 Spring Lift
- Need help. Running out of ideas.
- TPM System coming on after installing lift and 35"s.
- Speedo not working after gears and superchip
- Kink in winch cable
- Changeing lug pattern
- Resonator deleted
- Best deal on Procal.
- Weird Speedometer Question
- What are your Thoughts on Installing a Supercharger in a 2011 3.8?
- Aftermarket bumper and fog lights
- Arb air compressor
- Artec Truss Installation
- Anyone like the mopar cold air intake for 3.6
- Windshield header/channel needed for new soft top?
- Can I lower my JK an inch?
- T-case, Towing, and Manual Hubs
- Can I use an OEM drag link after doing the drag link flip?
- Rustoleum right over powder coat?
- Installing Multiple Light Sets on a Jeep
- Front DS
- How Catalytic Converters Work, Parts 1 & 2
- Know where to get these in the u.s.???
- Hemi Swap time
- Upgrading springs on 2.5" lift
- Best price on Pitbull Rocker Radials?
- I've been gone for years what to do...
- First Time Out... First Time Broke!
- Question about soft tops......
- NV241 Transfer case swap - Rubicon to Sport
- Help Front End Vibration
- Changing Springs
- 15" wheels RK tie Rod
- Synthetic Rope Protector
- Mamba MR1X 16s and 17s with 285's
- Locking Front Hubs
- Atx slab question
- What to expect?
- 2007 Steering Gearbox on a 2010
- tires decision time soon
- p0300 multiple cyl miss fire. Sometimes....
- Help with Shocks!!
- New jeeper
- Track bar hell! Any ideas please?
- Ls 5.3 swap
- Go pro mounts ?
- Has anyone used the MetalCloak Drop Brackets?
- How do able are 15in wheels on JKU?
- 1 ton build- Custom Brake lines Needed
- Spare tire rattle fixed!!!
- Frame Notch
- 5.7 hemi 37 tires and 5.38s good or bad
- Skid Plates
- Pro Rock Tie Rod - Wheel Clearance Issue
- 2012+ exhaust system on 2007
- plasti dipped rockers
- Finally a member of the Jeep family
- Smitty Built XRC Rear Corner Guards
- aev 4.5 inch sc lift converted to aev 2.5 xt lift
- ESP issue is getting old!
- One person first time lift install experiences
- New beadlocks on the market?
- gobi stealth rack install question
- Diff help!!!!!!!
- Another what's that noise thread.......
- 16 inch wheels
- Power steering whine but no leaks or signs of wear
- So i spun a rivnut
- Dana Spicer driveshaft?
- Drive Shaft Question
- Power Dome Hood
- Will they work together? - ShrockWorks Rear Bumper and Garvin Adventure Rack
- lift advice
- JK 1 ton axles electronics and splicing ABS wires?
- JKS 2" rear springs and forward tilt
- Secondary diff oil change
- Coil wedges needed
- Rattling Sound before shift?
- final crawl ratio
- PIC REQUEST: Mammoth Boulder Wheels (BLACK)
- Jeep jumps sideways when hitting bumps at highway speeds...why?
- Bushwacker flat style fender flares
- Replaced Steering box, now too much movement to the left
- Best dual steering stabilizer?
- Help please. Weird steering wobble...
- Is Planman wrong? Checking Tie Rod Ends
- Shout Out to Warn
- setting steering after broken sector shaft
- What tire pressure when running 37's??
- OME 4" lift w/ Synergy Drag Link Flip
- 37x12.5 vs 38x13.5
- driveline slip yoke question
- D60 vs G2 D44 front axle.
- Trektop NOT NX
- 1" performance accessories body lift??
- Tough stuff gasket or nothing?
- Deals on mopar/spicer 60's
- Need replacment inner washer for fox ats?
- SC'd 3.8L crank pulley dowel pin?
- 3" afe mach force xp high tuck exhaust
- Mopar stage 1 2" lift w/fox shocks
- Rk front track bar to long ?
- JKU Rubi vs TF 2.5" coils
- Drag Link vs. Tie Rod upgrade?
- Mid Width Bumper Options
- Alignment problemd
- Light weight bumpers for JK
- Looking for painted fenders - New Jersey
- Mopar high clearance fenders
- Does changing the tire size with flashcal change shift points?
- Swapping out Coils question
- For those who want to run 37s on stock rubi D44s...
- Lift Kit for Looks Only
- JK Differential Rebuild
- Adjustment "knobs" on Rancho RS 9000XL
- 4BT Swap
- Leveling kit with a suspension lift
- Purchase pre 2013 or Not.
- LOD Full width bumpers
- 3rd Row Using TJ Brackets
- AEV 2.5 Lift using Synergy Longer Fixed Lower Control Arms instead of Drop Brackets
- Poison Sypder Hood Louver for daily driver
- anyone have the teraflex epic front bumper with grille guard?
- Lift ID
- Steerbox Leak
- In Dash CB
- Shop to Weld Truss
- Wobble after Tire Rotation
- How to put this?
- Best Cover for a 2013 JKU
- Beefing up the Aev lift
- Fox 2.5 internal bypasses
- Can we talk about MPG (again)?
- Rancho RS9000XL shocks, Settings
- Where to run wiring for third brake light to tire carrier?
- Quadratic LED Fogs
- Fender flares
- Lift ?
- Want to replace 14mm bolts in control arms w/9/16"; Will swap affect alignment?
- Installed a nice combo today. Banks, Magnaflow, Superchip
- Rubicon Express Driveshafts
- Replace budget boost with real lift kit?
- Dynatrac pro grip brake system questions
- replacing my manual with an auto
- Adjustable Control Arms vs relocation brackets.
- Recommendation on non weld on exhasut tips /that fit on the stock exhaust
- What would you do with this Mopar Bumper?
- Stiffer Springs 2 door JK
- Quadratec Quick Release Mirror Movers with Square Head WHISTLING...
- Faulty Computer?
- Regearing with Rubicon Lockers
- Dyno Numbers?????
- finally back in a jeep.
- Carrying a spare tire on the roof
- New front Bumper -- How much sag?
- 5.13's above 70mph
- Frameless soft top?
- RIPP long tube headers? Worth it?
- Game Changer and Exhaust
- 2012 JKU that have regear from 3.21
- Anyone out there running the new Dana axles?
- Genright Tire Carrier LOCK!!!
- Pro armor 4 point harness
- Help! Pulled front locker sensor plunger thingy - now locker wont disengage
- Recommendations on new 3 inch springs
- How much lift
- E rated Trail Grapps / Duratracs
- Help identifying mirror mounts on a lightbar
- Steering vibration
- Rock krawler Rear LCA with EVO ROCKSTARS
- Great Looking Side Step!!!
- Engine Transmisson skid plate
- badland winch=bad idea???
- Ripp supercharger tune
- Share some pics please...
- Will a budget lift for a 2007 JK work on a 2012 JK
- making custom Fox dual stabilizer
- My favorite game, what's that sound
- Tranfer case 4.1 convert
- EVO or MC Front LCA's?
- Decision time on tires, DuraTracs or BFG Mud TA/KM 2's
- engine whine - rpm based
- Dirtman made the big time.
- Aussie Locker for the Dana 44 rear
- Light weight rear bumper with integrated lights
- Rancho 9000's
- Rock Krawler 3.5" X Factor vs Flex
- Wheel curiosity
- LED Tail Lights Recommendation
- Need help
- Who makes this bumper/fog light?
- MOPAR CAI & Exhaust for 2008 JK
- Steering not Centered
- Tuffy Cargo Locking Cubby Cover
- 35s, 4 inch lift, flat fender flares pics?
- how to get a bolt seized inside those metal bushing sleeves.
- 2 post lift jack point
- Rock rail advice
- need help guys
- Lower control arm correction brackets?
- 2015 Hard Rock level kit advice please?
- Spiderweb Shade & Bestop Supertop NX 2 Door ???
- Spiderweb Shade 2 Door Bestop & Supertop NX ??? 2 Door
- paint stock fenders
- Havoc Offroad
